Possible MediaInfo Bug vs Bad File?
Madoka
Post by Madoka » Sun Apr 07, 2013 9:14 am
I realize this is not a UMS bug, but I'd thought I'd mention it anyways. I apologise if I am out of line.
The following file results in a 2101 DLNA error and a hard crash of UMS 2.6.0 (the icon will disappear from the task bar) if you browse into the folder containing it. I did a test and isolated this file as the culprit.
General
Format                         : MPEG-TS
File size                      : 347 MiB
Duration                       : 3mn 30s
Start time                     : UTC 2013-01-22 21:38:50
End time                       : UTC 2013-01-22 21:42:15
Overall bit rate mode          : Variable
Overall bit rate               : 13.8 Mbps
Network name                   : 6a5&~²
Video
Menu ID                        : 2064 (0x810)
Format                         : MPEG Video
Format version                 : Version 2
Format profile                 : [email protected]
Format settings, BVOP          : Yes
Format settings, Matrix        : Custom
Codec ID                       : 2
Duration                       : 3mn 30s
Bit rate mode                  : Variable
Bit rate                       : 12.9 Mbps
Width                          : 1 440 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate                     : 29.970 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Interlaced
Scan order                     : Top Field First
Compression mode               : Lossy
Bits/(Pixel*Frame)             : 0.277
Stream size                    : 324 MiB (94%)
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.709
Audio
Format                         : AAC
Format/Info                    : Advanced Audio Codec
Format profile                 : LC
Muxing mode                    : ADTS
Codec ID                       : 15
Duration                       : 3mn 30s
Bit rate                       : 192 Kbps
Channel(s)                     : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 48.0 KHz
Delay relative to video        : -8ms
Stream size                    : 4.82 MiB (1%)
Menu
List                           : 273 (0x111) (MPEG Video) / 274 (0x112) (AAC) / 276 (0x114) () / 277 (0x115) ()
Service name                   : ~ÍÂÓKhF|J|Aw
Service type                   : digital television
UTC 2013-01-22 21:00:00        : ja:2PMK6J~ÓÐ$*;}úÖúØ / ja:1j>eI,;j$*;}ýï~ÁË´¸*0}Ë7c;w|âÎÞÍ7]?MEP>l}Ç=i4i9gï»~¡:#G/}â4V0c¤Ê¯@9ê>e¬ë6J|«éª±éó­ó°H/I=}ËMpF~|´!<ëÇóÜóÐ!<}ɦÊë$*;}ýïCfEgH~2E*0}Ë~ÓËÅ´¸ / reserved for future use /  / 01:48:00 /
UTC 2013-01-22 22:48:00        : ja:|¹­Þ}À|¸ãë¸ãë / ja: / reserved for future use /  / 00:06:00 /
UTC 2013-01-22 22:54:00        : ja:~ÎÅ×Ó²³|¯í¹ / ja:|¢ë¸§ê¢:G?7>pJs"&}µ¢F|K\|¹ÞÛ}Î5U=1~¡[email protected]|ÒÃÈ5!<o}Î8=>l"&[email protected]|Ïï¤L)Ce / undefined /  / 00:51:00 /
UTC 2013-01-22 23:45:00        : ja:~ÍÂÓ|Ëå!<¹ / ja: / undefined /  / 00:05:00 /
UTC 2013-01-22 23:50:00        : ja:´Ö´Ö$*;}úÖ / ja:IMED2m8y!"ElLn9,<#¬!V8^J,8^J,!WÎN)>lÇ|í±}ò¹ëHVAH"&¤Þ:Gâ|¢Ä}¤D.!&Cf:jD.òC58!~¡IM}Áãó|¹¤!<Ä}ËBgK~B-~¡El}ÎêÏ8ECeËD)@o~¡¿ / reserved for future use /  / 01:05:00 /
UTC 2013-01-23 00:55:00        : ja:|ÎÖʬ$*;}úÖ / ja:!V|¦§Öʬ!W~¼L?}ò«±¿|µéê!<Þó}Î<qL#!AF67"C58!~¾¼|Öµ¤¯}ʪ¸µóË|É­É­}¹ë=w;[email protected]~¾"&!V;W}¤=P«±Ã³!W"&~ÁË´¸KL86N$1Q!V}«ï¤¤Ê¾Ê¾!W / reserved for future use /  / 01:00:00 /
UTC 2013-01-23 01:55:00        : ja:|Ñï!<!y×êó / ja:|Ñóµ!<Hx7A}Î?M5$|­ãé!XBgFsO:!Y}¬7c?I¦Éóò~ÐÒ¡Bg?M5$|°éÉë4]9b0&H~}â1~1gË~¡}·«·!"Þµ«Î4]9bâD)@o~¡¿E7:M;RLr|³óÈ!X>>Hx=Y;0O:!Y}ä?7:n|³óÈ}â~¡ / entertainment programmes for 6 to 14 /  / 00:30:00 /
