Can't pause/play some videos
LuciferIAm
Post by LuciferIAm »
I stream pretty much all my videos to my Xbox One using UMS. Recently, not sure if its UMS or Xbox's fault but playing anime works fine but if I pause it will crash after about a minute of resuming. Animes are typically in MKV, I rarely use transcode to play them, typically work in normal folder. Stranger still is that any other MKVs - movies/shows - pause and resume without issue. Any advice would be appreciated. I feel like it might be Xboxs fault (some update to the Media Player app) but I don't know.
Note: I have UMS 6.6.0
thanks
squadjot
Re: Can't pause/play some videos
Post by squadjot »
A good tip is to follow the Problem Reporting Guidelines
That way the developers can see what exactly is going on.
LuciferIAm
Sami32
Post by Sami32 »
Hello LuciferIAm,
Your very partial log is not useful...
You can always try to revert back your XBOX firmware and see if things return back, as i don't own a XBOX or even your log that's all i can say.
