Java 7 or 8?
theoldfarter
Java 7 or 8?
Post by theoldfarter »
Greetings
I have Windows 10 (64 bit) and I see that UMS is available in two versions of java, seven and eight. Which should I use and why?
renehoss
Re: Java 7 or 8?
Post by renehoss »
I suppose if you have a Java version 7 installed you use the UMS-java7 version,
and if you have Java version 8 installed you use the UMS-java8 version.
You can check the installed version of Java through the Control Panel -> Java -> General | About.
Version 8.121 is the latest common version of Java.
theoldfarter
Re: Java 7 or 8?
Thanks for your reply. I have the latest Java 8.
I get the notification when there is a new release of UMS but the link takes me to the Java 7 version.
Are you able to point me to where I can set up a notification that includes the link to the Java 8 version?
I have had a look around but no luck. Maybe I missed something.
About Java 7 vs 8. Do you know the differences?
I will Google it but the info I may find, or not, may not tell me much.
Have you any knowledge on it?
renehoss
Re: Java 7 or 8?
Post by renehoss »
Java version 8 is the latest and will have the longest support.
You can find UMS-java8 when you click the "down arrow" on the right side next to the Unix pinguin:
then a submenu will be revealed, it is kind of hidden... :P
Re: Java 7 or 8?
There aren't any important differences between them. Java 8 is faster but not by much and not with operations we use a lot :)
theoldfarter
Re: Java 7 or 8?
renehoss wrote:Java version 8 is the latest and will have the longest support.
Found the link. As per usual, it was right under my nose. lol
Thanks.
theoldfarter
Re: Java 7 or 8?
SubJunk wrote:There aren't any important differences between them. Java 8 is faster but not by much and not with operations we use a lot :)
Thanks for that information. As I already have Java 8 installed, I will just keep downloading that version. :)