UTC 2013-01-23 02:25:00        : ja:~ÅÎÔ / ja:2;3Z!"1G2h!"IqBfȤÿ~Åîôåòôáéíåîô}Ê~Îå÷ó}È~Ôéãëåô>pJs}òªFO±¹ëHVAH!# / reserved for future use /  / 00:15:00 /
UTC 2013-01-23 02:40:00        : ja:$*;}úë=*EE|ФФ!!Bh~±OC}úÖ / ja:!VBh0lLk!&N)@n1X!A?<LkÎBg?MÎKA81~¡!W"&N)@n1X}Ç=*EEòF(·¿:4F#Ï!"8x1`Ç0z­³âêÎCK!&;3EDË=P2q¤!"µéË?<LkËʼ«!V|±¤Éí!W}Ë;22C¹ë³ÈËÊê!D / reserved for future use /  / 00:40:00 /
UTC 2013-01-23 03:20:00        : ja:~íí­ÔÖ / ja: / sports /  / 00:10:00 /
UTC 2013-01-23 03:30:00        : ja:|ï!<ëɳ쯷çó´!<ëÉ / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-23 04:00:00        : ja:Di??0l!!|ÒÞéä=dNiÊÓ / ja:~²¶F|¨EZ©}Òë~²;~!A"&GPM%!&Di??0l}¬@$3&:G9bJv!&|¨Ùì¹È~¨¸¬¸´¸í©}Ç2?òA[¦Î«~¿ / reserved for future use /  / 00:02:00 /
UTC 2013-01-23 04:02:00        : ja:|Ëå!<¹Ð!<É / ja: / undefined /  / 00:28:00 /
UTC 2013-01-23 04:30:00        : ja:|·çÃ×~´³° / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-23 05:00:00        : ja:D+Î|¤Áª·~¡ / ja: / discussion/interview/debate /  / 00:15:00 /
UTC 2013-01-23 05:15:00        : ja:Aa|ºÐÃ~¡|ÊÞ}¿Þ´$*;}úØ / ja:KhD+Î:G?7|Ëå!<¹!"¹Ý!<Ä;f0lLL>pJs!":#F|}ÎE75$ÊɽÎF|ËCN꿤>pJsò!"|³óѯÈ}Ë~±µJ,}Ë|Õì÷å}˪EA¨·Þ¹!# / user defined /  / 00:15:00 /
UTC 2013-01-23 05:30:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:ßÎâó¿!!D+BSHVAHË;2>e$*;}ýî / user defined /  / 00:25:00 /
UTC 2013-01-23 05:55:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:|¢ë¸§ê¢?M<A;v7oÆí5>@7}ÎF|K\?M0dB2|«áé}Ë8lÿ2y·µK\EvËL5M}ÀÿΫ5_=P:[email protected]òE0Dl8!>Z~¡"&J*2AL\I8²¥}ÃÆ2?F|6d6bM;@/:v½ÎCf?H"&BgEg4FFDN^Î9pJL<0 / user defined /  / 02:35:00 /
UTC 2013-01-23 08:30:00        : ja:ÏÊÞë|Þ!<±ÃÈ$*;}úÖúØ / ja:Be<U~ÕÐ}ǤÄÎ4VË«Ai»ë~¡80}Ï!H|Ë!<È!I~¡¡"&;P!&[email protected]}¦Î¬>W7bH/[email protected]~¡L!:M2&<T!&|ÏÞ«!<ó / reserved for future use /  / 01:25:00 /
UTC 2013-01-23 09:55:00        : ja:|×ê×ê / ja:Bg:e6uKYÇ8+ı¿<j:nêApMz"&5HC];~7W:nêËD)@o~¡"&3$30}Ø~¡?74k2hH/I= / news magazine /  / 00:55:00 /
UTC 2013-01-23 10:50:00        : ja:Öé|óÁ / ja:!V|ª¹ÆªÑ·!<!W}Ç>.4i~¦|êÕÈ¢Ã×~¡!V|Óå!<Æ£!<~¦|ê鯼!<·çó~íáîá!W / news magazine /  / 00:03:00 /
UTC 2013-01-23 10:53:00        : ja:M_|Ðê;T>l / ja: / discussion/interview/debate /  / 00:07:00 /
UTC 2013-01-23 11:00:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:30:00 /
UTC 2013-01-23 11:30:00        : ja:ÒëªÓ~¡$*;}úÖ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:25:00 /
UTC 2013-01-23 11:55:00        : ja:ÒëªÓ~¡ / ja:!HM%·¯Æ7;5.;W¤!I|Æí5>@7<T0dB2L5G0!D;D}ë~³K.?M}Î0BH]Ï"&9qO"Î@):[7h5DÇKLÎ3K<B836/9TÏ~¿"&G/>&´°2/1_¡¡=\|Í¿}ÇLv?J2sE><w;JÎ[email protected],$*;}úô / news/current affairs /  / 01:55:00 /
UTC 2013-01-23 13:50:00        : ja:´´|Í¿~¡@c7n2VÔÖ$*;}úÖ / ja:"&F|K\Ë@N«é¢ëLnÎ2V!&<yLZ!&>.D;!&CnÊÉÎ?H6aÊ<+A3ÎCf«é5(@aËյ﷤|Æ!<Þ}ò<hê>e²!"H~·¤1GA|òCf?4Ë!"|Æ!<Þ}ËÞÄïëF&CN<1ÊÉò>R2p·Þ¹!# / user defined /  / 00:05:00 /
UTC 2013-01-23 13:55:00        : ja:|ÉéÞ}Î8w!V?7;2<T!W!!Bh~²OC$*;}úêúÖ / ja:!VNADbÎ>.AN!W"&;&?M8=>lË;Dµì¿!V?M7A>F!WÎ;XLf!#³ìÇ!"HH?M¬3dìëΫ~¡¿2C2l¨0$It42©}Î?dM}ÈF6;!NOÇ!"È¢ë;v<B¬!&!&!&!# / reserved for future use /  / 01:00:00 /
UTC 2013-01-23 14:55:00        : ja:ÁÁóפפ / ja:3$30ÎF|K\?Mòɦ<ië~¿"&A49qM-L>1XJ[E9}Î?7>&IJBg:e>eN&"&>CHqA}@GÇ[email protected]<TBP:v"&B?ItB29q|¬!<Ê}Ç6C­Î4?7^K!"&|í°Ï¦¹}Ç|·Áê¢NAM}4.G=}Î[email protected]"&|ÖêBg:, / reserved for future use /  / 02:50:00 /
UTC 2013-01-23 17:45:00        : ja:~Î|¹¿$*;}úÖ / ja:[email protected]@¬ªFO±¹ëM<J}ÎBg7?JsF;HVAH!#E0Dl<h:`·¿~ÖÔÒ}È!"«æ¤È³íË<j¬FO¯|¹¿¸ª[email protected]}Ç!"Fq·¤@/<#!&7P:Q!&<R2qLdBjâ!"|ÐÃÁê}ï«êÞ¹!# / reserved for future use /  / 00:30:00 /
UTC 2013-01-23 18:15:00        : ja:~ÖÏÉÃÅ$*;}úÖ / ja:|ÞëD4!!L)<<}Ç2?¬5/­¿Î«[email protected]ÎHtÓ9_ê;`ÈBNH3«;XF3ò=dëBPN) / undefined /  / 00:45:00 /
