Installation issues with PMSencoder & Channels
I seem to get the following error when I put pmsencoder-1.6.0.jar in my plugins folder:
Configuration error: net.pms.PMS.registerPlayer(Lnet/pms/encoders/Player;)V
I've put pmsencoder at the beginning of engines in UMS.conf in the program's installation folder but it doesn't make a difference. Any suggestions?
Running, Win7 x64.
Running, Win7 x64.
- (17.84 KiB) Downloaded 612 times
Re: Installation issues with PMSencoder & Channels
Same here. Same error. Same OS.
Edit: Installed Shark's UMS build from P.2 of the Channels Plugin thread ( http://sharkhunter-shb.googlecode.com/f ... -setup.exe ) and no errors. Both plugs load just fine. (no auto download of channels as noted, but no big deal since I already had it).
- SharkHunter
- Developer
This is a "bug" in UMS 1.3.0. Some deprecated code was cleaned up and some plugins (pmsencoder,channles too I think but only pmsencoder is seen during the startup) used the deprecated versions. Thes plugins has not been updated to stop using the deprecated code. Until that is done this error will occur. Use an older version. I'll make a specail version of UMS which wil work with these plugins later on.
Thanks bcrest1, that worked. Should I stay on this pumped up version of 1.3.0 or move over to 1.4.0 with plugin installer?bcrest1 wrote:Edit: Installed Shark's UMS build from P.2 of the Channels Plugin thread ( http://sharkhunter-shb.googlecode.com/f ... -setup.exe ) and no errors. Both plugs load just fine. (no auto download of channels as noted, but no big deal since I already had it).
- SharkHunter
- Developer
You could try the new 1.4.0 with the plugin installer. pmsencoder has been updated so the deprecated code is now removed from there so it should work better. Plus you get a long list of new features as well of course...
