cant watch shared video files
always have unsupported video format message
i have vox smart tv
i have vox smart tv
- (58.6 KiB) Downloaded 409 times
Re: cant watch shared video files
It seems that your renderer does not get recognized.
Until we get a render config up and runnning for your TV you can try to play files from the #--transocde--# folder instead
OR you could try forcing some of the other profiles.
On General Configuration tab, you can choose a renderer from the list, and then tick on "Force default renderer"
I would choose Samsung JU6400, but you can try others too.
While somebody else works on a new renderer conf, would you mind using a custom build that I'm working on?
Binary https://drive.google.com/open?id=0B6j7C ... TNKTm5ra00
Source https://github.com/atamariya/UniversalM ... r/tree/dev
Feature details https://github.com/UniversalMediaServer ... r/pull/987
Or try that one:
I could be wrong, but i don't think you'll return any feedback if it's work... That's could be nice though
