UMS Closing when trying to add folders * SOLVED *
Billbogz9x8
Post by Billbogz9x8 »
Hello Everyone ,
Ive been using UMS for a long time now but something weird has just started happening
i got a SSD today and reinstalled Windows 10 and what not then time came to do UMS
I downloaded the newest one , went to install it ( Clean Install ) everything went well
up to the point where i try to add folders ... as soon as i click add directory the whole program closes
now i tried shutting down the computer reinstalling .. installing older versions and nothing works same thing
just closes out java is updated i dont know what else i could do at this point Please help
Thanks..
Re: UMS Closing when trying to add folders * Please help*
Please follow the instructions in red above.
Billbogz9x8
Wow im sorry ill do it now
Since UMS crashed/closes when you click add folders, you won't be able to follow the instructions exactly. Follow the instructions until you reproduce the error and UMS closes, then start UMS again, go directly to the "Logs" tab and continue with "Pack debug files".
Billbogz9x8
I am trying to zip the files but as if its gonna ask where to save it it closes out like it dose when i try to add folders
even when i go to alternate video cover art folder as if i'm going to add and such folders it closes before anything could happen
for some reason i think as soon as it tries to find a directory of any kinda the whole program closes ... i'm sorry i cant get a log of it
only thing i could get is the log and copy it
DEBUG 2017-06-10 22:51:56.465 [main] Default logfile folder set to: C:\ProgramData\UMS
WARN 2017-06-10 22:51:56.466 [main] Could not rename "C:\ProgramData\UMS\debug.log" to "C:\ProgramData\UMS\debug.log.prev"
DEBUG 2017-06-10 22:51:56.592 [main] LogBack started with configuration file: C:\Program Files (x86)\Universal Media Server\logback.xml
DEBUG 2017-06-10 22:51:56.608 [main] Sat Jun 10 22:51:56 EDT 2017
DEBUG 2017-06-10 22:51:56.608 [main] Reading cred.path: "C:\ProgramData\UMS\UMS.cred" (default: "")
DEBUG 2017-06-10 22:51:56.850 [main] Writing PID: 6100
DEBUG 2017-06-10 22:51:56.857 [main]
INFO 2017-06-10 22:51:56.857 [main] Starting Universal Media Server 6.7.1
INFO 2017-06-10 22:51:56.858 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 2017-06-10 22:51:56.858 [main] http://www.universalmediaserver.com
INFO 2017-06-10 22:51:56.858 [main] Build: 7c737389d (2017-06-11)
INFO 2017-06-10 22:51:56.858 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.8.0_131 64-bit by Oracle Corporation
INFO 2017-06-10 22:51:56.859 [main] OS: Windows 10 64-bit 10.0
INFO 2017-06-10 22:51:56.859 [main] Encoding: UTF-8
INFO 2017-06-10 22:51:56.859 [main] Memory: 1138 MB
INFO 2017-06-10 22:51:56.867 [main] Language: English (United States)
INFO 2017-06-10 22:51:56.867 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO 2017-06-10 22:51:56.876 [main] Temporary directory: C:\Users\Willi\AppData\Local\Temp\UMS
INFO 2017-06-10 22:51:56.878 [main] Logging configuration file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO 2017-06-10 22:51:56.878 [main] Logfile: C:\ProgramData\UMS\debug.log
INFO 2017-06-10 22:51:56.878 [main] Profile directory: C:\ProgramData\UMS
INFO 2017-06-10 22:51:56.880 [main] Profile directory permissions: drwx
INFO 2017-06-10 22:51:56.880 [main] Profile configuration file: C:\ProgramData\UMS\UMS.conf
INFO 2017-06-10 22:51:56.881 [main] Profile configuration file permissions: -rwx
INFO 2017-06-10 22:51:56.882 [main] Profile name: DESKTOP-V9CFS58
DEBUG 2017-06-10 22:51:56.883 [main] Reading web_conf: "C:\ProgramData\UMS\WEB.conf" (previous: null, default: "C:\ProgramData\UMS\WEB.conf")
INFO 2017-06-10 22:51:56.883 [main] Web configuration file: C:\ProgramData\UMS\WEB.conf
INFO 2017-06-10 22:51:56.884 [main] Web configuration file permissions: -rwx
INFO 2017-06-10 22:51:56.885 [main]
DEBUG 2017-06-10 22:51:56.891 [main] Using database URL: jdbc:h2:C:\ProgramData\UMS\database\medias
INFO 2017-06-10 22:51:56.891 [main] Using database located at: C:\ProgramData\UMS\database
DEBUG 2017-06-10 22:51:57.148 [main] Database file count: 0
DEBUG 2017-06-10 22:51:57.148 [main] Database version: 8
DEBUG 2017-06-10 22:51:57.148 [main] Starting check of database tables
DEBUG 2017-06-10 22:51:57.164 [main] Reading run_wizard: false (default: true)
DEBUG 2017-06-10 22:51:57.188 [main] Starting SleepManager
DEBUG 2017-06-10 22:51:57.191 [main] Reading hide_advanced_options: false (default: true)
DEBUG 2017-06-10 22:51:57.973 [main] Reading automatic_maximum_bitrate: true (default: false)
DEBUG 2017-06-10 22:51:58.549 [main] Reading screen_size: "1366x768" (default: "-1x-1")
DEBUG 2017-06-10 22:51:58.549 [main] Reading window_geometry: "x=183,y=9,width=1000,height=750" (default: "x=-1,y=-1,width=1000,height=750")
DEBUG 2017-06-10 22:51:59.008 [main] Checking dbgpack property in UMS.conf
DEBUG 2017-06-10 22:51:59.008 [main] Reading uuid: "28c4bbdd-5d79-4701-aae4-24189bc5d515" (default: null)
INFO 2017-06-10 22:51:59.008 [main] Using the following UUID configured in UMS.conf: 28c4bbdd-5d79-4701-aae4-24189bc5d515
DEBUG 2017-06-10 22:51:59.008 [main] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2017-06-10 22:51:59.008 [main] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2017-06-10 22:51:59.008 [main] adding C:\ProgramData\UMS\debug.log.prev
DEBUG 2017-06-10 22:51:59.055 [main] Added file watch at C:\ProgramData\UMS: C:\\ProgramData\\UMS\\UMS.cred
INFO 2017-06-10 22:51:59.065 [main] Loading MediaInfo library
