UTF-8 supported ?
marito
UTF-8 supported ?
Post by marito »
My question is quite simple : does UMS support UTF-8 ?
And if it does can someone please tell me how to configure UMS to do so ??
Please........
Marito
squadjot
Re: UTF-8 supported ?
Post by squadjot »
If you mean subtitles then yes.
If you are having problems displaying the correct then follow the Problem Reporting Guidelines
That way the developers can see what exactly is going on.
marito
Post by marito »
@squadjot
I meant subs ....yes.
Thanks for the guidance.
Here is the log...hopefully it's allright.
Sami32
Post by Sami32 »
Hello marito,
your log wasn't posted. You can only post the link from a registration and ads free website if you get issue , or you can paste the full copy of your log here and use the "code" balise.
That's said, before doing that, perhaps reading our Wiki (click on the green link found in my signature) will explain you how to configurate it correctly.
Hoping that helped.
