After update UMS crashes
rmanal
Post by rmanal » Sun Jul 31, 2016 7:17 pm
i'm using XP and i have updated java to release 8. Then I have discovered:
1/ Java does not support anymore XP
2/ UMS has two differents installs
Then I have updated UMS with java 8 and when trying to launch I get the message "Application can not start correctly (0xc0000142) ....
I have then try to desinstall, reinstall, go bacj to Java 7 and UMS Java 7, I have even tried to reinstall my UMS working version (5.5.0) but since I'm unable to make it works, even with Java 7
Can anyone help me?
Thx
Rmanal
rmanal
Re: After update UMS crashes
Post by rmanal » Sat Aug 06, 2016 7:11 pm
No idea?
rmanal
Post by rmanal » Sat Sep 03, 2016 8:09 pm
up
erick diangilis
Post by erick diangilis » Sun Sep 04, 2016 1:32 am
hi i guess the problem is because Windows xp is very old so new softwares are not supporting this system operation anymore the only way to fix your problem is to upgrade the Windows at least to 7 or 8 in case your computer can't handle the newest 10. yes there are two options avaliable for the universal media server one is java 7 compatible and the other one is java 8 compatible, but you don't have to install both just one one them that your system supports it. ;)
