Version 6.7.3 released
Post by SubJunk » Sun Aug 13, 2017 12:23 pm
General:
It adds support for new devices, bugfixes, and improvements.
Changes since 6.7.2:
  • General:
    • Improved support for AVI and MJPEG
    • Improved general DLNA implementation
    • Fixed duplicate entries in transcode folders
    • Fixed logging in macOS
    • Fixed menu name in macOS
  • Renderers:
    • Added renderer configuration for conversion of 3D video to 2D
    • Added support for Fetch TV
    • Added support for Onkyo TXNR8xx
    • Improved support for Cambridge Audio Azur BD
    • Improved support for OPPO BDP
    • Improved support for Panasonic VIERA TXL32V10E
    • Improved support for Sony BRAVIA 5500 and EX TVs
    • Improved support for Sony SMP-N100
    • Improved support for Sony STR-DA5800ES
    • Fixed album art for Onkyo receivers (and probably others)
    • Fixed support for Xbox 360
  • Dependencies:
    • Updated MediaInfo to 0.7.97, which:
      • Improves support for HEVC (H.265), FLV, MKV, TIFF and more
Compatibility notes:
The Windows releases work on Windows Vista onwards. We are working on supporting older versions.
snakebyte
Re: Version 6.7.3 released
Post by snakebyte » Sun Aug 13, 2017 8:25 pm
Hey SubJunk,
I tried to download this new release on my mac running the latest Sierra, but the dmg file won't open no matter which browser I use for downlowading, either Safari or Firefox.
Could there be somthing wrong with the dmg ?
Greetssssssssssssss Snakebyte.
Solved !!!
erick diangilis
Post by erick diangilis » Mon Aug 14, 2017 4:02 am
hi subjunk i got the Windows version is ok to download. is this version only compatible with java 7 and 8 or i can use 9 early acess too?
robertc99
Post by robertc99 » Mon Aug 14, 2017 8:54 am
The changelog mentions FetchTV. I had a look in the fetch renderer, it also mentoins "Fetch Mighty".
My Fetch Mighty isnt recognised.
06:47:43 INFO Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: Linux/3.14.28-1.6, UPnP/1.0, DLNADOC/1.50
pipin
Post by pipin » Tue Aug 15, 2017 8:33 pm
Thanks für the release.
But I have the same problem as with 7.0.0-rc1. Both my Samsung TV's won't show thumbnails any more.
Regards,
Jens
pvw
Post by pvw » Mon Aug 21, 2017 6:48 pm
Hi
I have the same problem with my Fetch Mighty. (Mac version)
I get the same message in the Log
UMS shows up on the Fetch box
Update:
After highlighting a movie on the Fetch, the Fetch icon displayed in the application
Thanks in Advance
horrible
Post by horrible » Tue Aug 22, 2017 8:15 am
h.265 10bits problems. h.265 8bits works fine.
J_345
Post by J_345 » Mon Aug 28, 2017 10:22 pm
Has anyone had probelms with java 8 update 144 if i update java to that version UMS stops working will not open at all but if i delete java 8 144 and open UMS and let the app prompt the right java version download it downloads java 7.0+ which turns out to be java 8 update 121 and everything works prefect was just curious as to why because i assume its always good to have the latest java but to me not at a cost of UMS not working lol. So i always get promts to update java is this a issue that can be fixed in a UMS update or is it a java probelm thanks as stated the fix is to stay with a older version of java for now i guess was just curious.
mykee
Post by mykee » Wed Aug 30, 2017 7:28 am
I have many problem with Samsung D5500 too:
- no thumbnails
- sort is not working
- updated srt files no see on my TV (hasn't subtitle there or my TV cannot see this .srt file).
With 6.7.2 version no problem, all things is correct.
valib
Post by valib » Thu Aug 31, 2017 10:17 am
How can we help without the log?
