Can connect to my PS3 but not my Vizio 65"
I'm using a M3D650SV Vizio set a notebook running XP with a C1000 Modem/router from CenturyLink/ ActionTec. I've researched and tried to just the Vizio Smart TV config by itself to no avail. I've also tried that custom config file for Viz that I found over at PS3MS and still nothing. That said, UMS and PS3MS both find my PS3 and streams fine but when I go to the Media widget on the TV I can't find anything. The PS3 is in my kids room so I don't really want to have to move it from there all the time but nothing I've tried will recognize the Viz as a renderer. Here's the debug with all the configs, just the Viz, and the custom Viz.
Default Viz:
Custom Viz:
INFO 2013-09-16 23:33:43.578 [main] Starting Universal Media Server 2.6.5
INFO 2013-09-16 23:33:43.609 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-09-16 23:33:43.609 [main] http://www.universalmediaserver.com
INFO 2013-09-16 23:33:43.609 [main] Build: 54bd7b6d1 (2013-06-06)
INFO 2013-09-16 23:33:43.609 [main] Java: 1.7.0_21-Oracle Corporation
INFO 2013-09-16 23:33:43.609 [main] OS: Windows XP 32-bit 5.1
INFO 2013-09-16 23:33:43.609 [main] Encoding: UTF-8
INFO 2013-09-16 23:33:43.609 [main] Memory: 742 MB
INFO 2013-09-16 23:33:43.609 [main] Working directory: C:\Program Files\Universal Media Server
INFO 2013-09-16 23:33:43.625 [main] Temp directory: C:\Temp\universalmediaserver
INFO 2013-09-16 23:33:43.625 [main] Logging config file: C:\Program Files\Universal Media Server\logback.xml
INFO 2013-09-16 23:33:43.625 [main] debug.log: C:\Program Files\Universal Media Server\debug.log
INFO 2013-09-16 23:33:43.625 [main] Profile directory: C:\Documents and Settings\All Users\UMS
INFO 2013-09-16 23:33:43.625 [main] Profile path: C:\Documents and Settings\All Users\UMS\UMS.conf
INFO 2013-09-16 23:33:43.625 [main] Profile permissions: rw
INFO 2013-09-16 23:33:43.640 [main] Profile name: Dd47xn4k1
INFO 2013-09-16 23:33:43.640 [main] Loading MediaInfo library
INFO 2013-09-16 23:33:43.859 [main] Loaded MediaInfoLib - v0.7.63
INFO 2013-09-16 23:33:43.859 [main] Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
INFO 2013-09-16 23:33:43.859 [main] Loading configuration file: AirPlayer.conf
INFO 2013-09-16 23:33:43.859 [main] Loading configuration file: Android.conf
INFO 2013-09-16 23:33:43.875 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO 2013-09-16 23:33:43.890 [main] Loading configuration file: Bravia4500.conf
INFO 2013-09-16 23:33:43.890 [main] Loading configuration file: Bravia5500.conf
INFO 2013-09-16 23:33:43.890 [main] Loading configuration file: BraviaEX.conf
INFO 2013-09-16 23:33:43.890 [main] Loading configuration file: BraviaEX620.conf
INFO 2013-09-16 23:33:43.890 [main] Loading configuration file: BraviaHX.conf
INFO 2013-09-16 23:33:43.890 [main] Loading configuration file: DirecTVHR.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: DLinkDSM510.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: FreeboxHD.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: iPad-iPhone.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: Kuro.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: LGST600.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: N900.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: NetgearNeoTV.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: OPPOBDP83.conf
INFO 2013-09-16 23:33:43.906 [main] Loading configuration file: OPPOBDP93.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: Panasonic.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: Philips.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: PhilipsPFL.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: PopcornHour.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: PS3.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: Realtek.conf
INFO 2013-09-16 23:33:43.921 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2013-09-16 23:33:43.937 [main] Loading configuration file: SamsungAllShare.conf
INFO 2013-09-16 23:33:43.937 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2013-09-16 23:33:44.000 [main] Loading configuration file: SharpAquos.conf
INFO 2013-09-16 23:33:44.000 [main] Loading configuration file: Showtime3.conf
INFO 2013-09-16 23:33:44.000 [main] Loading configuration file: Showtime4.conf
INFO 2013-09-16 23:33:44.000 [main] Loading configuration file: SMP-N100.conf
INFO 2013-09-16 23:33:44.000 [main] Loading configuration file: SonyBluray.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: Streamium.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: TelstraTbox.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: VideoWebTV.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: vizio.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: VizioSmartTV.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: WDTVLive.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: WMP.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: XBMC.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: XBOX360.conf
INFO 2013-09-16 23:33:44.015 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2013-09-16 23:33:44.031 [main] Loading configuration file: YamahaRXV3900.conf
INFO 2013-09-16 23:33:44.031 [main] Loading configuration file: YamahaRXV671.conf
INFO 2013-09-16 23:33:44.031 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-09-16 23:33:44.031 [main] Launching: win32/mplayer.exe
DEBUG 2013-09-16 23:33:44.156 [main] Launching: win32/mplayer.exe
INFO 2013-09-16 23:33:44.312 [main] Finished checking the MPlayer font cache.
