MEncoder h264 Encoding Support
Madoka
Post by Madoka »
Sorry for the newb question.
Will SB52/UMS 2.6.0 use h264 encoding automatically on renderers that support it, or do I have to edit the conf file or do something else? Nothing seems to have changed in that respect on the PS3 with subtitles...maybe the PS3 does not support this feature?
Thanks.
Re: MEncoder h264 Encoding Support
Yes you have to set it in the renderer.conf file to use it :) Like this:
TranscodeVideo = H264TSAC3
It isn't done for any renderers at the moment because it needs more testing
