Chromecast problem
Chromecast problem
Hello, i'm using chromecast 2 with UMS 6.6.0 and BubbleUPnP 2.8.8 on Android for playing the files from the server on my chromecast renderer. The problem is that when i play files and try to time seek (jump to certain position in the movie) the movie freeze and nothing happens and i have to exit the bubble app and launch it again. Thank you for your time and keep up the good work.
Re: Chromecast problem
Please, follow the forum rules write in red above your post
This wasnt reffered to a bug that's why i didnt made a report using the trace thingy. I just wanted to know if there is a known incompatibility between UMS and Chromecast 2 and maybe BubbleUPnP. Maybe it was a setting that u had to make it work. I will make a report with trace when i will have time.
We should have disabled Chromacast by default, imho. We use an external library that should work fine, but our implementation is flawed and freeze until the end of the playing. The developper that made it is not active anymore and we don't own a Chromecast, so that doesn't really help...
So, yes, we need log for everything we don't own, and as a general rules for every report, as every case is different and rarely obvious as some users think.
No worry, feel free to report anytime.
