UMS Over Powerline Network
Zero3K
Post by Zero3K » Wed Jun 05, 2013 3:49 pm
Is there any way to improve the speed of it so it won't stutter as often or not at all?
geaves
Re: UMS Over Powerline Network
Post by geaves » Wed Jun 05, 2013 6:12 pm
In one simple word....no Powerline Ethernet is dependant upon the type of wiring within a house/building, it can also be affected by noise/interference. If you're experiencing problems it 'might' be the powerline adaptor itself that's breaking down if your wiring is up to date.
Zero3K
Post by Zero3K » Wed Jun 05, 2013 6:27 pm
So, I take it as there's no way to have it not be uploading at random speeds then?
geaves
Post by geaves » Wed Jun 05, 2013 6:41 pm
Zero3K wrote:So, I take it as there's no way to have it not be uploading at random speeds then?
No afraid not....as I say the other option is to try a another powerline, there is a thread on here, probably on page 2 someone having a similar problem, the solution was to change the powerline and the switch.
