GPU Acceleration with MEncoder
Zero3K
Post by Zero3K » Thu Jun 06, 2013 3:07 pm
Is there any way to get it to work without having to have CoreAVC installed?
geaves
Re: GPU Acceleration with MEncoder
Post by geaves » Fri Jun 07, 2013 9:57 pm
Zero3K wrote:Is there any way to get it to work without having to have CoreAVC installed?
You should be able to by adding a command line switch under Transocde Settings/Mencoder, you may have to install additional codecs....best thing is to google information regarding command line switches specific to your set up and see what there is......and bear in mind it may take a few experimental settings before you get it right.
