Problem with unwanted transcoding
Re: Problem with unwanted transcoding
Oh, sorry the GUI did launch :/ woops, i forgot i had it minized.
Anyways, i did wait to turn on my TV's as you suggested, but it gives same result.
From the TV i can see Universal Media Server, but when i select it, it just says "No content is available". ( Same thing when i try from my Sony TV )
I can see the Server in Chrome browser, but i can not browse the server ( it gives me browser-error: ERR_TOO_MANY_REDIRECTS )
I chose/selected the path by using UMS GUI.
I made sure that there's actual content/files in the folder.
- ums_dbg_2018-06-24-23-30-33.zip
- (52.68 KiB) Downloaded 346 times
Is W:/Test a remote mounted folder or a USB drive? Can you try with some local shared folder?
W:\Test is a local folder.
It has subfolders containing "normal" files that normally plays with UMS.