INFO 2017-06-10 22:51:59.078 [main] Loaded MediaInfoLib - v0.7.96
DEBUG 2017-06-10 22:51:59.079 [main] Option 'File_TestContinuousFileNames' is set to: 0
DEBUG 2017-06-10 22:51:59.079 [main] Option 'ParseSpeed' is set to: 0.000
INFO 2017-06-10 22:51:59.082 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
DEBUG 2017-06-10 22:51:59.087 [main] Added file watch at renderers: renderers\\AnyCast.conf
DEBUG 2017-06-10 22:51:59.090 [main] Added file watch at renderers: renderers\\Apple-iDevice-AirPlayer.conf
DEBUG 2017-06-10 22:51:59.091 [main] Added file watch at renderers: renderers\\Apple-iDevice-VLC.conf
DEBUG 2017-06-10 22:51:59.091 [main] Added file watch at renderers: renderers\\Apple-iDevice-VLC32bit.conf
DEBUG 2017-06-10 22:51:59.091 [main] Added file watch at renderers: renderers\\Apple-iDevice.conf
DEBUG 2017-06-10 22:51:59.107 [main] Added file watch at renderers: renderers\\Apple-TV-VLC.conf
DEBUG 2017-06-10 22:51:59.107 [main] Added file watch at renderers: renderers\\BlackBerry-PlayBook-KalemSoftMP.conf
DEBUG 2017-06-10 22:51:59.107 [main] Added file watch at renderers: renderers\\CambridgeAudio-AzurBD.conf
DEBUG 2017-06-10 22:51:59.107 [main] Added file watch at renderers: renderers\\DefaultRenderer.conf
DEBUG 2017-06-10 22:51:59.122 [main] Added file watch at renderers: renderers\\DirecTV.conf
DEBUG 2017-06-10 22:51:59.122 [main] Added file watch at renderers: renderers\\DLink-DSM510.conf
DEBUG 2017-06-10 22:51:59.122 [main] Added file watch at renderers: renderers\\Free-Freebox.conf
DEBUG 2017-06-10 22:51:59.129 [main] Added file watch at renderers: renderers\\Freecom-MusicPal.conf
DEBUG 2017-06-10 22:51:59.133 [main] Added file watch at renderers: renderers\\Google-Android-BubbleUPnP-MXPlayer.conf
DEBUG 2017-06-10 22:51:59.138 [main] Added file watch at renderers: renderers\\Google-Android-Chromecast.conf
DEBUG 2017-06-10 22:51:59.141 [main] Added file watch at renderers: renderers\\Google-Android.conf
DEBUG 2017-06-10 22:51:59.143 [main] Added file watch at renderers: renderers\\Google-ChromecastUltra.conf
DEBUG 2017-06-10 22:51:59.146 [main] Added file watch at renderers: renderers\\Hama-IR320.conf
DEBUG 2017-06-10 22:51:59.149 [main] Added file watch at renderers: renderers\\Hisense-K680.conf
DEBUG 2017-06-10 22:51:59.154 [main] Added file watch at renderers: renderers\\Kodi.conf
DEBUG 2017-06-10 22:51:59.158 [main] Added file watch at renderers: renderers\\LG-BP.conf
DEBUG 2017-06-10 22:51:59.161 [main] Added file watch at renderers: renderers\\LG-BP550.conf
DEBUG 2017-06-10 22:51:59.164 [main] Added file watch at renderers: renderers\\LG-EG910V.conf
DEBUG 2017-06-10 22:51:59.167 [main] Added file watch at renderers: renderers\\LG-LA6200.conf
DEBUG 2017-06-10 22:51:59.169 [main] Added file watch at renderers: renderers\\LG-LA644V.conf
DEBUG 2017-06-10 22:51:59.171 [main] Added file watch at renderers: renderers\\LG-LB.conf
DEBUG 2017-06-10 22:51:59.174 [main] Added file watch at renderers: renderers\\LG-LM620.conf
DEBUG 2017-06-10 22:51:59.177 [main] Added file watch at renderers: renderers\\LG-LM660.conf
DEBUG 2017-06-10 22:51:59.179 [main] Added file watch at renderers: renderers\\LG-LS5700.conf
DEBUG 2017-06-10 22:51:59.182 [main] Added file watch at renderers: renderers\\LG-ST600.conf
DEBUG 2017-06-10 22:51:59.184 [main] Added file watch at renderers: renderers\\LG-UB820V.conf
DEBUG 2017-06-10 22:51:59.187 [main] Added file watch at renderers: renderers\\LG-WebOS.conf
DEBUG 2017-06-10 22:51:59.189 [main] Added file watch at renderers: renderers\\Logitech-Squeezebox.conf
DEBUG 2017-06-10 22:51:59.193 [main] Added file watch at renderers: renderers\\Microsoft-WindowsMediaPlayer.conf
DEBUG 2017-06-10 22:51:59.196 [main] Added file watch at renderers: renderers\\Microsoft-Xbox360.conf
DEBUG 2017-06-10 22:51:59.199 [main] Added file watch at renderers: renderers\\Microsoft-XboxOne.conf
DEBUG 2017-06-10 22:51:59.201 [main] Added file watch at renderers: renderers\\Miracast-M806.conf
DEBUG 2017-06-10 22:51:59.203 [main] Added file watch at renderers: renderers\\Naim-Mu-So.conf
DEBUG 2017-06-10 22:51:59.205 [main] Added file watch at renderers: renderers\\Netgear-NeoTV.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\Netgem-N7700.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\Nokia-N900.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\Onkyo-TXNR7xx.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\OPPO-BDP.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\OPPO-BDP83.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\Panasonic-DMPBDT.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\Panasonic-DMPBDT220.conf
DEBUG 2017-06-10 22:51:59.207 [main] Added file watch at renderers: renderers\\Panasonic-DMPBDT360.conf
DEBUG 2017-06-10 22:51:59.224 [main] Added file watch at renderers: renderers\\Panasonic-DMR.conf
DEBUG 2017-06-10 22:51:59.226 [main] Added file watch at renderers: renderers\\Panasonic-SCBTT.conf
DEBUG 2017-06-10 22:51:59.230 [main] Added file watch at renderers: renderers\\Panasonic-Viera.conf
DEBUG 2017-06-10 22:51:59.233 [main] Added file watch at renderers: renderers\\Panasonic-VieraAS600E.conf
DEBUG 2017-06-10 22:51:59.235 [main] Added file watch at renderers: renderers\\Panasonic-VieraAS650.conf
DEBUG 2017-06-10 22:51:59.239 [main] Added file watch at renderers: renderers\\Panasonic-VieraCX680.conf
DEBUG 2017-06-10 22:51:59.260 [main] Added file watch at renderers: renderers\\Panasonic-VieraCX700.conf
DEBUG 2017-06-10 22:51:59.263 [main] Added file watch at renderers: renderers\\Panasonic-VieraE6.conf
