Ubuntu 18.04 & PS3 Failure to play
busyguy2
Post by busyguy2 » Mon Dec 03, 2018 6:45 am
I have UMS 7.6.2 running on Ubuntu 18.04. I am unable to play any titles on the PS3. I keep getting "This content cannot be played. (800288E1). I created a test folder with one file only and tried to play this. Please find attached the zip with the debug log file, UMS.conf and mediainfo for the file being tested.
Any help would be appreciated.
Thanks,
test.zip
(51.98 KiB) Downloaded 76 times
busyguy2
Re: Ubuntu 18.04 & PS3 Failure to play
Post by busyguy2 » Tue Dec 25, 2018 1:00 am
I'm still working on this issue, and I've now realised that transcoding is failing for all systems. I used VLC on a windows system, and any video which requires to be transcoded fails. I have reinstalled a new 18.04 headless ubuntu system using the defaults, and added unzip, openjdk-8-jdk, and mediainfo packages. Using UMS 8.0.0-a1 I'm seeing the same behaviour. What ever I am doing is systemic to the systems.
Relevant portion of the log showing failure is:
TRACE 2018-12-24 15:51:37.469 [HTTPv2 Request Worker 2] Stripping preceding slash from: /get/51/test.mkv_transcoded_to.ts
TRACE 2018-12-24 15:51:37.470 [HTTPv2 Request Worker 2] Matched media renderer "VLC for desktop" based on address 192.168.1.183
DEBUG 2018-12-24 15:51:37.470 [HTTPv2 Request Worker 2] Recognized media renderer "VLC for desktop"
TRACE 2018-12-24 15:51:37.470 [HTTPv2 Request Worker 2] Received a request from VLC for desktop (192.168.1.183:57431):
GET /get/51/test.mkv_transcoded_to.ts HTTP/1.1
HEADER:
  Host: 192.168.1.205:5001
  Accept: */*
  Accept-Language: en_US
  User-Agent: VLC/3.0.4 LibVLC/3.0.4
  Range: bytes=0-
TRACE 2018-12-24 15:51:37.470 [HTTPv2 Request Worker 2] Asked stream chunk : TimeRange [start=null, end=null] of test.mkv and player FFmpeg Video
TRACE 2018-12-24 15:51:37.470 [HTTPv2 Request Worker 2] Setting lastStartPosition from time-seeking: 0.0
DEBUG 2018-12-24 15:51:37.471 [HTTPv2 Request Worker 2] Starting transcode/remux of test.mkv with media info: Container: MKV, Size: 16176698394, Video Bitrate: 18445326, Video Tracks: 1, Video Codec: h264, Duration: 1:56:56.064, Video Resolution: 1920 x 1080, Display Aspect Ratio: 16:9, Scan Type: Progressive, Frame Rate: 23.976, Frame Rate Mode: CFR, AVC Level: 4.1, Subtitle Tracks: 2 [Embedded, id: 0, type: PGS, lang: eng], [Embedded, id: 1, type: PGS, lang: spa], DLNAThumbnail: [Format = JPEG, Resolution = 320×180, Size = 6633, DLNA Profile = JPEG_RES_320_180], Mime Type: video/x-matroska
TRACE 2018-12-24 15:51:37.471 [HTTPv2 Request Worker 2] Found no audio track
TRACE 2018-12-24 15:51:37.471 [HTTPv2 Request Worker 2] Using video bitrate limit from the general configuration (90 Mb/s)
TRACE 2018-12-24 15:51:37.472 [HTTPv2 Request Worker 2] Adjusting the video bitrate limit to the H.264 Level 4.1-safe value of 31250 kb/s
DEBUG 2018-12-24 15:51:37.472 [HTTPv2 Request Worker 2] Caught exception: null
TRACE 2018-12-24 15:51:37.473 [HTTPv2 Request Worker 2]
        at net.pms.encoders.FFMpegVideo.launchTranscode(FFMpegVideo.java:1097)
        at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:3257)
        at net.pms.network.RequestV2.dlnaMediaHandler(RequestV2.java:375)
        at net.pms.network.RequestV2.dlnaResourceHandler(RequestV2.java:339)
        at net.pms.network.RequestV2.answer(RequestV2.java:230)
        at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:394)
        at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:258)
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
        at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142)
        at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145)
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296)
        at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459)
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536)
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268)
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255)
        at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
        at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
        at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
        at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
        at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
I'm uncertain if I have missed any packages or not as I have installed the server version of Ubuntu and I'm running it headless in a VM. Any pointer's or help on how to debug this?