UTC 2013-01-23 19:00:00        : ja:?e|ȯ~¡!V|¿«È·}Î;~4Vǹè~¡!W$*;}úÖ / ja:"!2sEzN(~±°°¥¡:G6/CN<1?M!!²;~4VÓÐ"!Ñ;K>e:G}âF,Τ¤?MÏ~¿ÑCO5e0J30}Î@1ËÏ=;áë~¿Ñ5-21}Î8r49Ï=PMhë~¿Ñ!Vo[!W}³Î4A;z2?ÈFIà~¿ / reserved for future use /  / 01:54:00 /
UTC 2013-01-23 20:54:00        : ja:|Õé÷åËå!<¹ / ja: / undefined /  / 00:06:00 /
UTC 2013-01-23 21:00:00        : ja:?eMK|×ìߢ·ÍÞ!V¨¤ê¢ó~²!W$*;}úÚúÖúØ / ja:~¼|Ǹ¿ëêÞ¹¿!<HG~¾²°@$5*}Î1G2h;KË51¯~ÓÆ|¹!<Ñ!<!&ÒÃÈ!V¨¤ê¢ó!W·ê!<º:G9b7f:n!D<!}«é<!ØÈ=1ÃƯë62I]Î|¨¤ê¢ó}ä6aL$MhJ<4oÏ[email protected]~¡ / reserved for future use /  / 01:54:00 /
UTC 2013-01-23 22:54:00        : ja:~ÎÅ×Ó²³|¯í¹ / ja:?73c!&86H/2TF/á°ë=;L1EjI<>rNc0FÇ:N7h"&=w;R|¸ãó×9bM|:;Me~¡|½Á8^NX6b}Ø2]BjÏ!D / undefined /  / 00:51:00 /
UTC 2013-01-23 23:45:00        : ja:~ÍÂÓ|Ëå!<¹ / ja: / undefined /  / 00:05:00 /
UTC 2013-01-23 23:50:00        : ja:|ÑÆÊ}Î[email protected]~¡$*;}úÖ / ja:!V|Öé¸ã!<!W}Î5?Ld2r7h$*;}þáH~MFHVD9|·ë¯[email protected]*0}·¤@v¤J}$*;}þâ|×í*0}¬A*Ö:G9b|Öé$*;}þã6;*0}ò>.µ¯8+»ëHkL)"&|¸åË¢~¦|í¶ó / reserved for future use /  / 01:05:00 /
UTC 2013-01-24 00:55:00        : ja:|Ëó²ó4Q;!Ðé¨Æ£!!âË¿êó° / ja:6K8BËDI¤9~Þì¿?M4VÎ9TF0ϳóÊËLLGr«Ã¿~¡!V|«éª±CfµÓ}ÎD>A0ÇE90w¬F~ÃÆ­¿é~¿!W!VL\}ÎA0Ϊ2[;Rò?)ÙëÎò2fK}¹ëÈ;R6!ÏɦÊë~¿!W / entertainment programmes for 6 to 14 /  / 00:30:00 /
UTC 2013-01-24 01:25:00        : ja:|«óËó°C];3}Î|¼Ë¦¹}ÎLk / ja:7c·¤Î¬ª9%­ÊH~?M?M:J~ÖÓL!:MGF<[email protected]:}Î;~ / user defined /  / 00:30:00 /
UTC 2013-01-24 01:55:00        : ja:=wÎ;[email protected]@~¡|¢²}Ýè~ÔÖ / ja:M-L>;(;o«éÎ<h:`"&B46HH/I=~¡¡ / entertainment programmes for 6 to 14 /  / 00:30:00 /
UTC 2013-01-24 02:25:00        : ja:~ÂÒÁÖÁ¡ / ja:|Öí!<ɦ§¤ßå!<¸«ë!X¹¦£!<Ë!<!&ÈÃÉ!Y}¬~µ7n}Ë:F!91iµìë!#;TB<@5?F!_BgC]·ÎÖ!_5\K\0!LgÎ4i9gï»Ï:#2s¬~ÆÉÎÁÌ!#}ª8+F(·Ê¯~¡ / user defined /  / 00:05:00 /
UTC 2013-01-24 02:30:00        : ja:~ÆÉÆÁ|ÕÃÈÜ!<ë!&àóÇ£¢ë$*;}úÚ / ja:@$3&Î|µÃ«!<}Î:G?7>pJsä|¹!<Ñ!<¹¿!<}Î|¤ó¿Óå!<}ÊÉòK~:\!#FC=8ÇÏ3F9qÎOCBjä2a5nÎL>>!IiÊÉâEP>l!#|µÃ«!<Õ¡ó}ÏMW|Á§Ã¯~¡ / movie/drama /  / 00:30:00 /
UTC 2013-01-24 03:00:00        : ja:~íí­ÔÖ / ja: / sports /  / 00:10:00 /
UTC 2013-01-24 03:10:00        : ja:|ï!<ëɳ쯷çó´!<ëÉ / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-24 03:40:00        : ja:Di??0l!!|ÒÞéä=dNiÊÓ / ja:~²¶F|¨EZ©}Òë~²;~!A"&GPM%!&Di??0l}¬@$3&:G9bJv!&|¨Ùì¹È~¨¸¬¸´¸í©}Ç2?òA[¦Î«~¿ / reserved for future use /  / 00:02:00 /
UTC 2013-01-24 03:42:00        : ja:|Ëå!<¹Ð!<É / ja: / undefined /  / 00:48:00 /
UTC 2013-01-24 04:30:00        : ja:|·çÃ×~´³° / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-24 05:00:00        : ja:D+Î|¤Áª·~¡ / ja: / discussion/interview/debate /  / 00:15:00 /
UTC 2013-01-24 05:15:00        : ja:Aa|ºÐÃ~¡|ÊÞ}¿Þ´$*;}úØ / ja:KhD+Î:G?7|Ëå!<¹!"¹Ý!<Ä;f0lLL>pJs!":#F|}ÎE75$ÊɽÎF|ËCN꿤>pJsò!"|³óѯÈ}Ë~±µJ,}Ë|Õì÷å}˪EA¨·Þ¹!# / user defined /  / 00:15:00 /
UTC 2013-01-24 05:30:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:ßÎâó¿!!D+BSHVAHË;2>e$*;}ýî / user defined /  / 00:25:00 /
UTC 2013-01-24 05:55:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:@$ÎCfÎ=PMh;vËE\ê!&6C­!&Ha·ß!&4nÖ!";kD0<TÎ3'µóÈEy?HBgÎ!HßÎâó¿!I¬D+BSË;2>e~¡¡KhD+!"D6|ÆóÝ}Î|¸§Ãȳ!<¹¿!<>pJsHVAH~¡ / user defined /  / 02:35:00 /
UTC 2013-01-24 08:30:00        : ja:ÏÊÞë|Þ!<±ÃÈ$*;}úÖúØ / ja:Jké·ËLrN)Ä>pJsK~:\~¡=\}Î?):`ä@dIJ|ì·Ô!"7r9/}äª6bÎCN<1!"@83hÎN"5;ÊɬEP>l·Þ¹!#½·Æ=\Î|²¹È}ò>7¯!VÏÊÞë|«Õ§!W}Û« / reserved for future use /  / 01:25:00 /
UTC 2013-01-24 09:55:00        : ja:|×ê×ê / ja:D+4)~¡5-;v}«éÜ¿âÁ"&ª¹¹á|éóÁ"&}ª[email protected]>pJsÛ« / news magazine /  / 00:55:00 /
UTC 2013-01-24 10:50:00        : ja:Öé|óÁ / ja:Ft:j1XA0Ë[email protected]¹ëBg5,LO|Þó·çó}ò|Á§Ã¯~¡ / news magazine /  / 00:03:00 /
UTC 2013-01-24 10:53:00        : ja:M_|Ðê;T>l$*;}úî / ja: / discussion/interview/debate /  / 00:07:00 /