DEBUG 2017-06-10 22:51:59.266 [main] Added file watch at renderers: renderers\\Panasonic-VieraET60.conf
DEBUG 2017-06-10 22:51:59.270 [main] Added file watch at renderers: renderers\\Panasonic-VieraGT50.conf
DEBUG 2017-06-10 22:51:59.273 [main] Added file watch at renderers: renderers\\Panasonic-VieraS60.conf
DEBUG 2017-06-10 22:51:59.276 [main] Added file watch at renderers: renderers\\Panasonic-VieraST60.conf
DEBUG 2017-06-10 22:51:59.278 [main] Added file watch at renderers: renderers\\Panasonic-VieraTHPU30Z.conf
DEBUG 2017-06-10 22:51:59.280 [main] Added file watch at renderers: renderers\\Panasonic-VieraTXL32V10E.conf
DEBUG 2017-06-10 22:51:59.286 [main] Added file watch at renderers: renderers\\Panasonic-VieraVT60.conf
DEBUG 2017-06-10 22:51:59.290 [main] Added file watch at renderers: renderers\\Philips-AureaAndNetTV.conf
DEBUG 2017-06-10 22:51:59.292 [main] Added file watch at renderers: renderers\\Philips-PFL.conf
DEBUG 2017-06-10 22:51:59.294 [main] Added file watch at renderers: renderers\\Philips-Streamium.conf
DEBUG 2017-06-10 22:51:59.296 [main] Added file watch at renderers: renderers\\Pioneer-BDP.conf
DEBUG 2017-06-10 22:51:59.299 [main] Added file watch at renderers: renderers\\Pioneer-Kuro.conf
DEBUG 2017-06-10 22:51:59.301 [main] Added file watch at renderers: renderers\\PopcornHour.conf
DEBUG 2017-06-10 22:51:59.303 [main] Added file watch at renderers: renderers\\Realtek.conf
DEBUG 2017-06-10 22:51:59.305 [main] Added file watch at renderers: renderers\\Roku-Roku3-3.conf
DEBUG 2017-06-10 22:51:59.308 [main] Added file watch at renderers: renderers\\Roku-Roku3-5.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-9series.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-BDC6800.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-BDH6500.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-C6600.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-CD.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-D6400.conf
DEBUG 2017-06-10 22:51:59.309 [main] Added file watch at renderers: renderers\\Samsung-D7000.conf
DEBUG 2017-06-10 22:51:59.326 [main] Added file watch at renderers: renderers\\Samsung-EH5300.conf
DEBUG 2017-06-10 22:51:59.329 [main] Added file watch at renderers: renderers\\Samsung-EH6070.conf
DEBUG 2017-06-10 22:51:59.332 [main] Added file watch at renderers: renderers\\Samsung-ES6100.conf
DEBUG 2017-06-10 22:51:59.334 [main] Added file watch at renderers: renderers\\Samsung-ES6575.conf
DEBUG 2017-06-10 22:51:59.337 [main] Added file watch at renderers: renderers\\Samsung-ES8000.conf
DEBUG 2017-06-10 22:51:59.340 [main] Added file watch at renderers: renderers\\Samsung-ES8005.conf
DEBUG 2017-06-10 22:51:59.342 [main] Added file watch at renderers: renderers\\Samsung-F5100.conf
DEBUG 2017-06-10 22:51:59.346 [main] Added file watch at renderers: renderers\\Samsung-F5505.conf
DEBUG 2017-06-10 22:51:59.348 [main] Added file watch at renderers: renderers\\Samsung-F5900.conf
DEBUG 2017-06-10 22:51:59.350 [main] Added file watch at renderers: renderers\\Samsung-GalaxyS5.conf
DEBUG 2017-06-10 22:51:59.355 [main] Added file watch at renderers: renderers\\Samsung-H4500.conf
DEBUG 2017-06-10 22:51:59.360 [main] Added file watch at renderers: renderers\\Samsung-H6203.conf
DEBUG 2017-06-10 22:51:59.363 [main] Added file watch at renderers: renderers\\Samsung-H6400.conf
DEBUG 2017-06-10 22:51:59.365 [main] Added file watch at renderers: renderers\\Samsung-HTE3.conf
DEBUG 2017-06-10 22:51:59.368 [main] Added file watch at renderers: renderers\\Samsung-HTF4.conf
DEBUG 2017-06-10 22:51:59.372 [main] Added file watch at renderers: renderers\\Samsung-HU7000.conf
DEBUG 2017-06-10 22:51:59.375 [main] Added file watch at renderers: renderers\\Samsung-HU9000.conf
DEBUG 2017-06-10 22:51:59.378 [main] Added file watch at renderers: renderers\\Samsung-J55xx.conf
DEBUG 2017-06-10 22:51:59.380 [main] Added file watch at renderers: renderers\\Samsung-J6200.conf
DEBUG 2017-06-10 22:51:59.383 [main] Added file watch at renderers: renderers\\Samsung-JU6400.conf
DEBUG 2017-06-10 22:51:59.385 [main] Added file watch at renderers: renderers\\Samsung-Mobile.conf
DEBUG 2017-06-10 22:51:59.387 [main] Added file watch at renderers: renderers\\Samsung-NotCD.conf
DEBUG 2017-06-10 22:51:59.391 [main] Added file watch at renderers: renderers\\Samsung-PL51E490.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Samsung-SMTG7400.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Samsung-WiseLink.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Sharp-Aquos.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Showtime3.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Showtime4.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Sony-Bluray.conf
DEBUG 2017-06-10 22:51:59.392 [main] Added file watch at renderers: renderers\\Sony-Bluray2013.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-Bravia4500.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-Bravia5500.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-BraviaBX305.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-BraviaEX.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-BraviaEX620.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-BraviaEX725.conf
DEBUG 2017-06-10 22:51:59.407 [main] Added file watch at renderers: renderers\\Sony-BraviaHX.conf
DEBUG 2017-06-10 22:51:59.424 [main] Added file watch at renderers: renderers\\Sony-BraviaHX75.conf
DEBUG 2017-06-10 22:51:59.426 [main] Added file watch at renderers: renderers\\Sony-BraviaNX70x.conf
