Version 3.4.0 is released
Fiddl3
Re: Version 3.4.0 is released
Post by Fiddl3 »
the error was caused by one of value in config file.
Mencoder as thumbinal generator in UMS 3.4 cause error.
use_mplayer_for_video_thumbs =false   #works fine
use_mplayer_for_video_thumbs =true    #error while listing video files
CappySpectrum
Post by CappySpectrum »
This release seems sweet!
I was originally on the OS X 2.6.5 version because 3.3.0 and such was giving me poor playback on the Panasonic DMP-BDT330 as that uses the Vizio renderer. So far not had any problems and fluid playback with 3.4.0.
pipin wrote:Great work. Got a new 32" Samsung and UMS works on this one without problems.
Great! Thanks for reporting this :)
Fiddl3 wrote:the error was caused by one of value in config file.
Thanks for reporting this, we are working on a fix now and will release 3.4.1 with it soon :)
CappySpectrum wrote:This release seems sweet!
Thanks a lot for the feedback :)
keefor
Post by keefor »
Seems faster browsing my libraries with this new version, previous version would take maybe 1 second or 2 but this is almost instant.
ans2012
Post by ans2012 »
it gives me this installation error: error opening file for writing: MediaInfo64.dll
emerson8
Post by emerson8 »
Im getting "filexxx.xxx could not be parsed. It will be hidden" for every single file I have.
Previously seen this maybe on some file sometimes, but now, it states that for all = only directories visible, nothing in them.
emerson8
Post by emerson8 »
Small update;
Simply re-installing 3.3.0 again ontop of 3.4.0 and all is back to normal again.
Davex3
Post by Davex3 »
Getting this error when i start playing a video.
Error adding child: "KBPS All-classical"
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:721) [ums.jar:3.4.0]
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:480) [ums.jar:3.4.0]
	at net.pms.dlna.RootFolder.addWebFolder(RootFolder.java:345) [ums.jar:3.4.0]
	at net.pms.dlna.RootFolder.discoverChildren(RootFolder.java:147) [ums.jar:3.4.0]
	at net.pms.configuration.RendererConfiguration.getRootFolder(RendererConfiguration.java:289) [ums.jar:3.4.0]
	at net.pms.PMS.getRootFolder(PMS.java:129) [ums.jar:3.4.0]
	at net.pms.network.RequestV2.answer(RequestV2.java:654) [ums.jar:3.4.0]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:295) [ums.jar:3.4.0]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:253) [ums.jar:3.4.0]
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [ums.jar:3.4.0]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [ums.jar:3.4.0]
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [ums.jar:3.4.0]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) [ums.jar:3.4.0]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [ums.jar:3.4.0]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) [ums.jar:3.4.0]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [ums.jar:3.4.0]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [ums.jar:3.4.0]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [ums.jar:3.4.0]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [ums.jar:3.4.0]
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [ums.jar:3.4.0]
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [ums.jar:3.4.0]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_51]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_51]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_51]
Gareee
Post by Gareee »
Videos playing fine here so far, but the server keeps vanishing from my ps3 slim, and I have to restart the server to make it show up again.
Also, while streaming I do not see the stream speed display updating on the status panel, but I do see the maximum speed streamed displayed.
Log available if it helps.
viewtopic.php?f=9&t=1601
pwnloiiopwn
Post by pwnloiiopwn »
Loving the updated version.
There just seems to be some sort of hiccup with my 64bit Linux Debian machine.
Tested it on my 32bit Linux Debian and everything works perfectly.
