UMS forces transcode on compatible files w/ Xbox 360
BirdSH
Post by BirdSH » Tue Oct 01, 2013 2:58 am
I have a perfectly standard AVC/2ch LC-AAC in .mp4 that I know my 360 can play (moving it to a USB stick and playing from there worked flawlessly). However, UMS starts transcoding it when I attempt to play it, and if I add mp4 to the list of file extensions to force direct playback on, it just won't start playing the file at all (displays the "circle with a line through it"-error sign). What do?
(15.92 KiB) Downloaded 41 times
DeFlanko
Contact:
Re: UMS forces transcode on compatible files w/ Xbox 360
Post by DeFlanko » Tue Oct 01, 2013 4:55 am
I think its because in the XBOX360.conf the option for 6 channel [5.1 audio] is set now... ( a:6)
try changing it back to a:2 and see if you get the same result.