DEBUG 2017-06-10 22:51:59.428 [main] Added file watch at renderers: renderers\\Sony-BraviaNX800.conf
DEBUG 2017-06-10 22:51:59.431 [main] Added file watch at renderers: renderers\\Sony-BraviaW.conf
DEBUG 2017-06-10 22:51:59.433 [main] Added file watch at renderers: renderers\\Sony-BraviaX.conf
DEBUG 2017-06-10 22:51:59.436 [main] Added file watch at renderers: renderers\\Sony-BraviaXBR.conf
DEBUG 2017-06-10 22:51:59.439 [main] Added file watch at renderers: renderers\\Sony-BraviaXD.conf
DEBUG 2017-06-10 22:51:59.442 [main] Added file watch at renderers: renderers\\Sony-HomeTheatreSystem.conf
DEBUG 2017-06-10 22:51:59.444 [main] Added file watch at renderers: renderers\\Sony-PlayStation3.conf
DEBUG 2017-06-10 22:51:59.447 [main] Added file watch at renderers: renderers\\Sony-PlayStation4.conf
DEBUG 2017-06-10 22:51:59.449 [main] Added file watch at renderers: renderers\\Sony-PlayStationVita.conf
DEBUG 2017-06-10 22:51:59.451 [main] Added file watch at renderers: renderers\\Sony-SMPN100.conf
DEBUG 2017-06-10 22:51:59.456 [main] Added file watch at renderers: renderers\\Sony-STR5800ES.conf
DEBUG 2017-06-10 22:51:59.458 [main] Added file watch at renderers: renderers\\Sony-Xperia.conf
DEBUG 2017-06-10 22:51:59.461 [main] Added file watch at renderers: renderers\\Sony-XperiaZ3.conf
DEBUG 2017-06-10 22:51:59.464 [main] Added file watch at renderers: renderers\\Technisat-S1Plus.conf
DEBUG 2017-06-10 22:51:59.467 [main] Added file watch at renderers: renderers\\Telefunken-TV.conf
DEBUG 2017-06-10 22:51:59.470 [main] Added file watch at renderers: renderers\\Telstra-Tbox.conf
DEBUG 2017-06-10 22:51:59.473 [main] Added file watch at renderers: renderers\\Thomson-U3.conf
DEBUG 2017-06-10 22:51:59.474 [main] Added file watch at renderers: renderers\\VideoWeb-VideoWebTV.conf
DEBUG 2017-06-10 22:51:59.477 [main] Added file watch at renderers: renderers\\Vizio-SmartTV.conf
DEBUG 2017-06-10 22:51:59.478 [main] Added file watch at renderers: renderers\\VLC-for-desktop.conf
DEBUG 2017-06-10 22:51:59.480 [main] Added file watch at renderers: renderers\\WesternDigital-WDTVLive.conf
DEBUG 2017-06-10 22:51:59.481 [main] Added file watch at renderers: renderers\\XBMC.conf
DEBUG 2017-06-10 22:51:59.482 [main] Added file watch at renderers: renderers\\Yamaha-RN500.conf
DEBUG 2017-06-10 22:51:59.484 [main] Added file watch at renderers: renderers\\Yamaha-RXA1010.conf
DEBUG 2017-06-10 22:51:59.486 [main] Added file watch at renderers: renderers\\Yamaha-RXA2050.conf
DEBUG 2017-06-10 22:51:59.487 [main] Added file watch at renderers: renderers\\Yamaha-RXV3900.conf
DEBUG 2017-06-10 22:51:59.489 [main] Added file watch at renderers: renderers\\Yamaha-RXV500D.conf
DEBUG 2017-06-10 22:51:59.490 [main] Added file watch at renderers: renderers\\Yamaha-RXV671.conf
INFO 2017-06-10 22:51:59.490 [main] Enabled 145 configurations, listed in order of loading priority:
INFO 2017-06-10 22:51:59.491 [main] : BubbleUPnP
INFO 2017-06-10 22:51:59.491 [main] : Chromecast
INFO 2017-06-10 22:51:59.491 [main] : Naim Mu-So
INFO 2017-06-10 22:51:59.491 [main] : Panasonic AS600
INFO 2017-06-10 22:51:59.492 [main] : Panasonic AS650
INFO 2017-06-10 22:51:59.492 [main] : Panasonic BDT220
INFO 2017-06-10 22:51:59.493 [main] : Panasonic BDT360
INFO 2017-06-10 22:51:59.493 [main] : Panasonic CX680
INFO 2017-06-10 22:51:59.494 [main] : Panasonic CX700
INFO 2017-06-10 22:51:59.494 [main] : Panasonic E6
INFO 2017-06-10 22:51:59.494 [main] : Panasonic ET60
INFO 2017-06-10 22:51:59.494 [main] : Panasonic GT50
INFO 2017-06-10 22:51:59.494 [main] : Panasonic Home Theater (SC-BTT)
INFO 2017-06-10 22:51:59.495 [main] : Panasonic S60
INFO 2017-06-10 22:51:59.495 [main] : Panasonic ST60
INFO 2017-06-10 22:51:59.495 [main] : Panasonic VT60
INFO 2017-06-10 22:51:59.495 [main] : Sony Blu-ray (2013)
INFO 2017-06-10 22:51:59.495 [main] : Sony Bravia XD/XE
INFO 2017-06-10 22:51:59.495 [main] : VLC for iOS
INFO 2017-06-10 22:51:59.496 [main] : Xperia Z3
INFO 2017-06-10 22:51:59.496 [main] : Chromecast
INFO 2017-06-10 22:51:59.496 [main] : Hisense K680
INFO 2017-06-10 22:51:59.496 [main] : LG BP550
INFO 2017-06-10 22:51:59.496 [main] : LG EG910V
INFO 2017-06-10 22:51:59.497 [main] : LG LCD TV (2014)
INFO 2017-06-10 22:51:59.497 [main] : LG LM660
INFO 2017-06-10 22:51:59.497 [main] : LG LS5700
INFO 2017-06-10 22:51:59.497 [main] : LG UB820V
INFO 2017-06-10 22:51:59.499 [main] : LG WebOS TV
INFO 2017-06-10 22:51:59.499 [main] : Panasonic DMR
INFO 2017-06-10 22:51:59.499 [main] : Panasonic TV
INFO 2017-06-10 22:51:59.500 [main] : Samsung 9 Series
INFO 2017-06-10 22:51:59.500 [main] : Samsung BD-C6800
INFO 2017-06-10 22:51:59.500 [main] : Samsung D6400
INFO 2017-06-10 22:51:59.500 [main] : Samsung D7000
INFO 2017-06-10 22:51:59.500 [main] : Samsung EH5300
INFO 2017-06-10 22:51:59.501 [main] : Samsung EH6070
INFO 2017-06-10 22:51:59.501 [main] : Samsung ES6100
INFO 2017-06-10 22:51:59.501 [main] : Samsung ES6575
INFO 2017-06-10 22:51:59.501 [main] : Samsung ES8000
INFO 2017-06-10 22:51:59.501 [main] : Samsung ES8005
INFO 2017-06-10 22:51:59.502 [main] : Samsung F5100
INFO 2017-06-10 22:51:59.502 [main] : Samsung F5505
INFO 2017-06-10 22:51:59.502 [main] : Samsung F5900
INFO 2017-06-10 22:51:59.502 [main] : Samsung H4500
INFO 2017-06-10 22:51:59.502 [main] : Samsung H6203
INFO 2017-06-10 22:51:59.503 [main] : Samsung H6400
INFO 2017-06-10 22:51:59.503 [main] : Samsung H6500
INFO 2017-06-10 22:51:59.503 [main] : Samsung HT-E3 Series
INFO 2017-06-10 22:51:59.503 [main] : Samsung HT-F4
