[Fixed] Not able to detect ps3...
footpunker60
Post by footpunker60 »
Hey! I'm having some issues with ums! Not sure why but sometimes it work sometime it dosen't... tried to isolate the issue without any sucess. I tried restart the app, restart the ps3, restart the computer and right now everything fail... Not sure why but usually when I did restart the computer after it was always working but not anymore... I tried the option to force PS3 as default... dosen't change a thing...
Thanks for the help in advcance!
here is my debug:
INFO  2012-12-12 17:42:51.455 [main] An invalid plugin was ignored
INFO  2012-12-12 17:42:52.046 [main] Starting Universal Media Server 2.2.0
INFO  2012-12-12 17:42:52.076 [main] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2012-12-12 17:42:52.087 [main] http://www.universalmediaserver.com
INFO  2012-12-12 17:42:52.089 [main]
INFO  2012-12-12 17:42:52.090 [main] Build: dad63b8b4 (2012-12-11)
INFO  2012-12-12 17:42:52.092 [main] Java: 1.6.0_37-Sun Microsystems Inc.
INFO  2012-12-12 17:42:52.094 [main] OS: Windows Vista 32-bit 6.0
INFO  2012-12-12 17:42:52.097 [main] Encoding: UTF-8
INFO  2012-12-12 17:42:52.099 [main] Memory: 742 Mo
INFO  2012-12-12 17:42:52.100 [main]
INFO  2012-12-12 17:42:52.100 [main] Working directory: D:\Program Files\Universal Media Server
INFO  2012-12-12 17:42:52.110 [main] Temp directory: C:\Users\Gerald\AppData\Local\Temp\universalmediaserver
INFO  2012-12-12 17:42:52.113 [main] Logging config file: D:\Program Files\Universal Media Server\logback.xml
INFO  2012-12-12 17:42:52.115 [main] debug.log: D:\Program Files\Universal Media Server\debug.log
INFO  2012-12-12 17:42:52.116 [main]
INFO  2012-12-12 17:42:52.116 [main] Profile directory: C:\ProgramData\UMS
INFO  2012-12-12 17:42:52.117 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-12-12 17:42:52.118 [main] Profile permissions: rw
INFO  2012-12-12 17:42:52.119 [main] Profile name: PC-de-Gerald
INFO  2012-12-12 17:42:52.120 [main]
INFO  2012-12-12 17:42:52.125 [main] Loading MediaInfo library
INFO  2012-12-12 17:42:52.199 [main] Loaded MediaInfoLib - v0.7.61
INFO  2012-12-12 17:42:52.205 [main] Loading renderer configurations from D:\Program Files\Universal Media Server\renderers
INFO  2012-12-12 17:42:52.206 [main] Loading configuration file: AirPlayer.conf
INFO  2012-12-12 17:42:52.209 [main] Loading configuration file: Android.conf
INFO  2012-12-12 17:42:52.211 [main] Loading configuration file: Bravia4500.conf
INFO  2012-12-12 17:42:52.213 [main] Loading configuration file: Bravia5500.conf
INFO  2012-12-12 17:42:52.215 [main] Loading configuration file: BraviaEX.conf
INFO  2012-12-12 17:42:52.219 [main] Loading configuration file: BraviaEX620.conf
INFO  2012-12-12 17:42:52.222 [main] Loading configuration file: DirecTVHR.conf
INFO  2012-12-12 17:42:52.225 [main] Loading configuration file: DLinkDSM510.conf
INFO  2012-12-12 17:42:52.228 [main] Loading configuration file: FreeboxHD.conf
INFO  2012-12-12 17:42:52.229 [main] Loading configuration file: FreecomMusicPal.conf
INFO  2012-12-12 17:42:52.231 [main] Loading configuration file: iPad-iPhone.conf
INFO  2012-12-12 17:42:52.233 [main] Loading configuration file: Kuro.conf
INFO  2012-12-12 17:42:52.236 [main] Loading configuration file: LGST600.conf
INFO  2012-12-12 17:42:52.238 [main] Loading configuration file: N900.conf
INFO  2012-12-12 17:42:52.241 [main] Loading configuration file: OPPOBDP83.conf
INFO  2012-12-12 17:42:52.243 [main] Loading configuration file: OPPOBDP93.conf
INFO  2012-12-12 17:42:52.244 [main] Loading configuration file: Panasonic.conf
INFO  2012-12-12 17:42:52.247 [main] Loading configuration file: Philips.conf
INFO  2012-12-12 17:42:52.248 [main] Loading configuration file: PhilipsPFL.conf
INFO  2012-12-12 17:42:52.251 [main] Loading configuration file: PopcornHour.conf