UTC 2013-01-24 11:00:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:30:00 /
UTC 2013-01-24 11:30:00        : ja:ÒëªÓ~¡$*;}úÖ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:25:00 /
UTC 2013-01-24 11:55:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 01:55:00 /
UTC 2013-01-24 13:50:00        : ja:´´|Í¿~¡|Ï°}¯à~¡ÔÖ$*;}úÖ / ja:ªJlµóÀ±¬CNÃƤë!"ª;RµóÎE7:M|¨Ô½!<É}ä!"[email protected]ò46¸µ»ëÛÛ¨Þ·¤F|>oÎ>lLLò!"|«áé}ÎA0Ç8lÃƤ¿À­!"HdO*·Æâé¤Þ¹!# / reserved for future use /  / 00:05:00 /
UTC 2013-01-24 13:55:00        : ja:|ÉéÞ}Î8w!V?7;2<T!W!!Bh~³OC$*;}úêúÖ / ja:[email protected]%8MJ*20Î2G!W"&7v2^Î@d¨Ê¤@%8MJ*20Î2G8H!#4VË64ÞìÆ1&1}:81}¹ë@W<hêB);R!#³Î~³?M}¬;00fJw;R;&32;v7oÎ80ò0.ë~¡¿ / reserved for future use /  / 01:00:00 /
UTC 2013-01-24 14:55:00        : ja:ÁÁóפפ / ja:[email protected]>L\@~Ç=\Î|Ëå!<¹}ò@>Î!y0u~¦@PED}¬[email protected]!&Á¨ßâG<[email protected]"&|ê¢ë@$3&}ò;3CfCf7Q"&[email protected];KÎ3(K\N9"&Fn8wÎLQA[H~=Q0FFb"&@NÎ?MÏ0N«Ã¿2OED¯Ã¹óDAF;Cf / reserved for future use /  / 02:50:00 /
UTC 2013-01-24 17:45:00        : ja:~Î|¹¿$*;}úÖ / ja:[email protected]@¬ªFO±¹ëM<J}ÎBg7?JsF;HVAH!#E0Dl<h:`·¿~ÖÔÒ}È!"«æ¤È³íË<j¬FO¯|¹¿¸ª[email protected]}Ç!"Fq·¤@/<#!&7P:Q!&<R2qLdBjâ!"|ÐÃÁê}ï«êÞ¹!# / reserved for future use /  / 00:30:00 /
UTC 2013-01-24 18:15:00        : ja:~ÖÏÉÃÅ$*;}úÖ / ja:"&CO0hËL)Ce·¿|Ëå!<¹}òªFO±·Þ¹"&!VJ0XpK\J^!W!VFCL?D4::HI!!|ÞëÁç¦!W}ÊÉ4k2h|ꯨ¹È!&>pJs}ò<uIUCf~¡"&}ßóÊ~äåE75$!&}¢Ê¿Î?H6aÊ<L??Jg=8Cf~¡ / undefined /  / 00:45:00 /
UTC 2013-01-24 19:00:00        : ja:|¤«}µÞ!y|¿³}µÞ~ÓÐ$*;}úÖ / ja:D6|¹´¤@j}¤;U~ÃÈÉÅ}¬?kË|¹¿¸ª@8EP>l"&?M5$°éÉë~Ô6C|¬¯~ÄÖH`}ÈÎ[email protected]ÊNx0&ò|ºÐê~¦?M5$7]?MÓ}ÎIB>uò40A44UDj~¡"&:4F#?NH~}¬3Z·ÆH~?MËÊë9a9AN9Ø~¡ / entertainment programmes for 6 to 14 /  / 01:49:00 /
UTC 2013-01-24 20:49:00        : ja:~ÆÁÃÅ!A;~Be}òįë?M!9!A / ja:[email protected]=IJÎN"B&ÇÏ!"C/«¬4hD%ÃƤë!#!W0lÄ0lÄÎ@=IJÎN"B&Ç4hD%ë3+H/<T!"8&5f<T¿ÁÎ|¤ó¿Óå!<}òDL·ÆH`é¬AOê=P·¿?7·¤@=IJò>R2p·Þ¹!# / user defined /  / 00:02:00 /
UTC 2013-01-24 20:51:00        : ja:ªE75$ΪCNé» / ja: / undefined /  / 00:03:00 /
UTC 2013-01-24 20:54:00        : ja:|Õé÷åËå!<¹ / ja: / undefined /  / 00:06:00 /
UTC 2013-01-24 21:00:00        : ja:LZMK|ÉéÞ~¹!V}¢Ýäó!AAvë9q:]6u9A!W!!Bh~²OC$*;}úÖúØ / ja:!VLkÎ6u9AÇBgA\:w~¡>C}¨¿|Ïï¤5R!W"&F1;~4VBS}Ë=PH/¹ë~²AH}Ϊ5RMM!#8&=$=*N;Î>r7oÏÉÁéâL5;vËAwê=P¹³È!#0l?MA0ÈG'áéìë¿á!"1sF#~¨0KF#FX;K©}¬Avë / reserved for future use /  / 00:54:00 /
UTC 2013-01-24 21:54:00        : ja:|ÝÆÈ}ʸ«ó$*;}úÖ / ja:"&[email protected]>Ç4hD%ÃƤë|ÛÃÈ}Ê?M¿ÁÎ!"[email protected]|ØÎ!"½·ÆKvMhØÎ3hNOÇ¢ë!X|ÛÃ!Y}ÈÊ;~4Vò>R2p¹ëHVAH!#¢Ê¿ÎÈÃƪ­Î|ÛÃ}ÈÇ­ë>l=jÏɳǹ«~¿ / user defined /  / 00:06:00 /
UTC 2013-01-24 22:00:00        : ja:ÒßÄÎMrÁãó$*;}úÖúØ / ja:ÊóÈ~¶°:P¡2FLZ|Þê!"<+?H9M0F}Î9|HWBNA`ÇH~KFÈ<cµÎHk7mòBg8x3+~¡}ÎϺ¬!"Fs5\Î0-5:ËBg|ÑËï"&>>;3±ó¤Á!"ÑÑ}ÎAG4i / reserved for future use /  / 00:54:00 /
UTC 2013-01-24 22:54:00        : ja:~ÎÅ×Ó²³|¯í¹ / ja:­ç¦~±F|2?}¬¢Ã¿Î«!D|Ëå!<¹}¬!H·Ã«êJ,«ë!I!"½·Æ!H¢·¿¬8+¨ë!IòLsB+·Þ¹!#|¹Ý!<ÄËå!<¹}âK~:\ǹ~¡ / undefined /  / 00:51:00 /
UTC 2013-01-24 23:45:00        : ja:~ÍÂÓ|Ëå!<¹ / ja: / undefined /  / 00:05:00 /
UTC 2013-01-24 23:50:00        : ja:|í±}ßÄ!!|¶!&ï!<ëÉ / ja:!V|è!<íÃÑ2#CGÖí°N9!W:[email protected]}Ï~´}«9qL\Î|ɤÄ}ËFMF~!#À¬!"DL2a|ݤóÈ}Ïɳˢë«ï«éʤ8E>k!D"&|ë!<!&º!<¤ó}Ï!V¿é¤=.!WòL\;X¹~¡¡ / cartoons/puppets /  / 01:05:00 /
UTC 2013-01-25 00:55:00        : ja:$*;}úë|³Éâ7Y;k!!Bh~±OC}úÖ / ja:!VFf϶ïêÈ2r±¿~¡!W"&!V|³Éâ7Y;!!W}«é!"?7|·ê!<º}¬[email protected]~¡K\D#}Î|¨ê!<È7Y;k!&[email protected];;MO:~¨|ÞꦹMU~©}¬3X9;Ç5/³ë:3:YÊ;v7oòï¶ï¶2ZNoË2r­[email protected]«¹$*;}ýï / reserved for future use /  / 00:30:00 /
UTC 2013-01-25 01:25:00        : ja:2N|Í¿2&~ÔÖ / ja:A4¯?7·¤ª>P¤>^|ì!<¹!V2NÍ¿2&[email protected]!W}ÈÏ~¡¿!#2N}ä|êºà}ò;HÃÆ>Pï»ë!V2N|Í¿!W<+K}}Î7]?M¿Á¬|ì!<¹}Î35MWÈGz>P2N|Í¿}òªFO±¹ë~¡ / reserved for future use /  / 00:05:00 /