INFO 2017-06-10 22:51:59.503 [main] : Samsung HU7000
INFO 2017-06-10 22:51:59.503 [main] : Samsung HU9000
INFO 2017-06-10 22:51:59.504 [main] : Samsung J55xx Series
INFO 2017-06-10 22:51:59.504 [main] : Samsung J6200
INFO 2017-06-10 22:51:59.504 [main] : Samsung JU6400
INFO 2017-06-10 22:51:59.504 [main] : Samsung PL51E490
INFO 2017-06-10 22:51:59.504 [main] : Sony Bravia EX725
INFO 2017-06-10 22:51:59.504 [main] : Vizio Smart TV
INFO 2017-06-10 22:51:59.504 [main] : VLC for Apple TV
INFO 2017-06-10 22:51:59.505 [main] : VLC for iOS (iPhone 5 or older)
INFO 2017-06-10 22:51:59.505 [main] : Xbox One
INFO 2017-06-10 22:51:59.505 [main] : AirPlayer
INFO 2017-06-10 22:51:59.505 [main] : Android
INFO 2017-06-10 22:51:59.505 [main] : AnyCast
INFO 2017-06-10 22:51:59.505 [main] : Apple iPad / iPhone
INFO 2017-06-10 22:51:59.506 [main] : Azur BD
INFO 2017-06-10 22:51:59.506 [main] : BRAVIA KDL-xxNX800
INFO 2017-06-10 22:51:59.506 [main] : D-Link DSM-510
INFO 2017-06-10 22:51:59.507 [main] : DirecTV
INFO 2017-06-10 22:51:59.507 [main] : Freebox
INFO 2017-06-10 22:51:59.507 [main] : Freecom MusicPal
INFO 2017-06-10 22:51:59.507 [main] : Hama IR320
INFO 2017-06-10 22:51:59.507 [main] : KalemSoft Media Player
INFO 2017-06-10 22:51:59.508 [main] : Kodi
INFO 2017-06-10 22:51:59.508 [main] : LG Blu-Ray Player
INFO 2017-06-10 22:51:59.508 [main] : LG LA6200
INFO 2017-06-10 22:51:59.509 [main] : LG LA644V
INFO 2017-06-10 22:51:59.509 [main] : LG LM620
INFO 2017-06-10 22:51:59.509 [main] : LG Smart TV Upgrader
INFO 2017-06-10 22:51:59.509 [main] : Logitech Squeezebox
INFO 2017-06-10 22:51:59.509 [main] : Miracast M806
INFO 2017-06-10 22:51:59.509 [main] : Netgear NeoTV
INFO 2017-06-10 22:51:59.509 [main] : Netgem N7700
INFO 2017-06-10 22:51:59.509 [main] : Nokia N900
INFO 2017-06-10 22:51:59.509 [main] : Onkyo TX-NR7xx
INFO 2017-06-10 22:51:59.509 [main] : OPPO BDP
INFO 2017-06-10 22:51:59.509 [main] : OPPO BDP-83
INFO 2017-06-10 22:51:59.509 [main] : Panasonic BDT
INFO 2017-06-10 22:51:59.509 [main] : Panasonic TX-L32V10E
INFO 2017-06-10 22:51:59.509 [main] : Panasonic U30Z
INFO 2017-06-10 22:51:59.509 [main] : Philips Aurea
INFO 2017-06-10 22:51:59.509 [main] : Philips TV
INFO 2017-06-10 22:51:59.509 [main] : Pioneer BDP
INFO 2017-06-10 22:51:59.509 [main] : Pioneer Kuro
INFO 2017-06-10 22:51:59.509 [main] : PlayStation 3
INFO 2017-06-10 22:51:59.509 [main] : PlayStation 4
INFO 2017-06-10 22:51:59.509 [main] : PlayStation Vita
INFO 2017-06-10 22:51:59.509 [main] : Popcorn Hour
INFO 2017-06-10 22:51:59.509 [main] : Realtek
INFO 2017-06-10 22:51:59.509 [main] : Roku 3 (NSP 3)
INFO 2017-06-10 22:51:59.509 [main] : Roku 3 (NSP 5)
INFO 2017-06-10 22:51:59.509 [main] : Samsung C/D Series
INFO 2017-06-10 22:51:59.509 [main] : Samsung C6600
INFO 2017-06-10 22:51:59.509 [main] : Samsung E+ Series
INFO 2017-06-10 22:51:59.509 [main] : Samsung Galaxy S5
INFO 2017-06-10 22:51:59.509 [main] : Samsung Mobile
INFO 2017-06-10 22:51:59.509 [main] : Samsung SMT-G7400
INFO 2017-06-10 22:51:59.509 [main] : Samsung WiseLink
INFO 2017-06-10 22:51:59.509 [main] : Sharp Aquos
INFO 2017-06-10 22:51:59.509 [main] : Showtime 3
INFO 2017-06-10 22:51:59.509 [main] : Showtime 4
INFO 2017-06-10 22:51:59.509 [main] : Sony Blu-ray
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia 4500
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia 5500
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia BX305
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia EX
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia EX620
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia HX
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia HX75
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia NX70x
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia W
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia X
INFO 2017-06-10 22:51:59.509 [main] : Sony Bravia XBR
INFO 2017-06-10 22:51:59.509 [main] : Sony Home Theatre System
INFO 2017-06-10 22:51:59.509 [main] : Sony SMP-N100
INFO 2017-06-10 22:51:59.509 [main] : Sony STR-DA5800ES
INFO 2017-06-10 22:51:59.509 [main] : Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO 2017-06-10 22:51:59.509 [main] : Streamium
INFO 2017-06-10 22:51:59.509 [main] : Technisat S1+
INFO 2017-06-10 22:51:59.509 [main] : Telefunken TV
INFO 2017-06-10 22:51:59.509 [main] : Telstra T-Box
INFO 2017-06-10 22:51:59.509 [main] : Thomson U3 Series
INFO 2017-06-10 22:51:59.509 [main] : Unknown renderer
INFO 2017-06-10 22:51:59.509 [main] : VideoWeb TV
INFO 2017-06-10 22:51:59.509 [main] : VLC for desktop
INFO 2017-06-10 22:51:59.509 [main] : WD TV Live
INFO 2017-06-10 22:51:59.509 [main] : Windows Media Player
INFO 2017-06-10 22:51:59.509 [main] : XBMC
INFO 2017-06-10 22:51:59.509 [main] : Xbox 360
INFO 2017-06-10 22:51:59.509 [main] : Yamaha R-N500
INFO 2017-06-10 22:51:59.509 [main] : Yamaha RX-A1010
INFO 2017-06-10 22:51:59.509 [main] : Yamaha RX-A2050
INFO 2017-06-10 22:51:59.509 [main] : Yamaha RX-V3900
INFO 2017-06-10 22:51:59.509 [main] : Yamaha RX-V500D
INFO 2017-06-10 22:51:59.509 [main] : Yamaha RX-V671
DEBUG 2017-06-10 22:51:59.707 [main] UPNP Services are online, listening for media renderers
DEBUG 2017-06-10 22:51:59.723 [main] Attached http player control handler to web server
INFO 2017-06-10 22:51:59.788 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
DEBUG 2017-06-10 22:51:59.793 [mplayer.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\mplayer.exe" dummy