Thanks,
busyguy2
Post by busyguy2 » Tue Dec 25, 2018 1:03 am
I've reinstalled a system with 18.04 headless and I realise that all transcoding is failing. When I use VLC on a windows desktop, I am getting the following failure:
HEADER:
  Accept: */*
  Range: bytes=0-
The system was installed using 18.04 server image with defaults and sshd, unzip, openjdk-8-jdk and mediainfo packages installed.
Any pointers/help?
Thanks,
atamariya
Post by atamariya » Tue Dec 25, 2018 3:48 pm
Thanks,
This failure is because ffmpeg is failing to transcode. You can try the following command on command-line.
/opt/ums-7.6.2/linux/ffmpeg64 -y -loglevel info -hwaccel auto -threads 1 -i /nfs/ums-user/Media/Test/test.mkv -map 0:V -map 0:a:0 -bufsize 166k -g 25 -qmax 7 -qmin 2 -ac 6 -ab 640k -ar 48000 -c:a ac3 -c:v mpeg2video -f vob /tmp/UMS-ums-user/ffmpegvideo_46_1543610628501
A quick fix is to remove "-bufsize 166k" option in FFMpegVideo.java. Let me know if that works. There's already an issue for this https://github.com/UniversalMediaServer ... ssues/1374
atamariya
Post by atamariya » Tue Dec 25, 2018 3:50 pm
HEADER:
  Accept: */*
  Range: bytes=0-
Any pointers/help?
Thanks,
This must be a different version from original post. Line 1090-1101 is
				if (
					params.aid.getSampleRate() != params.mediaRenderer.getTranscodedVideoAudioSampleRate() &&
					configuration.isFFmpegSoX() &&
					!customFFmpegOptions.contains("--resampler")
					cmdList.add("-resampler");
					cmdList.add("soxr");
					cmdList.add("-precision");
					cmdList.add("33");
					cmdList.add("-cheby");
					cmdList.add("1");
busyguy2
Post by busyguy2 » Tue Dec 25, 2018 8:52 pm
I did the test on the command line and here's the output:
WITH the BUFSIZE included
[email protected]:~$ /opt/ums-7.6.2/linux/ffmpeg64 -y -loglevel info -hwaccel auto -threads 1 -i /nfs/ums-user/Media/Test/test.mkv -map 0:V -map 0:a:0 -bufsize 166k -g 25 -qmax 7 -qmin 2 -ac 6 -ab 640k -ar 48000 -c:a ac3 -c:v mpeg2video -f vob /tmp/UMS-ums-user/ffmpegvideo_46_1543610628501
ffmpeg version N-80363-g403a53c-static http://johnvansickle.com/ffmpeg/  Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 5.4.0 (Debian 5.4.0-4) 20160609
  configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc
  libavutil      55. 24.100 / 55. 24.100
  libavcodec     57. 46.100 / 57. 46.100
  libavformat    57. 38.100 / 57. 38.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 46.101 /  6. 46.101
  libswscale      4.  1.100 /  4.  1.100
  libswresample   2.  1.100 /  2.  1.100
  libpostproc    54.  0.100 / 54.  0.100
[matroska,webm @ 0x510d5a0] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, matroska,webm, from '/nfs/ums-user/Media/Test/test.mkv':
  Metadata:
    encoder         : libebml v1.3.6 + libmatroska v1.4.9
    creation_time   : 2018-11-01 16:41:42
  Duration: 01:56:56.06, start: 0.000000, bitrate: 18445 kb/s
    Chapter #0:0: start 0.000000, end 452.410000
    Metadata:
      title           : 00:00:00.000
    Chapter #0:1: start 452.410000, end 848.097000
    Metadata:
      title           : 00:07:32.410
    Chapter #0:2: start 848.097000, end 1244.534000
    Metadata:
      title           : 00:14:08.097
    Chapter #0:3: start 1244.534000, end 1708.039000
    Metadata:
      title           : 00:20:44.534
    Chapter #0:4: start 1708.039000, end 2115.863000
    Metadata:
      title           : 00:28:28.039
    Chapter #0:5: start 2115.863000, end 2482.438000
    Metadata:
      title           : 00:35:15.863
    Chapter #0:6: start 2482.438000, end 2844.675000
    Metadata:
      title           : 00:41:22.438
    Chapter #0:7: start 2844.675000, end 3139.135000
    Metadata:
      title           : 00:47:24.675
    Chapter #0:8: start 3139.135000, end 3757.295000
    Metadata:
      title           : 00:52:19.135