DEBUG 2013-09-16 23:33:44.312 [main] AviSynth plugins directory: C:\Program Files\AviSynth\plugins
INFO 2013-09-16 23:33:44.312 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO 2013-09-16 23:33:44.312 [main] Found VideoLAN version 0.8.6f at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-16 23:33:44.312 [main] Searching for plugins in C:\Program Files\Universal Media Server\plugins
INFO 2013-09-16 23:33:44.312 [main] No plugins found
INFO 2013-09-16 23:33:44.328 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2013-09-16 23:33:44.328 [main] Registering transcoding engine: FFmpeg Audio
INFO 2013-09-16 23:33:44.343 [main] Registering transcoding engine: MEncoder
INFO 2013-09-16 23:33:44.343 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2013-09-16 23:33:44.343 [main] Registering transcoding engine: FFmpeg
INFO 2013-09-16 23:33:44.343 [main] Registering transcoding engine: MPlayer Audio
DEBUG 2013-09-16 23:33:44.421 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms, https]
INFO 2013-09-16 23:33:44.421 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2013-09-16 23:33:44.421 [main] Registering transcoding engine: MEncoder Web
INFO 2013-09-16 23:33:44.421 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2013-09-16 23:33:44.421 [main] Registering transcoding engine: MPlayer Web
INFO 2013-09-16 23:33:44.421 [main] Registering transcoding engine: tsMuxeR
INFO 2013-09-16 23:33:44.437 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-09-16 23:33:44.437 [main] Found VLC version 0.8.6f in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-16 23:33:44.437 [main] Registering transcoding engine: VLC Audio Streaming
INFO 2013-09-16 23:33:44.437 [main] Registering transcoding engine: VLC Video Streaming
INFO 2013-09-16 23:33:44.437 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2013-09-16 23:33:44.437 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2013-09-16 23:33:44.484 [main] Using address /192.168.0.22 found on network interface: name:eth0 (Intel(R) WiFi Link 5100 AGN - Packet Scheduler Miniport)
INFO 2013-09-16 23:33:44.484 [main] Created socket: /192.168.0.22:5001
DEBUG 2013-09-16 23:33:44.593 [main] Sending ALIVE...
INFO 2013-09-16 23:33:44.593 [main] Using the following UUID configured in UMS.conf: 2490fbc9-cf94-4606-9976-8db5994fc68e
INFO 2013-09-16 23:33:44.843 [main] The server is now available for renderers to find
DEBUG 2013-09-16 23:33:54.843 [UPNP-AliveMessageSender] Sending ALIVE...
Default Viz:
INFO 2013-09-16 23:36:13.765 [main] Starting Universal Media Server 2.6.5
INFO 2013-09-16 23:36:13.765 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-09-16 23:36:13.781 [main] http://www.universalmediaserver.com
INFO 2013-09-16 23:36:13.781 [main] Build: 54bd7b6d1 (2013-06-06)
INFO 2013-09-16 23:36:13.781 [main] Java: 1.7.0_21-Oracle Corporation
INFO 2013-09-16 23:36:13.781 [main] OS: Windows XP 32-bit 5.1
INFO 2013-09-16 23:36:13.781 [main] Encoding: UTF-8
INFO 2013-09-16 23:36:13.781 [main] Memory: 742 MB
INFO 2013-09-16 23:36:13.781 [main] Working directory: C:\Program Files\Universal Media Server
INFO 2013-09-16 23:36:13.781 [main] Temp directory: C:\Temp\universalmediaserver
INFO 2013-09-16 23:36:13.781 [main] Logging config file: C:\Program Files\Universal Media Server\logback.xml
INFO 2013-09-16 23:36:13.781 [main] debug.log: C:\Program Files\Universal Media Server\debug.log
INFO 2013-09-16 23:36:13.781 [main] Profile directory: C:\Documents and Settings\All Users\UMS
INFO 2013-09-16 23:36:13.781 [main] Profile path: C:\Documents and Settings\All Users\UMS\UMS.conf
INFO 2013-09-16 23:36:13.781 [main] Profile permissions: rw
INFO 2013-09-16 23:36:13.796 [main] Profile name: Dd47xn4k1
INFO 2013-09-16 23:36:13.796 [main] Loading MediaInfo library
INFO 2013-09-16 23:36:14.078 [main] Loaded MediaInfoLib - v0.7.63
INFO 2013-09-16 23:36:14.093 [main] Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
INFO 2013-09-16 23:36:14.093 [main] Loading configuration file: VizioSmartTV.conf
INFO 2013-09-16 23:36:14.093 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-09-16 23:36:14.093 [main] Launching: win32/mplayer.exe
DEBUG 2013-09-16 23:36:14.250 [main] Launching: win32/mplayer.exe
INFO 2013-09-16 23:36:14.390 [main] Finished checking the MPlayer font cache.