DEBUG 2017-06-10 22:51:59.793 [ffmpeg64.exe-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe" -y -f lavfi -i nullsrc=s=720x480:d=1:r=1 -vf ass=DummyInput.ass -target ntsc-dvd -
DEBUG 2017-06-10 22:51:59.824 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth\plugins
INFO 2017-06-10 22:51:59.824 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO 2017-06-10 22:51:59.824 [main] Found VLC version 2.2.6 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
DEBUG 2017-06-10 22:51:59.870 [mplayer.exe-1] Attaching thread: mplayer.exe-1
DEBUG 2017-06-10 22:51:59.870 [ffmpeg64.exe-2] Attaching thread: ffmpeg64.exe-2
INFO 2017-06-10 22:51:59.875 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO 2017-06-10 22:51:59.878 [main] No plugins found
INFO 2017-06-10 22:51:59.898 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2017-06-10 22:51:59.901 [main] Registering transcoding engine: FFmpeg Audio
INFO 2017-06-10 22:51:59.908 [main] Registering transcoding engine: MEncoder
INFO 2017-06-10 22:51:59.908 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2017-06-10 22:51:59.908 [main] Registering transcoding engine: FFmpeg
INFO 2017-06-10 22:51:59.908 [main] Registering transcoding engine: VLC
DEBUG 2017-06-10 22:51:59.924 [cling-7] Reading MediaInfo: true (default: false)
DEBUG 2017-06-10 22:51:59.924 [cling-7] Marking upnp renderer "Smart TV" at /192.168.1.2 as unrecognized
DEBUG 2017-06-10 22:51:59.924 [cling-7] Reading automatic_maximum_bitrate: true (default: false)
DEBUG 2017-06-10 22:51:59.924 [cling-7] Adding status button for Smart TV
DEBUG 2017-06-10 22:51:59.933 [cling-7] Device icon: http://192.168.1.2:2870/icon/DMR-large.jpg
INFO 2017-06-10 22:51:59.936 [pool-6-thread-1] Checking IP: 192.168.1.2 for Smart TV
DEBUG 2017-06-10 22:51:59.941 [cling-7] Error reading icon url: javax.imageio.IIOException: Can't get input stream from URL!
DEBUG 2017-06-10 22:51:59.942 [cling-7] Unable to read icon url "http://192.168.1.2:2870/icon/DMR-large.jpg", using "unknown.png" instead.
DEBUG 2017-06-10 22:51:59.999 [cling-7] New renderer found: "Smart TV" with dlna details: {friendlyName=Smart TV, address=192.168.1.2, udn=uuid:13ed0f7e-f22d-1656-969c-000ce7060000, manufacturer=, modelName=, modelNumber=, modelDescription=IPI Media Renderer, manufacturerURL=}
DEBUG 2017-06-10 22:51:59.999 [cling-7] Adding device: urn:schemas-upnp-org:device:MediaRenderer:1 (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:13ed0f7e-f22d-1656-969c-000ce7060000, Descriptor: http://192.168.1.2:2870/dmr.xml, Root: true
DEBUG 2017-06-10 22:51:59.999 [cling-7] Subscribing to RenderingControl service on Smart TV
DEBUG 2017-06-10 22:52:00.001 [cling-7] Subscribing to ConnectionManager service on Smart TV
DEBUG 2017-06-10 22:52:00.002 [cling-7] Subscribing to AVTransport service on Smart TV
DEBUG 2017-06-10 22:52:00.171 [ffmpeg64.exe-2-2] ffmpeg version N-84348-gdb7a05d Copyright (c) 2000-2017 the FFmpeg developers
DEBUG 2017-06-10 22:52:00.171 [ffmpeg64.exe-2-2] built with gcc 6.3.0 (GCC)
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libavutil 55. 50.100 / 55. 50.100
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libavcodec 57. 83.101 / 57. 83.101
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libavformat 57. 66.105 / 57. 66.105
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libavdevice 57. 3.100 / 57. 3.100
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libavfilter 6. 78.100 / 6. 78.100
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libswscale 4. 3.101 / 4. 3.101
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libswresample 2. 4.100 / 2. 4.100
DEBUG 2017-06-10 22:52:00.172 [ffmpeg64.exe-2-2] libpostproc 54. 2.100 / 54. 2.100
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] Input #0, lavfi, from 'nullsrc=s=720x480:d=1:r=1':
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] Duration: N/A, start: 0.000000, bitrate: N/A
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 720x480 [SAR 1:1 DAR 3:2], 1 tbr, 1 tbn, 1 tbc
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] Stream mapping:
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] Stream #0:0 -> #0:0 (rawvideo (native) -> mpeg2video (native))
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] Press [q] to stop, [?] for help
DEBUG 2017-06-10 22:52:00.173 [ffmpeg64.exe-2-2] [Parsed_ass_0 @ 000000000244b540] Shaper: FriBidi 0.19.6 (SIMPLE)
DEBUG 2017-06-10 22:52:00.183 [main] FFmpeg supported protocols: [async, bluray, cache, concat, crypto, data, file, ftp, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, subfile, tcp, tls, udp, udplite, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms]
INFO 2017-06-10 22:52:00.183 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2017-06-10 22:52:00.184 [main] Registering transcoding engine: MEncoder Web
INFO 2017-06-10 22:52:00.184 [main] Registering transcoding engine: VLC Web Video
INFO 2017-06-10 22:52:00.188 [main] Registering transcoding engine: tsMuxeR
INFO 2017-06-10 22:52:00.189 [main] Registering transcoding engine: Audio High Fidelity
INFO 2017-06-10 22:52:00.190 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 2017-06-10 22:52:00.191 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 2017-06-10 22:52:00.191 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2017-06-10 22:52:00.193 [main] Registering transcoding engine: DCRaw
DEBUG 2017-06-10 22:52:00.256 [ffmpeg64.exe-2-2] [Parsed_ass_0 @ 000000000244b540] Using font provider fontconfig
DEBUG 2017-06-10 22:52:00.257 [ffmpeg64.exe-2-2] [Parsed_ass_0 @ 000000000244b540] Added subtitle file: 'DummyInput.ass' (6 styles, 1 events)
