[Solved] No ISO or VOB Support on PS3 after installing 5.2.x
chrisl
Re: No ISO or VOB Support on PS3 after installing 5.2.x
Post by chrisl »
Thanks very much SubJunk !
I can't reproduce the issue - my DVDs work on all the versions mentioned. So I need you guys to test some custom versions for me and hopefully we can narrow it down like that. Here are three builds, please let me know which one/s work:
http://www.spirton.com/uploads/UMS/UMS-5295613.exe
http://www.spirton.com/uploads/UMS/UMS-025ad1e.exe
http://www.spirton.com/uploads/UMS/UMS-2a04ce0.exe
chrisl
Post by chrisl »
I am on OSX ...
snakebyte
Post by snakebyte »
Hello Subjunk,
The UMS-025ad1e seems to work for me while using OSX El Capitan and PS4.
Finally the ISO-VOB files play with subtitles while transcoded through mencoder.
Thanks a million times :lol: :lol: :lol: :lol:
Have a good 2016 and be sure to know you helped my year start on a good note.
Greetssssssssssssss,
Snakebyte
Hi snakebyte, what about the other 2 files? It would be strange if that was the only one that worked
snakebyte
Post by snakebyte »
SubJunk,
The http://www.spirton.com/uploads/UMS/UMS-2a04ce0.dmg version did not work for me.
The other one I did not test yet , but I will do on a later time and keep you posted on this , but first I have some newyears party's to attend.
Happy New Year !!!!!
Greetssssssssss Snakebyte
chrisl
Post by chrisl »
Thanks for your support SubJunk, and sorry for the delay.
So, I'm on OSX 10.9.5 and PS3.
UMS-2a04ce0 and UMS-5295613 work perfectly with ISOs and VOBs.
With UMS-025ad1e, I could not really test it because I get "DLNA protocol error 7522" and cannot list the movies ...
By the way, Happy New Year to everybody here :-)
snakebyte
Post by snakebyte »
Hey Subjunk,
Tested the http://www.spirton.com/uploads/UMS/UMS-5295613.dmg build , but this shows the files ,but won't play them on the PS4.
So for now only the http://www.spirton.com/uploads/UMS/UMS-025ad1e.dmg does work for me.
When I've got some more time on my hand ,I will provide you with logs.
Greetsssssssss Snakebyte
So it seems a bit inconsistent, with different people getting different results. The tool we use for this, MPlayer, seems to have that inconsistency. Can you try the latest version of UMS and just try it 5 times, see if it works sometimes?