DEBUG 2013-09-16 23:36:14.390 [main] AviSynth plugins directory: C:\Program Files\AviSynth\plugins
INFO 2013-09-16 23:36:14.390 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO 2013-09-16 23:36:14.390 [main] Found VideoLAN version 0.8.6f at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-16 23:36:14.390 [main] Searching for plugins in C:\Program Files\Universal Media Server\plugins
INFO 2013-09-16 23:36:14.390 [main] No plugins found
INFO 2013-09-16 23:36:14.468 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2013-09-16 23:36:14.468 [main] Registering transcoding engine: FFmpeg Audio
INFO 2013-09-16 23:36:14.468 [main] Registering transcoding engine: MEncoder
INFO 2013-09-16 23:36:14.468 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2013-09-16 23:36:14.468 [main] Registering transcoding engine: MPlayer Audio
DEBUG 2013-09-16 23:36:14.578 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms, https]
INFO 2013-09-16 23:36:14.578 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2013-09-16 23:36:14.578 [main] Registering transcoding engine: MEncoder Web
INFO 2013-09-16 23:36:14.578 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2013-09-16 23:36:14.578 [main] Registering transcoding engine: MPlayer Web
INFO 2013-09-16 23:36:14.593 [main] Registering transcoding engine: tsMuxeR
INFO 2013-09-16 23:36:14.593 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-09-16 23:36:14.593 [main] Found VLC version 0.8.6f in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-16 23:36:14.593 [main] Registering transcoding engine: VLC Audio Streaming
INFO 2013-09-16 23:36:14.593 [main] Registering transcoding engine: VLC Video Streaming
INFO 2013-09-16 23:36:14.593 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2013-09-16 23:36:14.593 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2013-09-16 23:36:14.640 [main] Using address /192.168.0.22 found on network interface: name:eth0 (Intel(R) WiFi Link 5100 AGN - Packet Scheduler Miniport)
INFO 2013-09-16 23:36:14.640 [main] Created socket: /192.168.0.22:5001
DEBUG 2013-09-16 23:36:14.750 [main] Sending ALIVE...
INFO 2013-09-16 23:36:14.765 [main] Using the following UUID configured in UMS.conf: 2490fbc9-cf94-4606-9976-8db5994fc68e
INFO 2013-09-16 23:36:15.015 [main] The server is now available for renderers to find
DEBUG 2013-09-16 23:36:25.015 [UPNP-AliveMessageSender] Sending ALIVE...