DEBUG 2017-06-10 22:52:00.263 [cling-7] Created upnp player for Smart TV
DEBUG 2017-06-10 22:52:00.280 [main] Reading alternativeffmpegpath: "C:\Program Files (x86)\Universal Media Server\win32\dvrms\ffmpeg_MPGMUX.exe" (default: null)
DEBUG 2017-06-10 22:52:00.300 [main] Reading avisynth_script: "<movie>
<sub>" (default: "<movie>
<sub>
DEBUG 2017-06-10 22:52:00.305 [ffmpeg64.exe-2-2] Output #0, dvd, to 'pipe:':
DEBUG 2017-06-10 22:52:00.305 [ffmpeg64.exe-2-2] Metadata:
DEBUG 2017-06-10 22:52:00.305 [ffmpeg64.exe-2-2] encoder : Lavf57.66.105
DEBUG 2017-06-10 22:52:00.305 [ffmpeg64.exe-2-2] Stream #0:0: Video: mpeg2video (Main), yuv420p, 720x480 [SAR 1:1 DAR 3:2], q=2-31, 6000 kb/s, 29.97 fps, 90k tbn, 29.97 tbc
DEBUG 2017-06-10 22:52:00.305 [ffmpeg64.exe-2-2] encoder : Lavc57.83.101 mpeg2video
DEBUG 2017-06-10 22:52:00.305 [ffmpeg64.exe-2-2] Side data:
DEBUG 2017-06-10 22:52:00.306 [ffmpeg64.exe-2-2] cpb: bitrate max/min/avg: 9000000/0/6000000 buffer size: 1835008 vbv_delay: -1
DEBUG 2017-06-10 22:52:00.319 [ffmpeg64.exe-2-2] frame= 1 fps=0.0 q=1.6 Lsize= 8kB time=00:00:00.00 bitrate=5957818.2kbits/s speed=4.76e-005x
DEBUG 2017-06-10 22:52:00.320 [ffmpeg64.exe-2-2] video:5kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 51.227615%
INFO 2017-06-10 22:52:00.326 [main] Using address /192.168.1.8 found on network interface: name:eth2 (Realtek PCIe GBE Family Controller)
INFO 2017-06-10 22:52:00.327 [main] Created socket: /192.168.1.8:5001
DEBUG 2017-06-10 22:52:00.376 [mplayer.exe-1-2] File not found: 'dummy'
DEBUG 2017-06-10 22:52:00.376 [mplayer.exe-1-2] Failed to open dummy.
DEBUG 2017-06-10 22:52:00.382 [cling-12] Subscription established: RenderingControl on Smart TV
DEBUG 2017-06-10 22:52:00.388 [cling-12] Subscription established: ConnectionManager on Smart TV
DEBUG 2017-06-10 22:52:00.392 [cling-12] Subscription established: AVTransport on Smart TV
INFO 2017-06-10 22:52:00.427 [main] WEB interface is available at: http://192.168.1.8:9001
INFO 2017-06-10 22:52:00.456 [main] A tiny cache admin interface is available at: http://192.168.1.8:5001/console/home
DEBUG 2017-06-10 22:52:00.576 [main] Added file watch at C:\ProgramData\UMS: C:\\ProgramData\\UMS\\WEB.conf
DEBUG 2017-06-10 22:52:00.592 [main] Sending BYEBYE...
DEBUG 2017-06-10 22:52:01.230 [main] Sending ALIVE...
DEBUG 2017-06-10 22:52:02.828 [AWT-EventQueue-0] Checking dbgpack property in UMS.conf
DEBUG 2017-06-10 22:52:02.829 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2017-06-10 22:52:02.829 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2017-06-10 22:52:02.829 [AWT-EventQueue-0] adding C:\ProgramData\UMS\debug.log.prev
DEBUG 2017-06-10 22:52:02.859 [ffmpeg64.exe-2-Cleanup] Stopping process: ffmpeg64.exe-2
DEBUG 2017-06-10 22:52:02.940 [mplayer.exe-1-Cleanup] Stopping process: mplayer.exe-1
INFO 2017-06-10 22:52:02.959 [main] Universal Media Server is now available for renderers to find
INFO 2017-06-10 22:52:04.545 [pool-6-thread-1] Renderer Smart TV found on this address: 192.168.1.2
DEBUG 2017-06-10 22:52:04.547 [pool-6-thread-1] Starting ping -n 3 -l 512 192.168.1.2
DEBUG 2017-06-10 22:52:04.606 [ping-3-1]
DEBUG 2017-06-10 22:52:04.606 [ping-3-1] Pinging 192.168.1.2 with 512 bytes of data:
DEBUG 2017-06-10 22:52:04.607 [ping-3-1] Reply from 192.168.1.2: bytes=512 time<1ms TTL=64
DEBUG 2017-06-10 22:52:05.685 [ping-3-1] Reply from 192.168.1.2: bytes=512 time=61ms TTL=64
DEBUG 2017-06-10 22:52:06.626 [ping-3-1] Reply from 192.168.1.2: bytes=512 time=1ms TTL=64
DEBUG 2017-06-10 22:52:06.627 [ping-3-1] Ping statistics for 192.168.1.2:
DEBUG 2017-06-10 22:52:06.627 [ping-3-1] Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
DEBUG 2017-06-10 22:52:06.627 [ping-3-1] Approximate round trip times in milli-seconds:
DEBUG 2017-06-10 22:52:06.627 [ping-3-1] Minimum = 0ms, Maximum = 61ms, Average = 20ms
DEBUG 2017-06-10 22:52:06.630 [pool-6-thread-1] est speed for 512 1 is 565248.0
DEBUG 2017-06-10 22:52:06.631 [pool-6-thread-1] Starting ping -n 3 -l 1476 192.168.1.2
DEBUG 2017-06-10 22:52:06.665 [ping-4-1]
DEBUG 2017-06-10 22:52:06.666 [ping-4-1] Pinging 192.168.1.2 with 1476 bytes of data:
DEBUG 2017-06-10 22:52:06.668 [ping-4-1] Reply from 192.168.1.2: bytes=1476 time=1ms TTL=64
DEBUG 2017-06-10 22:52:07.551 [SpeedStats Failsafe] Stopping process: ping-3
DEBUG 2017-06-10 22:52:07.732 [ping-4-1] Reply from 192.168.1.2: bytes=1476 time=65ms TTL=64
DEBUG 2017-06-10 22:52:08.671 [ping-4-1] Reply from 192.168.1.2: bytes=1476 time=1ms TTL=64
DEBUG 2017-06-10 22:52:08.672 [ping-4-1]
DEBUG 2017-06-10 22:52:08.672 [ping-4-1] Ping statistics for 192.168.1.2:
DEBUG 2017-06-10 22:52:08.672 [ping-4-1] Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
DEBUG 2017-06-10 22:52:08.672 [ping-4-1] Approximate round trip times in milli-seconds:
DEBUG 2017-06-10 22:52:08.672 [ping-4-1] Minimum = 1ms, Maximum = 65ms, Average = 22ms
DEBUG 2017-06-10 22:52:08.676 [pool-6-thread-1] est speed for 1476 1 is 1426823.5294117648
DEBUG 2017-06-10 22:52:08.677 [pool-6-thread-1] Starting ping -n 3 -l 9100 192.168.1.2
DEBUG 2017-06-10 22:52:08.707 [ping-5-1]
DEBUG 2017-06-10 22:52:08.707 [ping-5-1] Pinging 192.168.1.2 with 9100 bytes of data:
DEBUG 2017-06-10 22:52:08.707 [ping-5-1] Reply from 192.168.1.2: bytes=9100 time=7ms TTL=64
DEBUG 2017-06-10 22:52:09.632 [SpeedStats Failsafe] Stopping process: ping-4
DEBUG 2017-06-10 22:52:09.734 [ping-5-1] Reply from 192.168.1.2: bytes=9100 time=11ms TTL=64
DEBUG 2017-06-10 22:52:10.237 [AWT-EventQueue-0] Reloading...