INFO  2012-12-12 17:42:52.253 [main] Loading configuration file: PS3.conf
INFO  2012-12-12 17:42:52.262 [main] Loading configuration file: Realtek.conf
INFO  2012-12-12 17:42:52.264 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2012-12-12 17:42:52.266 [main] Loading configuration file: SamsungAllShare.conf
INFO  2012-12-12 17:42:52.268 [main] Loading configuration file: SamsungWiseLink.conf
INFO  2012-12-12 17:42:52.270 [main] Loading configuration file: Showtime3.conf
INFO  2012-12-12 17:42:52.271 [main] Loading configuration file: SMP-N100.conf
INFO  2012-12-12 17:42:52.273 [main] Loading configuration file: SonyBluray.conf
INFO  2012-12-12 17:42:52.275 [main] Loading configuration file: SonyBraviaHX800.conf
INFO  2012-12-12 17:42:52.277 [main] Loading configuration file: Streamium.conf
INFO  2012-12-12 17:42:52.278 [main] Loading configuration file: WDTVLive.conf
INFO  2012-12-12 17:42:52.280 [main] Loading configuration file: WMP.conf
INFO  2012-12-12 17:42:52.281 [main] Loading configuration file: XBMC.conf
INFO  2012-12-12 17:42:52.282 [main] Loading configuration file: XBOX360.conf
INFO  2012-12-12 17:42:52.285 [main] Loading configuration file: YamahaRXA1010.conf
INFO  2012-12-12 17:42:52.287 [main] Loading configuration file: YamahaRXV671.conf
INFO  2012-12-12 17:42:52.288 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2012-12-12 17:42:52.289 [main] launching: win32/mplayer.exe
DEBUG 2012-12-12 17:42:52.383 [main] launching: win32/mplayer.exe
INFO  2012-12-12 17:42:52.479 [main] Finished checking the MPlayer font cache.
DEBUG 2012-12-12 17:42:52.480 [main] AviSynth plugins directory: d:\Program Files\AviSynth\plugins
DEBUG 2012-12-12 17:42:52.480 [main] VSFilter / DirectVobSub was found in the K-Lite Codec Pack filters directory.
INFO  2012-12-12 17:42:52.486 [main] Searching for plugins in D:\Program Files\Universal Media Server\plugins
INFO  2012-12-12 17:42:52.487 [main] No plugins found
INFO  2012-12-12 17:42:52.502 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-12-12 17:42:52.503 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-12-12 17:42:52.509 [main] Registering transcoding engine: MEncoder
INFO  2012-12-12 17:42:52.510 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-12-12 17:42:52.511 [main] Registering transcoding engine: FFmpeg
INFO  2012-12-12 17:42:52.511 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-12-12 17:42:52.512 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2012-12-12 17:42:52.512 [main] Registering transcoding engine: MEncoder Web
INFO  2012-12-12 17:42:52.514 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-12-12 17:42:52.514 [main] Registering transcoding engine: MPlayer Web
INFO  2012-12-12 17:42:52.516 [main] Registering transcoding engine: tsMuxeR
INFO  2012-12-12 17:42:52.517 [main] Registering transcoding engine: Audio High Fidelity
INFO  2012-12-12 17:42:52.517 [main] Executable of transcoder profile VLC Audio Streaming not found
INFO  2012-12-12 17:42:52.518 [main] Executable of transcoder profile VLC Video Streaming not found
INFO  2012-12-12 17:42:52.518 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-12-12 17:42:52.519 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-12-12 17:42:52.647 [main] Using address /192.168.1.3 found on network interface: name:eth2 (NVIDIA nForce Networking Controller)
INFO  2012-12-12 17:42:52.648 [main] Created socket: /192.168.1.3:5001
INFO  2012-12-12 17:42:52.729 [main] Checking shared folder: E:\VIDEO
INFO  2012-12-12 17:42:52.730 [main] Checking shared folder: J:\
INFO  2012-12-12 17:42:52.730 [main] Checking shared folder: G:\Mp3 simon
INFO  2012-12-12 17:42:52.730 [main] Checking shared folder: G:\Torrent\NOFX - All 3 DVDRIPs - 10 Years_Backstage_Decline
INFO  2012-12-12 17:42:52.731 [main] Checking shared folder: D:\TORRENT
DEBUG 2012-12-12 17:42:52.794 [main] Sending ALIVE...