UTC 2013-01-25 01:30:00        : ja:|ÓÓÃÉìÃÉ!&ª}Ú|ì!<·çó!!~£°³ / ja:!VK\EvÎ6/µ!W"&ßóÊÈÀÿé!"@$3&ÀÃÆ5_¨ë / arts/culture (without music) /  / 00:30:00 /
UTC 2013-01-25 02:00:00        : ja:@d1`Î|ÆóÚ¹È!!~£±µ$*;}úÖ / ja:!V2?äé4kóǤëè¦Ç¢ê!W / reserved for future use /  / 00:30:00 /
UTC 2013-01-25 02:30:00        : ja:KMÏM'C#¬>/ʤ~ÎÅØÔ!!£°²$*;}úÖ / ja:!V|Ûâ²It!W"&?7}¿Êë!X;DG0ÊF|>o!Y¬Ï¸Þë~¡ / reserved for future use /  / 00:30:00 /
UTC 2013-01-25 03:00:00        : ja:Ǥê£!!²ÃÈ!# / ja: / reserved for future use /  / 00:05:00 /
UTC 2013-01-25 03:05:00        : ja:~íí­ÔÖ / ja: / sports /  / 00:10:00 /
UTC 2013-01-25 03:15:00        : ja:|ï!<ëɳ쯷çó´!<ëÉ / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-25 03:45:00        : ja:Di??0l!!|ÒÞéä=dNiÊÓ / ja:~²¶F|¨EZ©}Òë~²;~!A"&GPM%!&Di??0l}¬@$3&:G9bJv!&|¨Ùì¹È~¨¸¬¸´¸í©}Ç2?òA[¦Î«~¿ / reserved for future use /  / 00:02:00 /
UTC 2013-01-25 03:47:00        : ja:|Ëå!<¹Ð!<É / ja: / undefined /  / 00:43:00 /
UTC 2013-01-25 04:30:00        : ja:|·çÃ×~´³° / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-25 05:00:00        : ja:D+Î|¤Áª·~¡ / ja: / discussion/interview/debate /  / 00:15:00 /
UTC 2013-01-25 05:15:00        : ja:Aa|ºÐÃ~¡|ÊÞ}¿Þ´$*;}úØ / ja:KhD+Î:G?7|Ëå!<¹!"¹Ý!<Ä;f0lLL>pJs!":#F|}ÎE75$ÊɽÎF|ËCN꿤>pJsò!"|³óѯÈ}Ë~±µJ,}Ë|Õì÷å}˪EA¨·Þ¹!# / user defined /  / 00:15:00 /
UTC 2013-01-25 05:30:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:ßÎâó¿!!D+BSHVAHË;2>e$*;}ýî / user defined /  / 00:25:00 /
UTC 2013-01-25 05:55:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:@$ÎCfÎ=PMh;vËE\ê!&6C­!&Ha·ß!&4nÖ!";kD0<TÎ3'µóÈEy?HBgÎ!HßÎâó¿!I¬D+BSË;2>e~¡¡KhD+!"D6|ÆóÝ}Î|¸§Ãȳ!<¹¿!<>pJsHVAH~¡ / user defined /  / 02:35:00 /
UTC 2013-01-25 08:30:00        : ja:ÏÊÞë|Þ!<±ÃÈ$*;}úÖúØ / ja:Jké·ËLrN)Ä>pJsK~:\~¡=\}Î?):`ä@dIJ|ì·Ô!"7r9/}äª6bÎCN<1!"@83hÎN"5;ÊɬEP>l·Þ¹!#½·Æ=\Î|²¹È}ò>7¯!VÏÊÞë|«Õ§!W}Û« / reserved for future use /  / 01:25:00 /
UTC 2013-01-25 09:55:00        : ja:|×ê×ê / ja:D+4)~¡5-;v}«éÜ¿âÁ"&=\ÊOCBjò|éó­ó°}Ç>R2p / news magazine /  / 00:55:00 /
UTC 2013-01-25 10:50:00        : ja:=wÎ;[email protected]@~¡|Òë}Ýè~ÔÖ / ja:?<LkÇOCBjÎ!V|¢²}Ýè~ÔÖ!W}Î;PKeHVAH~¡¡}ªCkËEP>l!z / user defined /  / 00:03:00 /
UTC 2013-01-25 10:53:00        : ja:M_|Ðê;T>l / ja: / discussion/interview/debate /  / 00:07:00 /
UTC 2013-01-25 11:00:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:30:00 /
UTC 2013-01-25 11:30:00        : ja:ÒëªÓ~¡$*;}úÖ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:25:00 /
UTC 2013-01-25 11:55:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 01:55:00 /
UTC 2013-01-26 00:20:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-26 01:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-26 02:15:00        :  /  /  /  / 01:00:00 /
UTC 2013-01-26 05:30:00        :  /  /  /  / 00:15:00 /
UTC 2013-01-26 05:45:00        :  /  /  /  / 00:45:00 /
UTC 2013-01-26 06:45:00        :  /  /  /  / 00:45:00 /
UTC 2013-01-26 07:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-26 08:00:00        :  /  /  /  / 01:25:00 /
UTC 2013-01-26 09:25:00        :  /  /  /  / 02:20:00 /
UTC 2013-01-26 11:58:00        :  /  /  /  / 00:56:00 /
UTC 2013-01-26 12:54:00        :  /  /  /  / 01:00:00 /
UTC 2013-01-26 14:00:00        :  /  /  /  / 01:24:00 /
UTC 2013-01-26 15:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-26 16:00:00        :  /  /  /  / 01:00:00 /
UTC 2013-01-26 17:00:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-26 17:30:00        :  /  /  /  / 01:20:00 /
UTC 2013-01-26 19:00:00        :  /  /  /  / 01:54:00 /
UTC 2013-01-26 21:00:00        :  /  /  /  / 00:54:00 /
