ISO and VOB files are not displaying in Universal Media Server
Re: ISO and VOB files are not displaying in Universal Media Server
Yes, 6.5.3 works. I will update to most recent and get back to you
Thank you for you feedback
So that's mean that could be a bug introduced with the 6.6.0 version.
If you can post a log while playing DVD ISO with the 6.5.3 version, or 7.0.0a1, that should help us to fix it before new UMS version arise.
That user would be me...Sami32 wrote:Thank you for having take time to confirm it
But i suspect that the next version will not work as you expect...
So if you get time, please, provide a new full trace log with UMS 7.0.0a1 version.
I think i remember an other user said that this issue begin with 6.6.0, meaning that the 6.5.3 version should work as well.
Version 6.5.3 works OK, version 6.6.0 has the problems and version 7.0.0a1 is again OK.
Could you try these 2 new UMS builds ?
Backup you original ums.jar in your UMS program folder and place and rename the new one ums.jar:
https://we.tl/ofEHcPNq19
Please, report which one worked (n°1 or n°2)
#1 works, #2 doesn't
@clive Thank you very much for you testing
As i'm really not familiar with DVD ISO your help is welcome, to avoid that this bug will stay in the next versions.
When you'll have some time i'll appreciate 2 more testings:
https://we.tl/yielQLS6IO
I suspect that these 2 builds should work. That would mean that this issue only affect PS3, and that we now identified the commit that introduced that bug. Other way, one more test will be need.
Thank you very much for your help
I think this issue come from a simple line of code that was modified in this commit.
This build contain what i consider the faulty commit and should not work:
https://we.tl/qOi08Vo8AQ