On the 64bit tsMuxer is always the one giving headaches :(
Whenever I try playing a .mkv through tsMuxer, I get some strange error with it not finding mencoder
Here attached is the debug log, hope it can shed some light:
DEBUG 2014-02-10 18:29:05.766 [New I/O worker #4] Starting transcode/remux of top_gear.20x01.720p_hdtv_x264-sample-fov.mkv with media info: container: mkv, bitrate: 3696888, size: 27800598, video codec: h264, duration: 00:01:00.00, width: 1280, height: 720, frame rate: 25.000, muxing mode: null, mime type: video/x-matroska
	Audio track id: 0, lang: und, flavor: null, audio codec: AC3, sample frequency:48000, number of channels: 2, bits per sample: 16
DEBUG 2014-02-10 18:29:05.776 [New I/O worker #4] Starting /home/xxx/.builds/ums-3.4.0/linux/ffmpeg -i /home/xxx/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv -vframes 1 -c:v copy -f h264 -bsf h264_mp4toannexb -an -y pipe:
DEBUG 2014-02-10 18:29:05.796 [Thread-81] ffmpeg version N-59597-g4ced5d7 Copyright (c) 2000-2014 the FFmpeg developers
DEBUG 2014-02-10 18:29:05.796 [Thread-81]   built on Jan  6 2014 05:20:53 with gcc 4.6 (Debian 4.6.3-1)
DEBUG 2014-02-10 18:29:05.796 [Thread-81]   configuration: --prefix=/root/ffmpeg-static/32bit --arch=x86_32 --extra-cflags='-m32 -I/root/ffmpeg-static/32bit/include -static' --extra-ldflags='-m32 -L/root/ffmpeg-static/32bit/lib -static' --extra-libs='-lxml2 -lexpat -lfreetype' --enable-static --disable-shared --disable-ffserver --disable-doc --enable-bzlib --enable-zlib --enable-postproc --enable-runtime-cpudetect --enable-libx264 --enable-gpl --enable-libtheora --enable-libvorbis --enable-libmp3lame --enable-gray --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-version3 --enable-libvpx
DEBUG 2014-02-10 18:29:05.796 [Thread-81]   libavutil      52. 62.100 / 52. 62.100
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libavcodec     55. 47.100 / 55. 47.100
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libavformat    55. 22.102 / 55. 22.102
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libavdevice    55.  5.102 / 55.  5.102
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libavfilter     4.  0.103 /  4.  0.103
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libswscale      2.  5.101 /  2.  5.101
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libswresample   0. 17.104 /  0. 17.104
DEBUG 2014-02-10 18:29:05.797 [Thread-81]   libpostproc    52.  3.100 / 52.  3.100
DEBUG 2014-02-10 18:29:05.803 [Thread-81] Input #0, matroska,webm, from '/home/xxx/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv':
DEBUG 2014-02-10 18:29:05.803 [New I/O worker #4] Attaching thread: ffmpeg-31
DEBUG 2014-02-10 18:29:05.808 [Thread-81]   Metadata:
DEBUG 2014-02-10 18:29:05.808 [New I/O worker #4] Unix process ID (/home/xxx/.builds/ums-3.4.0/linux/ffmpeg): 7524
DEBUG 2014-02-10 18:29:05.809 [Thread-81]     ENCODER         : Larry Sanders
DEBUG 2014-02-10 18:29:05.809 [Thread-81]   Duration: 00:01:00.16, start: 0.000000, bitrate: 3696 kb/s
DEBUG 2014-02-10 18:29:05.810 [Thread-81]     Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
DEBUG 2014-02-10 18:29:05.810 [Thread-81]     Stream #0:1: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
DEBUG 2014-02-10 18:29:05.811 [Thread-81] Output #0, h264, to 'pipe:':
DEBUG 2014-02-10 18:29:05.811 [Thread-81]   Metadata:
DEBUG 2014-02-10 18:29:05.811 [Thread-81]     encoder         : Lavf55.22.102
DEBUG 2014-02-10 18:29:05.812 [Thread-81]     Stream #0:0(eng): Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 25 tbc (default)
DEBUG 2014-02-10 18:29:05.812 [Thread-81] Stream mapping:
DEBUG 2014-02-10 18:29:05.812 [Thread-81]   Stream #0:0 -> #0:0 (copy)
DEBUG 2014-02-10 18:29:05.812 [Thread-81] Press [q] to stop, [?] for help
DEBUG 2014-02-10 18:29:05.813 [Thread-81] frame=    1 fps=0.0 q=-1.0 Lsize=       3kB time=00:00:00.-4 bitrate=N/A
DEBUG 2014-02-10 18:29:05.813 [Thread-81] video:3kB audio:0kB subtitle:0 global headers:0kB muxing overhead 1.281619%
