Videos defualt to mpeg not AVC UMS 6.60 ps3
jp0213x
Re: Videos defualt to mpeg not AVC UMS 6.60 ps3
Post by jp0213x »
These are the settings with your new config. Video plays again
jp0213x
Post by jp0213x »
Would you like me to install 5.1.3 back and post logs? Everything works correctly with that version for some reason without making any edits to any config file. Also my radio streams in the web config stopped working through my Yamaha receiver. It was working before, not sure why Phillips-streamium show for my Yamaha receiver
Sami32
Post by Sami32 »
No.
Don't mix things. We are only trying to debug your PS3 and testing different configurations.
First you'll need to try that one: download/file.php?id=3779
jp0213x
Post by jp0213x »
Here are the logs
Sami32
Post by Sami32 »
Better if you say what is different, as i'm not going to search in your log...
Try that one:
UMS.conf
(38.9 KiB) Downloaded 451 times
jp0213x
Post by jp0213x »
Sami32 wrote:Better if you say what is different, as i'm not going to search in your log...
Try that one:
UMS.conf
Video and subs play. I would need you to look at the logs from 5.13 as well to see what the difference is. Compare logs. If I play this same show with internal subs with 5.13, ffmpeg will be the default automatically with subs turned on. All non sub shows will play under AVC which I prefer.
jp0213x
Post by jp0213x »
Sami32 wrote:So, you mean that now everything work fine, right ?
No, something in the code with 5.1.3 works perfectly that doesn't with 6.60, I would need you to compare logs to see what the difference is.