INFO  2012-12-12 17:42:52.815 [main] Using the following UUID configured in UMS.conf: 0cbda82e-cb81-4a2a-b1a2-f3c54b3905c8
INFO  2012-12-12 17:42:58.085 [main] The server is now available for renderers to find
DEBUG 2012-12-12 17:43:08.085 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:43:32.154 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:46:37.655 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:49:41.676 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:52:44.545 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:55:49.815 [UPNP-AliveMessageSender] Sending ALIVE...
2012-12-12 17:42:51.804 [WrapperSimpleAppMain] Using address /192.168.1.3 found on network interface: name:eth2 (NVIDIA nForce Networking Controller)
INFO  2012-12-12 17:42:51.805 [WrapperSimpleAppMain] Created socket: /192.168.1.3:5001
INFO  2012-12-12 17:42:52.002 [WrapperSimpleAppMain] Checking shared folder: E:\VIDEO
INFO  2012-12-12 17:42:52.003 [WrapperSimpleAppMain] Checking shared folder: J:\
INFO  2012-12-12 17:42:52.003 [WrapperSimpleAppMain] Checking shared folder: G:\Mp3 simon
INFO  2012-12-12 17:42:52.003 [WrapperSimpleAppMain] Checking shared folder: G:\Torrent\NOFX - All 3 DVDRIPs - 10 Years_Backstage_Decline
INFO  2012-12-12 17:42:52.003 [WrapperSimpleAppMain] Checking shared folder: D:\TORRENT
DEBUG 2012-12-12 17:42:52.088 [WrapperSimpleAppMain] Sending ALIVE...
INFO  2012-12-12 17:42:52.109 [WrapperSimpleAppMain] Using the following UUID configured in UMS.conf: 0cbda82e-cb81-4a2a-b1a2-f3c54b3905c8
INFO  2012-12-12 17:42:56.787 [WrapperSimpleAppMain] The server is now available for renderers to find
DEBUG 2012-12-12 17:43:06.787 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:43:31.820 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:46:36.077 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:49:40.155 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:52:43.493 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-12-12 17:55:46.891 [UPNP-AliveMessageSender] Sending ALIVE...
footpunker60
Re: Not able to detect ps3...
btw i'm not able anymore to make it work... not sure why... please help!
dmh
Post by dmh »
This is going to sound dumb, but did you enable the media server option on the ps3?
footpunker60
yeah lol... I can see me window media server! What I don't understand is that it was working b4!
squadjot
Post by squadjot »
Did you configure spefic shared locations..?
I experienced if UMS is showing all drives (default)..sometimes it can take a while for UMS to start up
footpunker60
yes I have specifics folder in fact... but lot of stuff in them... but it's not a time issue... I tried PS3 media server which look a lot like UMS and it's not working either...
footpunker60
I did the force to choose network and putted pot 6001 and now it work... guess the port got used by something else? Not sure what since I didn't chance a thing! Anyway thx for the help!
