XBox 360 doesn't See UMS but it can see PMS
Re: XBox 360 doesn't See UMS but it can see PMS
Hi guys, can one of you please try this version to see if it still has the bug?
I have tried to reproduce it but I can't with either my PS3 or Panasonic TV, so I have to rely on you guys for tests
Downloading it now.
Will edit with the results.
Trace log shows that UMS is picking up the 360 as a renderer, but I'm still not seeing it on the 360 itself:
INFO 2012-06-03 10:35:05.074 [pool-6-thread-2] Checking IP: 10.0.0.5 for Xbox 360
INFO 2012-06-03 10:35:09.684 [pool-6-thread-2] Renderer Xbox 360 found on this address: 10.0.0.5
Thanks a lot, Secate. I think I've found the problem, uploading another test now
Can someone please try test 4?
Thanks Sub, test4 is working correctly. What was the issue?
XBOX requires a different tag than other renderers in order to see the server and the rename broke the code that customised it. I'm releasing 1.0.1 nowish with the fix, cheers
Downloaded v1.01 and things look good, my XBox can see UMS.
Thanks for confirming, cmonster, and thanks for the private testing I've added thanks to you and Secate to the announcement/changelog
Not a problem, glad to have helped. Keep up the good work!
Any time Sub, long time fan of PMS/UMS