DEBUG 2017-06-10 22:52:10.243 [AWT-EventQueue-0] Checking dbgpack property in UMS.conf
DEBUG 2017-06-10 22:52:10.243 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2017-06-10 22:52:10.244 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2017-06-10 22:52:10.244 [AWT-EventQueue-0] adding C:\ProgramData\UMS\debug.log.prev
DEBUG 2017-06-10 22:52:10.791 [ping-5-1] Reply from 192.168.1.2: bytes=9100 time=80ms TTL=64
DEBUG 2017-06-10 22:52:10.807 [ping-5-1] Ping statistics for 192.168.1.2:
DEBUG 2017-06-10 22:52:10.807 [ping-5-1] Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
DEBUG 2017-06-10 22:52:10.807 [ping-5-1] Approximate round trip times in milli-seconds:
DEBUG 2017-06-10 22:52:10.807 [ping-5-1] Minimum = 7ms, Maximum = 80ms, Average = 32ms
DEBUG 2017-06-10 22:52:10.807 [pool-6-thread-1] est speed for 9100 7 is 5688076.19047619
DEBUG 2017-06-10 22:52:10.807 [pool-6-thread-1] Starting ping -n 3 -l 32000 192.168.1.2
DEBUG 2017-06-10 22:52:10.869 [ping-6-1]
DEBUG 2017-06-10 22:52:10.869 [ping-6-1] Pinging 192.168.1.2 with 32000 bytes of data:
DEBUG 2017-06-10 22:52:10.880 [ping-6-1] Reply from 192.168.1.2: bytes=32000 time=9ms TTL=64
DEBUG 2017-06-10 22:52:11.677 [SpeedStats Failsafe] Stopping process: ping-5
DEBUG 2017-06-10 22:52:11.881 [ping-6-1] Reply from 192.168.1.2: bytes=32000 time=8ms TTL=64
DEBUG 2017-06-10 22:52:12.959 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2017-06-10 22:52:13.071 [ping-6-1] Reply from 192.168.1.2: bytes=32000 time=197ms TTL=64
DEBUG 2017-06-10 22:52:13.072 [ping-6-1]
DEBUG 2017-06-10 22:52:13.072 [ping-6-1] Ping statistics for 192.168.1.2:
DEBUG 2017-06-10 22:52:13.072 [ping-6-1] Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
DEBUG 2017-06-10 22:52:13.072 [ping-6-1] Approximate round trip times in milli-seconds:
DEBUG 2017-06-10 22:52:13.072 [ping-6-1] Minimum = 8ms, Maximum = 197ms, Average = 71ms
DEBUG 2017-06-10 22:52:13.074 [pool-6-thread-1] est speed for 32000 22 is 9430486.486486487
DEBUG 2017-06-10 22:52:13.074 [pool-6-thread-1] Starting ping -n 3 -l 64000 192.168.1.2
DEBUG 2017-06-10 22:52:13.105 [ping-7-1]
DEBUG 2017-06-10 22:52:13.105 [ping-7-1] Pinging 192.168.1.2 with 64000 bytes of data:
DEBUG 2017-06-10 22:52:13.128 [ping-7-1] Reply from 192.168.1.2: bytes=64000 time=16ms TTL=64
DEBUG 2017-06-10 22:52:13.807 [SpeedStats Failsafe] Stopping process: ping-6
DEBUG 2017-06-10 22:52:14.138 [ping-7-1] Reply from 192.168.1.2: bytes=64000 time=15ms TTL=64
DEBUG 2017-06-10 22:52:15.323 [ping-7-1] Reply from 192.168.1.2: bytes=64000 time=198ms TTL=64
DEBUG 2017-06-10 22:52:15.323 [ping-7-1] Ping statistics for 192.168.1.2:
DEBUG 2017-06-10 22:52:15.323 [ping-7-1] Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
DEBUG 2017-06-10 22:52:15.323 [ping-7-1] Approximate round trip times in milli-seconds:
DEBUG 2017-06-10 22:52:15.323 [ping-7-1] Minimum = 15ms, Maximum = 198ms, Average = 76ms
DEBUG 2017-06-10 22:52:15.333 [pool-6-thread-1] est speed for 64000 43 is 1.7149901639344264E7
INFO 2017-06-10 22:52:15.334 [pool-6-thread-1] Renderer Smart TV has an estimated network speed of 6.852107169143743 Mb/s
DEBUG 2017-06-10 22:52:16.075 [SpeedStats Failsafe] Stopping process: ping-7
You don't need to zip the files, you can find the log file manually: "C:\ProgramData\UMS\debug.log"
What is important is that you make sure that the log is in trace mode before you replicate the problem. Then, without restarting UMS, find the file (debug.log) and attach it here.
The log you pasted doesn't have the information we need. One thing I can see from it though is that you have several instances of UMS running. If you have installed UMS as a service, please uninstall the service and restart the computer before capturing the log. You can also use Windows task manager to make sure that no java or javaw process is running before starting UMS.
Billbogz9x8
this is all i could get
from (C:\Program Files (x86)\Universal Media Server)
logback.xml
(3.9 KiB) Downloaded 371 times
logback.headless.xml
(3.51 KiB) Downloaded 403 times
Billbogz9x8
never mind got it
debug.log
(105.92 KiB) Downloaded 392 times
The log doesn't show anything of interest, so I'm not sure where to go from here. Maybe you should check Windows Event Viewer to see if you find any errors there that correspond in time with when UMS crashes.
You should also use Windows Task Manager to verify that the java/javaw process disappears when UMS closes, to confirm that it actually closes instead of that the GUI is just hidden.
ReeceK
Post by ReeceK »
Is there a solution to this yet?
My log says nothing happened, event viewer says nothing happened.........