INFO 2013-09-16 23:37:48.281 [main] Starting Universal Media Server 2.6.5
INFO 2013-09-16 23:37:48.281 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-09-16 23:37:48.281 [main] http://www.universalmediaserver.com
INFO 2013-09-16 23:37:48.296 [main]
INFO 2013-09-16 23:37:48.296 [main] Build: 54bd7b6d1 (2013-06-06)
INFO 2013-09-16 23:37:48.296 [main] Java: 1.7.0_21-Oracle Corporation
INFO 2013-09-16 23:37:48.296 [main] OS: Windows XP 32-bit 5.1
INFO 2013-09-16 23:37:48.296 [main] Encoding: UTF-8
INFO 2013-09-16 23:37:48.296 [main] Memory: 742 MB
INFO 2013-09-16 23:37:48.296 [main] Working directory: C:\Program Files\Universal Media Server
INFO 2013-09-16 23:37:48.296 [main] Temp directory: C:\Temp\universalmediaserver
INFO 2013-09-16 23:37:48.296 [main] Logging config file: C:\Program Files\Universal Media Server\logback.xml
INFO 2013-09-16 23:37:48.296 [main] debug.log: C:\Program Files\Universal Media Server\debug.log
INFO 2013-09-16 23:37:48.296 [main] Profile directory: C:\Documents and Settings\All Users\UMS
INFO 2013-09-16 23:37:48.296 [main] Profile path: C:\Documents and Settings\All Users\UMS\UMS.conf
INFO 2013-09-16 23:37:48.296 [main] Profile permissions: rw
INFO 2013-09-16 23:37:48.312 [main] Profile name: Dd47xn4k1
INFO 2013-09-16 23:37:48.312 [main] Loading MediaInfo library
INFO 2013-09-16 23:37:48.437 [main] Loaded MediaInfoLib - v0.7.63
INFO 2013-09-16 23:37:48.453 [main] Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
INFO 2013-09-16 23:37:48.453 [main] Loading configuration file: vizio.conf
INFO 2013-09-16 23:37:48.453 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-09-16 23:37:48.453 [main] Launching: win32/mplayer.exe
DEBUG 2013-09-16 23:37:48.609 [main] Launching: win32/mplayer.exe
INFO 2013-09-16 23:37:48.734 [main] Finished checking the MPlayer font cache.
DEBUG 2013-09-16 23:37:48.734 [main] AviSynth plugins directory: C:\Program Files\AviSynth\plugins
INFO 2013-09-16 23:37:48.734 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO 2013-09-16 23:37:48.734 [main] Found VideoLAN version 0.8.6f at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-16 23:37:48.750 [main] Searching for plugins in C:\Program Files\Universal Media Server\plugins
INFO 2013-09-16 23:37:48.750 [main] No plugins found
INFO 2013-09-16 23:37:48.812 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2013-09-16 23:37:48.812 [main] Registering transcoding engine: FFmpeg Audio
INFO 2013-09-16 23:37:48.812 [main] Registering transcoding engine: MEncoder
INFO 2013-09-16 23:37:48.812 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2013-09-16 23:37:48.828 [main] Registering transcoding engine: MPlayer Audio
DEBUG 2013-09-16 23:37:48.906 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms, https]
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: MEncoder Web
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: MPlayer Web
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: tsMuxeR
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-09-16 23:37:48.906 [main] Found VLC version 0.8.6f in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: VLC Audio Streaming
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: VLC Video Streaming
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2013-09-16 23:37:48.906 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2013-09-16 23:37:48.968 [main] Using address /192.168.0.22 found on network interface: name:eth0 (Intel(R) WiFi Link 5100 AGN - Packet Scheduler Miniport)
INFO 2013-09-16 23:37:48.968 [main] Created socket: /192.168.0.22:5001
DEBUG 2013-09-16 23:37:49.062 [main] Sending ALIVE...
INFO 2013-09-16 23:37:49.062 [main] Using the following UUID configured in UMS.conf: 2490fbc9-cf94-4606-9976-8db5994fc68e
INFO 2013-09-16 23:37:49.312 [main] The server is now available for renderers to find
DEBUG 2013-09-16 23:37:59.312 [UPNP-AliveMessageSender] Sending ALIVE...
Re: Can connect to my PS3 but not my Vizio 65"
Copying the InfoLog in the main UMS screen wont help identify the Render User-Agent.
You'll have to review the Debug.log to see the Nitty-Gritty details of the USER-Agent then you can build a CONF around that and what ever the Visio tv can render... a simple Google search returned this result for your TV:
http://store.vizio.com/m3d650sv.html
No where in Visio's site does it say what it can handle as far as like MPEG-4 AAC or anything...
ExSport nailed it tbh:
ExSport wrote: TRANSCODE folder gives you combination of all engines/audio/subtitle tracks so you can select what you need (if wrong subs/audio is played or if file doesn't play so you can test another engine etc...)
Universal Media Server Wiki!
Here is the debug file:
That said, I've seen lots of other people do it (which Vizio doesn't say it will) and I can play video if I connect a USB drive to it however, that's what I am trying to avoid.
