[Solved] Audio out of sync when fast forwarding
When playing any content from the beginning there are no issues, but after fast forwarding the audio is slightly behind the video. This happens pretty constantly on many different file types.
Is there anything I can do to stop this from happening?
Things to note:
Streaming between Win machine and PS3
Wired network between Server and PS3
Have tweaked network settings to the Automatic (wired network) preset in Common transcode settings.
Things to note:
Re: Audio out of sync when fast forwarding
Here are logs
- (581.86 KiB) Downloaded 394 times
I forgot whether the PS3 supports picking up where you stopped after stopping the video, but if it does, can you try stopping it and then playing it, and see if you get the same problem?
It does. I never FF on my PS3; I use the GoTo feature, and my A/V stays in sync.
It seems that it is using tsMuxeR which is disabled by default. I recommend doing a backup of your profile folder and then running a "clean install" so you get the most stable default settings. That has been a known bug with tsMuxeR for years and is the reason why we disabled it by default
Where is the profile located, appdata or just in program files ?
also I never heard of this go to feature, where is this located ?
omg the go to feature is life changing, I never knew about it and I just found out about it. I did a clean install and things seem to be working great. Thanks all!
Thanks for confirming it works