DEBUG 2014-02-10 18:29:05.819 [mkfifo-35] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053345818tsmuxerout.ts
DEBUG 2014-02-10 18:29:05.820 [mkfifo-35] Unix process ID (mkfifo): 7531
DEBUG 2014-02-10 18:29:05.875 [mkfifo-36] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053345767ffmpegvideo
DEBUG 2014-02-10 18:29:05.876 [mkfifo-37] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053345767videoout
DEBUG 2014-02-10 18:29:05.883 [mkfifo-36] Unix process ID (mkfifo): 7536
DEBUG 2014-02-10 18:29:05.884 [mkfifo-37] Unix process ID (mkfifo): 7537
DEBUG 2014-02-10 18:29:06.094 [mencoder-32] Starting mencoder -ss 0 /home/xxx/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o /tmp/universalmediaserver/1392053345767ffmpegvideo
ERROR 2014-02-10 18:29:06.100 [mencoder-32] Error initializing process:
java.io.IOException: Cannot run program "mencoder": error=2, No such file or directory
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041) ~[na:1.7.0_25]
	at net.pms.io.ProcessWrapperImpl.run(ProcessWrapperImpl.java:179) ~[ums.jar:3.4.0]
Caused by: java.io.IOException: error=2, No such file or directory
	at java.lang.UNIXProcess.forkAndExec(Native Method) ~[na:1.7.0_25]
	at java.lang.UNIXProcess.<init>(UNIXProcess.java:135) ~[na:1.7.0_25]
	at java.lang.ProcessImpl.start(ProcessImpl.java:130) ~[na:1.7.0_25]
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022) ~[na:1.7.0_25]
	... 1 common frames omitted
DEBUG 2014-02-10 18:29:06.105 [Buffered IO End Checker] Stopping Unix process 7479: ffmpeg-30
DEBUG 2014-02-10 18:29:06.116 [Thread-77] Error consuming stream of spawned process: Stream closed
DEBUG 2014-02-10 18:29:06.145 [mkfifo-38] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053345817ffmpegaudio01
DEBUG 2014-02-10 18:29:06.145 [mkfifo-39] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053345817audioout
DEBUG 2014-02-10 18:29:06.148 [mkfifo-39] Unix process ID (mkfifo): 7552
DEBUG 2014-02-10 18:29:06.148 [mkfifo-38] Unix process ID (mkfifo): 7551
DEBUG 2014-02-10 18:29:06.345 [mencoder-33] Starting mencoder -ss 0 /home/xxx/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv -quiet -quiet -really-quiet -msglevel statusline=2 -channels 2 -ovc copy -of rawaudio -mc 0 -noskip -oac copy -fafmttag 0x2000 -lavcopts acodec=ac3:abitrate=448 -af lavcresample=48000 -srate 48000 -quiet -quiet -o /tmp/universalmediaserver/1392053345817ffmpegaudio01
ERROR 2014-02-10 18:29:06.347 [mencoder-33] Error initializing process:
DEBUG 2014-02-10 18:29:06.445 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:06.445 [tsMuxeR-new-34] Starting /home/xxx/.builds/ums-3.4.0/linux/tsMuxeR-new /tmp/universalmediaserver/pms-tsmuxer.meta /tmp/universalmediaserver/1392053345818tsmuxerout.ts
DEBUG 2014-02-10 18:29:06.446 [tsMuxeR-new-34] Reading pipe: /tmp/universalmediaserver/1392053345818tsmuxerout.ts
DEBUG 2014-02-10 18:29:06.945 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:07.446 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
INFO  2014-02-10 18:29:07.613 [StopPlaying Event] Stopped playing top_gear.20x01.720p_hdtv_x264-sample-fov.mkv on your PlayStation 3
DEBUG 2014-02-10 18:29:07.614 [StopPlaying Event] The full filename of which is: /home/xxx/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv and the address of the renderer is: 192.168.1.128
DEBUG 2014-02-10 18:29:07.946 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:08.319 [Buffered IO End Checker] Stopping Unix process 7524: ffmpeg-31
DEBUG 2014-02-10 18:29:08.446 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:08.947 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:09.447 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:09.947 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:10.448 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:10.948 [New I/O worker #4] External input stream instance is null... sounds not good, waiting 500ms
ERROR 2014-02-10 18:29:11.449 [New I/O worker #4] There is no inputstream to return for top_gear.20x01.720p_hdtv_x264-sample-fov.mkv [tsMuxeR] {Audio: AC3}