INFO 2013-09-20 00:12:34.921 [main] Starting Universal Media Server 2.6.5
INFO 2013-09-20 00:12:34.921 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-09-20 00:12:34.921 [main] http://www.universalmediaserver.com
INFO 2013-09-20 00:12:34.921 [main] Build: 54bd7b6d1 (2013-06-06)
INFO 2013-09-20 00:12:34.921 [main] Java: 1.7.0_21-Oracle Corporation
INFO 2013-09-20 00:12:34.921 [main] OS: Windows XP 32-bit 5.1
INFO 2013-09-20 00:12:34.921 [main] Encoding: UTF-8
INFO 2013-09-20 00:12:34.921 [main] Memory: 742 MB
INFO 2013-09-20 00:12:34.921 [main] Working directory: C:\Program Files\Universal Media Server
INFO 2013-09-20 00:12:35.000 [main] Temp directory: C:\Temp\universalmediaserver
INFO 2013-09-20 00:12:35.000 [main] Logging config file: C:\Program Files\Universal Media Server\logback.xml
INFO 2013-09-20 00:12:35.000 [main] debug.log: C:\Program Files\Universal Media Server\debug.log
INFO 2013-09-20 00:12:35.000 [main] Profile directory: C:\Documents and Settings\All Users\UMS
INFO 2013-09-20 00:12:35.000 [main] Profile path: C:\Documents and Settings\All Users\UMS\UMS.conf
INFO 2013-09-20 00:12:35.015 [main] Profile permissions: rw
INFO 2013-09-20 00:12:35.015 [main] Profile name: Dd47xn4k1
INFO 2013-09-20 00:12:35.062 [main] Loading MediaInfo library
INFO 2013-09-20 00:12:35.781 [main] Loaded MediaInfoLib - v0.7.63
INFO 2013-09-20 00:12:35.796 [main] Loading renderer configurations from C:\Program Files\Universal Media Server\renderers
INFO 2013-09-20 00:12:35.796 [main] Loading configuration file: AirPlayer.conf
INFO 2013-09-20 00:12:35.859 [main] Loading configuration file: Android.conf
INFO 2013-09-20 00:12:35.875 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO 2013-09-20 00:12:35.890 [main] Loading configuration file: Bravia4500.conf
INFO 2013-09-20 00:12:35.890 [main] Loading configuration file: Bravia5500.conf
INFO 2013-09-20 00:12:35.906 [main] Loading configuration file: BraviaEX.conf
INFO 2013-09-20 00:12:35.906 [main] Loading configuration file: BraviaEX620.conf
INFO 2013-09-20 00:12:35.921 [main] Loading configuration file: BraviaHX.conf
INFO 2013-09-20 00:12:35.937 [main] Loading configuration file: DirecTVHR.conf
INFO 2013-09-20 00:12:35.953 [main] Loading configuration file: DLinkDSM510.conf
INFO 2013-09-20 00:12:35.953 [main] Loading configuration file: FreeboxHD.conf
INFO 2013-09-20 00:12:35.968 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2013-09-20 00:12:35.968 [main] Loading configuration file: iPad-iPhone.conf
INFO 2013-09-20 00:12:35.984 [main] Loading configuration file: Kuro.conf
INFO 2013-09-20 00:12:35.984 [main] Loading configuration file: LGST600.conf
INFO 2013-09-20 00:12:36.000 [main] Loading configuration file: N900.conf
INFO 2013-09-20 00:12:36.000 [main] Loading configuration file: NetgearNeoTV.conf
INFO 2013-09-20 00:12:36.000 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO 2013-09-20 00:12:36.000 [main] Loading configuration file: OPPOBDP83.conf
INFO 2013-09-20 00:12:36.015 [main] Loading configuration file: OPPOBDP93.conf
INFO 2013-09-20 00:12:36.031 [main] Loading configuration file: Panasonic.conf
INFO 2013-09-20 00:12:36.031 [main] Loading configuration file: Philips.conf
INFO 2013-09-20 00:12:36.046 [main] Loading configuration file: PhilipsPFL.conf
INFO 2013-09-20 00:12:36.062 [main] Loading configuration file: PopcornHour.conf
INFO 2013-09-20 00:12:36.062 [main] Loading configuration file: PS3.conf
INFO 2013-09-20 00:12:36.093 [main] Loading configuration file: Realtek.conf
INFO 2013-09-20 00:12:36.109 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2013-09-20 00:12:36.218 [main] Loading configuration file: SamsungAllShare.conf
INFO 2013-09-20 00:12:36.218 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2013-09-20 00:12:36.218 [main] Loading configuration file: SharpAquos.conf
INFO 2013-09-20 00:12:36.250 [main] Loading configuration file: Showtime3.conf
INFO 2013-09-20 00:12:36.250 [main] Loading configuration file: Showtime4.conf
INFO 2013-09-20 00:12:36.265 [main] Loading configuration file: SMP-N100.conf