UTC 2013-01-26 22:00:00        :  /  /  /  / 01:24:00 /
UTC 2013-01-26 23:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 00:00:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 00:30:00        :  /  /  /  / 00:28:00 /
UTC 2013-01-27 01:58:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 02:28:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 02:58:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 03:28:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 05:30:00        :  /  /  /  / 00:45:00 /
UTC 2013-01-27 06:30:00        :  /  /  /  / 00:15:00 /
UTC 2013-01-27 07:00:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 07:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 08:00:00        :  /  /  /  / 01:54:00 /
UTC 2013-01-27 10:00:00        :  /  /  /  / 01:24:00 /
UTC 2013-01-27 11:45:00        :  /  /  /  / 01:09:00 /
UTC 2013-01-27 13:00:00        :  /  /  /  / 01:58:00 /
UTC 2013-01-27 14:58:00        :  /  /  /  / 01:02:00 /
UTC 2013-01-27 16:00:00        :  /  /  /  / 00:54:00 /
UTC 2013-01-27 17:00:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 18:00:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 18:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 21:00:00        :  /  /  /  / 00:54:00 /
UTC 2013-01-27 22:00:00        :  /  /  /  / 00:54:00 /
UTC 2013-01-27 23:00:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-27 23:30:00        :  /  /  /  / 00:30:00 /
UTC 2013-01-28 00:00:00        :  /  /  /  / 00:50:00 /
UTC 2013-01-28 00:50:00        :  /  /  /  / 02:05:00 /
UTC 2013-01-28 03:25:00        : ja:|¯í!<¸ó° / ja: /  /  / 00:05:00 /
UTC 2013-01-28 04:25:00        : ja:|ª!<×Ëó° / ja: /  /  / 00:05:00 /
UTC 2013-01-28 04:30:00        : ja:|Ëå!<¹Ð!<É / ja: / undefined /  / 00:30:00 /
UTC 2013-01-28 05:00:00        : ja:D+Î|¤Áª·~¡ / ja: / discussion/interview/debate /  / 00:15:00 /
UTC 2013-01-28 05:15:00        : ja:Aa|ºÐÃ~¡|ÊÞ}¿Þ´$*;}úØ / ja:KhD+Î:G?7|Ëå!<¹!"¹Ý!<Ä;f0lLL>pJs!":#F|}ÎE75$ÊɽÎF|ËCN꿤>pJsò!"|³óѯÈ}Ë~±µJ,}Ë|Õì÷å}˪EA¨·Þ¹!# / user defined /  / 00:15:00 /
UTC 2013-01-28 05:30:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:ßÎâó¿!!D+BSHVAHË;2>e$*;}ýî / user defined /  / 00:25:00 /
UTC 2013-01-28 05:55:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:@$ÎCfÎ=PMh;vËE\ê!&6C­!&Ha·ß!&4nÖ!";kD0<TÎ3'µóÈEy?HBgÎ!HßÎâó¿!I¬D+BSË;2>e~¡¡KhD+!"D6|ÆóÝ}Î|¸§Ãȳ!<¹¿!<>pJsHVAH~¡ / user defined /  / 02:35:00 /
UTC 2013-01-28 08:30:00        : ja:ÏÊÞë|Þ!<±ÃÈ$*;}úÖúØ / ja:Jké·ËLrN)Ä>pJsK~:\~¡=\}Î?):`ä@dIJ|ì·Ô!"7r9/}äª6bÎCN<1!"@83hÎN"5;ÊɬEP>l·Þ¹!#½·Æ=\Î|²¹È}ò>7¯!VÏÊÞë|«Õ§!W}Û« / reserved for future use /  / 01:25:00 /
UTC 2013-01-28 09:55:00        : ja:|×ê×ê / ja:D+4)~¡5-;v}«éÜ¿âÁ"&5$ËÊë|¢ì³ìE0DlD4::~¡ / news magazine /  / 00:55:00 /
UTC 2013-01-28 10:50:00        : ja:èêÉê|Þ!<±ÃÈ / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-28 11:20:00        : ja:é¤èó|ÁãóÍë~¦M_|Ðê;T>l / ja: / discussion/interview/debate /  / 00:10:00 /
UTC 2013-01-28 11:30:00        : ja:ÒëªÓ~¡$*;}úÖ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:25:00 /
UTC 2013-01-28 11:55:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 01:55:00 /
UTC 2013-01-28 13:50:00        : ja:´´|Í¿~¡|¹Þ!<Èé¤Õ~ÔÖ$*;}úÖ / ja:0U30ÈCNéʤ!VJ]81!W¤Ä¤ÆÎ>pJsò!"|ÉéÞ;EN)}ÆÆï«ê乯ªEA¨·Þ¹!# / user defined /  / 00:05:00 /
UTC 2013-01-28 13:55:00        : ja:|ÉéÞ}Î8w!V?7;2<T!W!!Bh~µOC$*;}úêúÖ / ja:!VMN2[;R20ÎE90w!W"&Ho32<TÎJw;R~¨86EDH~;^;R©}¬B-HK¯DLÃƤ¿MN2[;RE9!#2C2l~¨0$It42©}ÏG%?1·Æ¤ëE90wÎ>[email protected]«é!"Jw;RÎ?4>pò¿°ê4s»ë!# / reserved for future use /  / 01:00:00 /