ERROR 2014-02-10 18:29:11.449 [Hanging External Process Stopper] External input stream instance is null... stopping process
DEBUG 2014-02-10 18:29:11.452 [Hanging External Process Stopper] Stopping Unix process 7561: tsMuxeR-new-34
DEBUG 2014-02-10 18:29:11.452 [Hanging External Process Stopper] Stopping Unix process 7531: mkfifo-35
DEBUG 2014-02-10 18:29:11.458 [New I/O worker #1] Starting transcode/remux of top_gear.20x01.720p_hdtv_x264-sample-fov.mkv with media info: container: mkv, bitrate: 3696888, size: 27800598, video codec: h264, duration: 00:01:00.00, width: 1280, height: 720, frame rate: 25.000, muxing mode: null, mime type: video/x-matroska
DEBUG 2014-02-10 18:29:11.464 [mkfifo-47] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053351463tsmuxerout.ts
DEBUG 2014-02-10 18:29:11.471 [mkfifo-47] Unix process ID (mkfifo): 7577
DEBUG 2014-02-10 18:29:11.514 [mkfifo-48] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053351462ffmpegvideo
DEBUG 2014-02-10 18:29:11.514 [mkfifo-49] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053351462videoout
DEBUG 2014-02-10 18:29:11.517 [mkfifo-49] Unix process ID (mkfifo): 7583
DEBUG 2014-02-10 18:29:11.518 [mkfifo-48] Unix process ID (mkfifo): 7582
DEBUG 2014-02-10 18:29:11.715 [mencoder-44] Starting mencoder -ss 0 /home/xxx/Top.Gear.S20.720p.HDTV.x264-SceneHD/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o /tmp/universalmediaserver/1392053351462ffmpegvideo
ERROR 2014-02-10 18:29:11.717 [mencoder-44] Error initializing process:
DEBUG 2014-02-10 18:29:11.765 [mkfifo-50] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053351462ffmpegaudio01
DEBUG 2014-02-10 18:29:11.765 [mkfifo-51] Starting mkfifo --mode=777 /tmp/universalmediaserver/1392053351462audioout
DEBUG 2014-02-10 18:29:11.768 [mkfifo-51] Unix process ID (mkfifo): 7594
DEBUG 2014-02-10 18:29:11.772 [mkfifo-50] Unix process ID (mkfifo): 7593
DEBUG 2014-02-10 18:29:11.966 [mencoder-45] Starting mencoder -ss 0 /home/xxx/Top_Gear.20x01.720p_HDTV_x264-FoV/Sample/top_gear.20x01.720p_hdtv_x264-sample-fov.mkv -quiet -quiet -really-quiet -msglevel statusline=2 -channels 2 -ovc copy -of rawaudio -mc 0 -noskip -oac copy -fafmttag 0x2000 -lavcopts acodec=ac3:abitrate=448 -af lavcresample=48000 -srate 48000 -quiet -quiet -o /tmp/universalmediaserver/1392053351462ffmpegaudio01
ERROR 2014-02-10 18:29:11.967 [mencoder-45] Error initializing process:
DEBUG 2014-02-10 18:29:12.066 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:12.066 [tsMuxeR-new-46] Starting /home/belva/.builds/ums-3.4.0/linux/tsMuxeR-new /tmp/universalmediaserver/pms-tsmuxer.meta /tmp/universalmediaserver/1392053351463tsmuxerout.ts
DEBUG 2014-02-10 18:29:12.067 [tsMuxeR-new-46] Reading pipe: /tmp/universalmediaserver/1392053351463tsmuxerout.ts
DEBUG 2014-02-10 18:29:12.566 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:13.066 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:13.567 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:14.067 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:14.567 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:15.068 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:15.568 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:16.068 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-02-10 18:29:16.569 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
ERROR 2014-02-10 18:29:17.069 [New I/O worker #1] There is no inputstream to return for top_gear.20x01.720p_hdtv_x264-sample-fov.mkv [tsMuxeR] {Audio: AC3}
ERROR 2014-02-10 18:29:17.069 [Hanging External Process Stopper] External input stream instance is null... stopping process
DEBUG 2014-02-10 18:29:17.071 [Hanging External Process Stopper] Stopping Unix process 7603: tsMuxeR-new-46
DEBUG 2014-02-10 18:29:17.072 [Hanging External Process Stopper] Stopping Unix process 7577: mkfifo-47
DEBUG 2014-02-10 18:30:27.724 [UPNP-AliveMessageSender] Sending ALIVE...
