Samsung UE40B7000WW
Samsung UE40B7000WW
This is a Samsung LED Series 7 TV. I have been fighting a lot with PS3 Media Server and now with UMS to find a way to scale videos to fix the monitor (1280x720). For some stream the scaler was not working (0x00, your Video Scaler setting) and format not supported was the error message appearing on the screen.
At the end I discoverd that for this type of tv the renderer Samsung SMT-G7400 is working much better and the scaling is working smoothly.
The only issue I've encountered is the following error message in the log file:
Process /opt/ums-2.6.5/mplayer has a return code of 1! Maybe an error occurred... check the log file
but I don't know if it is related to the render type or it is a bug. I did not noticed that in PS3.
Re: Samsung UE40B7000WW
Conserning the error about mplayer I have temporary solved by substituting mplayer with the one in /usr/share/mplayer
what were the Version differences between the two mPlayer versions?
just being currious
just being currious
Universal Media Server Wiki!
This is the version installed in ubuntu under /usr/bin/mplayer:
MPlayer svn r34540 (Ubuntu), built with gcc-4.7 (C) 2000-2012 MPlayer Team
Can you attach your Log Files here?