UTC 2013-01-28 14:55:00        : ja:ÁÁóפפ / ja:[email protected]>L\@~Ç=\Î|Ëå!<¹}ò@>Î!y0u~¦@PED}¬[email protected]¶³Ð!&Êëß;[email protected]"&9TÃÆ=iáÆï«ë~¡|ê¢ë@$3&;3CfCf7Q"&9b9;@8}ò¿à±óA4NOÇ1~1g"&J!Eg|¢ÊCO85L>;:}ò2NǪFO± / reserved for future use /  / 02:50:00 /
UTC 2013-01-28 17:45:00        : ja:~Î|¹¿$*;}úÖ / ja:[email protected]@¬ªFO±¹ëM<J}ÎBg7?JsF;HVAH!#E0Dl<h:`·¿~ÖÔÒ}È!"«æ¤È³íË<j¬FO¯|¹¿¸ª[email protected]}Ç!"Fq·¤@/<#!&7P:Q!&<R2qLdBjâ!"|ÐÃÁê}ï«êÞ¹!# / reserved for future use /  / 00:30:00 /
UTC 2013-01-28 18:15:00        : ja:~ÖÏÉÃÅ$*;}úÖ / ja:"&CO0hËL)Ce·¿|Ëå!<¹}òªFO±·Þ¹"&!VJ0XpK\J^!W!VFCL?D4::HI!!|ÞëÁç¦!W}ÊÉ4k2h|ꯨ¹È!&>pJs}ò<uIUCf~¡"&}ßóÊ~äåE75$!&}¢Ê¿Î?H6aÊ<L??Jg=8Cf~¡ / undefined /  / 00:45:00 /
UTC 2013-01-28 19:00:00        : ja:?eLn??5*ÎKbK!Î|ì¹Èéó$*;}úÖ / ja:!VG_ED|ÇÑ!<È}ÞÄê~¡!W / reserved for future use /  / 01:00:00 /
UTC 2013-01-28 20:00:00        : ja:|ÏóÁç¦~¶!A7Y;kD#[email protected]!A!!Bh³OC$*;}úÖ / ja:!V~¸G/A0}Î;XLf!D;&?MHHò«Ð¦D.0e<TÎHkL)!W"&L$2r7h;[email protected]ËF0¯[email protected]ò?eBt0e;U¬K832~¡2L}¿·Æ!"½ÎM}M3ÈÏ~¿"&:4!9LZB"G72p!!Hf2E0&L$!!>[email protected],1Y!!J!;[email protected]?<#$*;}úô / reserved for future use /  / 00:54:00 /
UTC 2013-01-28 20:54:00        : ja:|Õé÷åËå!<¹ / ja: / undefined /  / 00:06:00 /
UTC 2013-01-28 21:00:00        : ja:7nMK|´!<ëÇó!VA\::;X4x41!!?e>k}µä!W$*;}úÛúÖ / ja:!AA4ÆÎ@UG$Ï!";d¬<hêÞ¹~¡!A;&}µì¿@xF~A\::0w¬;D·¿5?OGÎ6b!D!DA\::>pJsÎN.=P~¡¡H~?M}¹®ë4IM}41¬|ªä¸7:;v}Ë|Àá}À·O"H/~¡¿!!<g1iº>.CS1I;R / reserved for future use /  / 01:54:00 /
UTC 2013-01-28 22:54:00        : ja:~ÎÅ×Ó²³|¯í¹ / ja:­ç¦~±F|2?}¬¢Ã¿Î«!D|Ëå!<¹}¬!H·Ã«êJ,«ë!I!"½·Æ!H¢·¿¬8+¨ë!IòLsB+·Þ¹!#|¹Ý!<ÄËå!<¹}âK~:\ǹ~¡ / undefined /  / 00:51:00 /
UTC 2013-01-28 23:45:00        : ja:~ÍÂÓ|Ëå!<¹ / ja: / undefined /  / 00:05:00 /
UTC 2013-01-28 23:50:00        : ja:DK2w~¡[email protected]@P2HEE;kBf$*;}úÖ / ja:!VÊËò­¯Íó!WÎ|²¹È}Ï1J0fBg!#|¯¤º³!<Ê!<}Ï|êËå!<¢ë}·Æ>^6b|¢Ã×~¡ / reserved for future use /  / 01:05:00 /
UTC 2013-01-29 00:55:00        : ja:~ÍÕÓÉÃ!!ÅÄÇÅ«ÏóáëáÓôùìå / ja:~ÊÕÎ!!ÓËÙ!!×ÁÌËÅÒ¨Ó© / sports /  / 00:30:00 /
UTC 2013-01-29 01:25:00        : ja:~ÍÕÓÉÃ!!ÅÄÇÅ«Îåøô!!Óôùìå / ja:~²°°·G/}Ë:[email protected]·¿!!~ÊÕÎ!!ÓËÙ!!×ÁÌËÅÒ¨Ó©}¬EP>l~¡¡}ª3Z·ßË~¡ / sports /  / 00:10:00 /
UTC 2013-01-29 01:35:00        : ja:|¬óÐ~ÔÖ[email protected]}È9u!A / ja:"&~Ê|ê!<°!&¬óÐBg:e}Î:G?7>pJsòªFO±·Þ¹~¡ / movie/drama /  / 00:15:00 /
UTC 2013-01-29 01:50:00        : ja:=54)~ÅØÉÌÅ / ja:~ÅØÉÌÅH/}Î;}Á9~ß4k2h¬Ä¤Ë;OF0~¡99}Ë;0BeL\~ÊÓÂ}é~ÖÂÁ=P?H|¢!<Æ£¹È}«é<[email protected]$BeÎBg7?|æËÃÈ}ÞÇ:G?7>pJsK~:\~¡ / tennis/squash /  / 00:30:00 /
UTC 2013-01-29 02:20:00        : ja:µ¯éAqÎ|ÚÃÈ}ÊH`=w!!~£±¶ / ja:!VºÃÈ!"9%­Ç·¿!D!D!W / arts/culture (without music) /  / 00:30:00 /
UTC 2013-01-29 02:50:00        : ja:ßÊß±!!¿À¤Þ!!~£°´ / ja:!V³Î@D¤2F6uÎ2<ÇCKÏ[email protected]òN.¹!W / arts/culture (without music) /  / 00:30:00 /
UTC 2013-01-29 03:20:00        : ja:~íí­ÔÖ / ja: / sports /  / 00:10:00 /
UTC 2013-01-29 03:30:00        : ja:|Ëå!<¹Ð!<É / ja: / undefined /  / 01:00:00 /
UTC 2013-01-29 04:30:00        : ja:|·çÃ×~´³° / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-29 05:00:00        : ja:D+Î|¤Áª·~¡ / ja: / discussion/interview/debate /  / 00:15:00 /
UTC 2013-01-29 05:15:00        : ja:Aa|ºÐÃ~¡|ÊÞ}¿Þ´$*;}úØ / ja:KhD+Î:G?7|Ëå!<¹!"¹Ý!<Ä;f0lLL>pJs!":#F|}ÎE75$ÊɽÎF|ËCN꿤>pJsò!"|³óѯÈ}Ë~±µJ,}Ë|Õì÷å}˪EA¨·Þ¹!# / user defined /  / 00:15:00 /
UTC 2013-01-29 05:30:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:ßÎâó¿!!D+BSHVAHË;2>e$*;}ýî / user defined /  / 00:25:00 /
UTC 2013-01-29 05:55:00        : ja:ßÎâó¿ÎD+|ºÐÃ~¡$*;}úØ / ja:@$ÎCfÎ=PMh;vËE\ê!&6C­!&Ha·ß!&4nÖ!";kD0<TÎ3'µóÈEy?HBgÎ!HßÎâó¿!I¬D+BSË;2>e~¡¡KhD+!"D6|ÆóÝ}Î|¸§Ãȳ!<¹¿!<>pJsHVAH~¡ / user defined /  / 02:35:00 /