INFO 2013-09-20 00:12:36.265 [main] Loading configuration file: SonyBluray.conf
INFO 2013-09-20 00:12:36.281 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO 2013-09-20 00:12:36.296 [main] Loading configuration file: Streamium.conf
INFO 2013-09-20 00:12:36.312 [main] Loading configuration file: TelstraTbox.conf
INFO 2013-09-20 00:12:36.312 [main] Loading configuration file: VideoWebTV.conf
INFO 2013-09-20 00:12:36.312 [main] Loading configuration file: VizioSmartTV.conf
INFO 2013-09-20 00:12:36.328 [main] Loading configuration file: WDTVLive.conf
INFO 2013-09-20 00:12:36.328 [main] Loading configuration file: WMP.conf
INFO 2013-09-20 00:12:36.343 [main] Loading configuration file: XBMC.conf
INFO 2013-09-20 00:12:36.343 [main] Loading configuration file: XBOX360.conf
INFO 2013-09-20 00:12:36.359 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2013-09-20 00:12:36.359 [main] Loading configuration file: YamahaRXV3900.conf
INFO 2013-09-20 00:12:36.421 [main] Loading configuration file: YamahaRXV671.conf
INFO 2013-09-20 00:12:36.421 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-09-20 00:12:36.421 [main] Launching: win32/mplayer.exe
DEBUG 2013-09-20 00:12:38.312 [main] Launching: win32/mplayer.exe
INFO 2013-09-20 00:12:38.437 [main] Finished checking the MPlayer font cache.
DEBUG 2013-09-20 00:12:38.437 [main] AviSynth plugins directory: C:\Program Files\AviSynth\plugins
INFO 2013-09-20 00:12:38.437 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO 2013-09-20 00:12:38.437 [main] Found VideoLAN version 0.8.6f at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-20 00:12:38.531 [main] Searching for plugins in C:\Program Files\Universal Media Server\plugins
INFO 2013-09-20 00:12:38.562 [main] No plugins found
INFO 2013-09-20 00:12:38.578 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2013-09-20 00:12:38.578 [main] Registering transcoding engine: FFmpeg Audio
INFO 2013-09-20 00:12:38.625 [main] Registering transcoding engine: MEncoder
INFO 2013-09-20 00:12:38.625 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2013-09-20 00:12:38.625 [main] Registering transcoding engine: FFmpeg
INFO 2013-09-20 00:12:38.625 [main] Registering transcoding engine: MPlayer Audio
DEBUG 2013-09-20 00:12:39.859 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms, https]
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: MEncoder Web
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: MPlayer Web
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: tsMuxeR
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-09-20 00:12:39.875 [main] Found VLC version 0.8.6f in Windows Registry: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: VLC Audio Streaming
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: VLC Video Streaming
INFO 2013-09-20 00:12:39.875 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2013-09-20 00:12:39.890 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2013-09-20 00:12:40.062 [main] Using address /192.168.0.22 found on network interface: name:eth0 (Intel(R) WiFi Link 5100 AGN - Packet Scheduler Miniport)
INFO 2013-09-20 00:12:40.062 [main] Created socket: /192.168.0.22:5001
DEBUG 2013-09-20 00:12:40.359 [main] Sending ALIVE...
INFO 2013-09-20 00:12:40.375 [main] Using the following UUID configured in UMS.conf: 2490fbc9-cf94-4606-9976-8db5994fc68e
INFO 2013-09-20 00:12:40.625 [main] The server is now available for renderers to find
DEBUG 2013-09-20 00:12:50.625 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-09-20 00:13:10.625 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-09-20 00:14:05.031 [AWT-EventQueue-0] checking dbgpack property in UMS.conf
DEBUG 2013-09-20 00:14:05.031 [AWT-EventQueue-0] adding C:\Documents and Settings\All Users\UMS\WEB.conf
DEBUG 2013-09-20 00:14:05.031 [AWT-EventQueue-0] adding C:\Documents and Settings\All Users\UMS\UMS.conf
DEBUG 2013-09-20 00:14:05.031 [AWT-EventQueue-0] adding C:\Program Files\Universal Media Server\debug.log
can you use the "Pack Debug Files" button and upload them here?
