File not supported WebOS
Although I can playback with no transcode, I cant play the proper file.
I had a working .conf file but I lost it any help?
https://www.lg.com/ca_en/support/produc ... 789-others Supported Formats
media Info
media Info
- (29.49 KiB) Downloaded 627 times
Re: File not supported WebOS
As explained in the problem reporting guidelines, only TRACE log are useful so...
You are not using an adequat renderer, but adding these lines should enhance your experience:
and remove that one:
and if you have a 4K model:
DefaultVBVBufSize = true
MaxVideoWidth = 3840
MaxVideoHeight = 2160
H264Level41Limited = false
SupportedVideoBitDepths = 8,10