UTC 2013-01-29 08:30:00        : ja:ÏÊÞë|Þ!<±ÃÈ$*;}úÖúØ / ja:Jké·ËLrN)Ä>pJsK~:\~¡=\}Î?):`ä@dIJ|ì·Ô!"7r9/}äª6bÎCN<1!"@83hÎN"5;ÊɬEP>l·Þ¹!#½·Æ=\Î|²¹È}ò>7¯!VÏÊÞë|«Õ§!W}Û« / reserved for future use /  / 01:25:00 /
UTC 2013-01-29 09:55:00        : ja:|×ê×ê / ja:D+4)~¡5-;v}«éÜ¿âÁ"&=54)|ìÇ£!<CcOC"&}ª[email protected]>pJs / news magazine /  / 00:55:00 /
UTC 2013-01-29 10:50:00        : ja:èêÉê|Þ!<±ÃÈ / ja: / discussion/interview/debate /  / 00:30:00 /
UTC 2013-01-29 11:20:00        : ja:é¤èó|ÁãóÍë~¦M_|Ðê;T>l / ja: / discussion/interview/debate /  / 00:10:00 /
UTC 2013-01-29 11:30:00        : ja:ÒëªÓ~¡$*;}úÖ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 00:25:00 /
UTC 2013-01-29 11:55:00        : ja:ÒëªÓ~¡ / ja:6H3&=i~¡Ht}Ó=P¹?7J9Ç@/<#!";v7o!"7]G=!"|¹Ý!<Ä!"5$}ËÊë:G?7>pJsòM>¹È³íʯ´>R2p·Þ¹~¡:G?7}ÎE75$>pJs!"µéËÏ|Ëå!<¹}â~¡ / news/current affairs /  / 01:55:00 /
UTC 2013-01-29 13:50:00        : ja:´´|Í¿~¡|¯Ã¯~ÔÖ$*;}úÖ / ja:"&!V|¯Ã¯~ÔÖ!W}ÏKhF|ÎNAM}¬3Z·¯Êëª=u±HVAHǹ!# / reserved for future use /  / 00:05:00 /
UTC 2013-01-29 13:55:00        : ja:|ÉéÞ}Î8w!V?7;2<T!W!!Bh~¶OC$*;}úêúÖ / ja:!VK]Lu2HÎM'!W"&0$It42!!9uLZ|ᤵ!!8~0fM}!!9BC<=_J?!!Ap4"L1Be!!C+86>O2p!!86EDH~;^;R!!;01:M'OB$*;}úô / reserved for future use /  / 01:00:00 /
UTC 2013-01-29 14:55:00        : ja:ÁÁóפפ / ja:[email protected]>L\@~Ç=\Î|Ëå!<¹}ò@>Î!y0u~¦@PED}¬[email protected]|í¶ó!&7r!&Bt>>G<[email protected]"&9T}ÃÆ=iáÆï«ë|ê¢ë@$3&;3CfCf7Q"&?{}Áãó1Q8lÏ@d9%D4Bg:eÇF;0FFb·è"&>"Î5;¬@8­¿0oIJ / reserved for future use /  / 02:50:00 /
UTC 2013-01-29 17:45:00        : ja:~Î|¹¿$*;}úÖ / ja:[email protected]@¬ªFO±¹ëM<J}ÎBg7?JsF;HVAH!#E0Dl<h:`·¿~ÖÔÒ}È!"«æ¤È³íË<j¬FO¯|¹¿¸ª[email protected]}Ç!"Fq·¤@/<#!&7P:Q!&<R2qLdBjâ!"|ÐÃÁê}ï«êÞ¹!# / reserved for future use /  / 00:30:00 /
UTC 2013-01-29 18:15:00        : ja:~ÖÏÉÃÅ$*;}úÖ / ja:"&CO0hËL)Ce·¿|Ëå!<¹}òªFO±·Þ¹"&!VJ0XpK\J^!W!VFCL?D4::HI!!|ÞëÁç¦!W}ÊÉ4k2h|ꯨ¹È!&>pJs}ò<uIUCf~¡"&}ßóÊ~äåE75$!&}¢Ê¿Î?H6aÊ<L??Jg=8Cf~¡ / undefined /  / 00:45:00 /
UTC 2013-01-29 19:00:00        : ja:âÆâÆ|ʤóƣʤó$*;}úÖ / ja:|ʤóƣʤó}È:G6/|µÝ!<¿!<}¬!"ª8+9g¤Û«??7uËNx0&Ë<hêAHàCK=wò|Ðï¢Ã×}¹ë!H|¬ÁNx0&1~1gÐé¨Æ£!I~¡}½ì¬!XâÆâÆ|ʤóƣʤó!Y~¡!! / user defined /  / 00:56:00 /
UTC 2013-01-29 19:56:00        : ja:Gz>P3X1`|Ê»ÐÊ!Aë~¡$*;}úÖ / ja:!V|äë5$}΢ë<c<Tè!"Çdz¤ä!AÃ~¡¡!WFH<+}Î|ÍÃÈï!<¯}ÇF|K\A49qάóÐÃƤë<c<T¿ÁÎ!V¤Þ!WòE0Dl<h:`~¡"&Gz>PLdBj!!Cf;3M%GO!!|ÞꦹMU!!;X86h=G5$*;}úô / user defined /  / 00:58:00 /
UTC 2013-01-29 20:54:00        : ja:|Õé÷åËå!<¹ / ja: / undefined /  / 00:06:00 /
UTC 2013-01-29 21:00:00        : ja:|êó«!<ó~ÓÐ$*;}úÖ / ja:!V7]?MÎ!&7]?MËèë!&7]?MοáÎHVAH!W / entertainment programmes for 10 to 16 /  / 01:48:00 /
UTC 2013-01-29 22:48:00        : ja:|¹­Þ}À|¸ãë¸ãë / ja: / reserved for future use /  / 00:06:00 /
UTC 2013-01-29 22:54:00        : ja:~ÎÅ×Ó²³|¯í¹ / ja:­ç¦~±F|2?}¬¢Ã¿Î«!D|Ëå!<¹}¬!H·Ã«êJ,«ë!I!"½·Æ!H¢·¿¬8+¨ë!IòLsB+·Þ¹!#|¹Ý!<ÄËå!<¹}âK~:\ǹ~¡ / undefined /  / 00:51:00 /
UTC 2013-01-29 23:45:00        : ja:~ÍÂÓ|Ëå!<¹ / ja: / undefined /  / 00:05:00 /
UTC 2013-01-29 23:50:00        : ja:´Ö´Ö$*;}úÖ / ja:IMED2m8y!"ElLn9,<#¬!V8^J,8^J,!WÎN)>lÇ|í±}ò¹ëHVAH"&Bg9%I>~¡|³íñ4k2hBh~¶CF!AElBg:eJT!AH,8M|ÎN$}ä[email protected]%ÊÉÎL>E9B3!9EP>l~¡@dIJ|³íñ}ËIMÁãó[email protected];?~¡¡ / reserved for future use /  / 01:05:00 /
Interestingly, the new MPC-HC 1.6.6 which uses the same MediaInfo version 0.7.62 locks up when you go Shift-F10 into file properties and try to look at the MediaInfo tab. I got the above by using MPC-BE 1.0.3 which does not lock up. The file plays fine in both as long as you don't MediaInfo it.
Fenzor
Re: Possible MediaInfo Bug vs Bad File?
Post by Fenzor » Fri Apr 12, 2013 9:37 am
What does the "debug.log"-file say?
The file should be in the folder where Universal Media Server is installed.