    Chapter #0:9: start 3757.295000, end 4192.146000
    Metadata:
      title           : 01:02:37.295
    Chapter #0:10: start 4192.146000, end 4481.643000
    Metadata:
      title           : 01:09:52.146
    Chapter #0:11: start 4481.643000, end 5014.551000
    Metadata:
      title           : 01:14:41.643
    Chapter #0:12: start 5014.551000, end 5204.449000
    Metadata:
      title           : 01:23:34.551
    Chapter #0:13: start 5204.449000, end 6118.612000
    Metadata:
      title           : 01:26:44.449
    Chapter #0:14: start 6118.612000, end 6361.313000
    Metadata:
      title           : 01:41:58.612
    Chapter #0:15: start 6361.313000, end 7015.800000
    Metadata:
      title           : 01:46:01.313
    Chapter #0:16: start 7015.800000, end 7016.064000
    Metadata:
      title           : 01:56:55.800
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Metadata:
      BPS-eng         : 14003698
      DURATION-eng    : 01:56:56.058000000
      NUMBER_OF_FRAMES-eng: 168217
      NUMBER_OF_BYTES-eng: 12281345060
      _STATISTICS_WRITING_APP-eng: mkvmerge v28.2.0 ('The Awakening') 32-bit
      _STATISTICS_WRITING_DATE_UTC-eng: 2018-11-01 16:41:42
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default)
    Metadata:
      BPS-eng         : 3681399
      DURATION-eng    : 01:56:56.062000000
      NUMBER_OF_FRAMES-eng: 8419274
      NUMBER_OF_BYTES-eng: 3228615948
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s
    Metadata:
      BPS-eng         : 640000
      DURATION-eng    : 01:56:56.064000000
      NUMBER_OF_FRAMES-eng: 219252
      NUMBER_OF_BYTES-eng: 561285120
    Stream #0:3(eng): Subtitle: hdmv_pgs_subtitle, 1920x1080
    Metadata:
      BPS-eng         : 62482
      DURATION-eng    : 01:50:19.696000000
      NUMBER_OF_FRAMES-eng: 4554
      NUMBER_OF_BYTES-eng: 51702205
    Stream #0:4(spa): Subtitle: hdmv_pgs_subtitle
    Metadata:
      BPS-eng         : 46965
      DURATION-eng    : 01:49:33.942000000
      NUMBER_OF_FRAMES-eng: 3581
      NUMBER_OF_BYTES-eng: 38593299
[mpeg2video @ 0x5723b80] Either both buffer size and max rate or neither must be specified
Output #0, vob, to '/tmp/UMS-ums-user/ffmpegvideo_46_1543610628501':
  Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Stream #0:0(eng): Unknown: none, SAR 1:1 DAR 0:0 (default)
    Metadata:
      BPS-eng         : 14003698
      encoder         : Lavc57.46.100 mpeg2video
    Stream #0:1(eng): Unknown: none (default)
    Metadata:
      BPS-eng         : 3681399
      encoder         : Lavc57.46.100 ac3
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> mpeg2video (native))
  Stream #0:1 -> #0:1 (truehd (native) -> ac3 (native))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Without BUFSIZE included
[email protected]:~$ /opt/ums-7.6.2/linux/ffmpeg64 -y -loglevel info -hwaccel auto -threads 1 -i /nfs/ums-user/Media/Test/test.mkv -map 0:V -map 0:a:0 -g 25 -qmax 7 -qmin 2 -ac 6 -ab 640k -ar 48000 -c:a ac3 -c:v mpeg2video -f vob /tmp/UMS-ums-user/ffmpegvideo_46_1543610628501
[matroska,webm @ 0x49365e0] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle): unspecified size
  Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
      BPS-eng         : 14003698
    Metadata:
      BPS-eng         : 3681399
    Metadata:
      BPS-eng         : 640000
    Metadata:
      BPS-eng         : 62482
    Metadata:
      BPS-eng         : 46965
[vob @ 0x4f5cca0] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
    Last message repeated 1 times
[vob @ 0x4f5cca0] VBV buffer size not set, using default size of 130KB
If you want the mpeg file to be compliant to some specification
Like DVD, VCD or others, make sure you set the correct buffer size
  Metadata:
    encoder         : Lavf57.38.100
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Metadata:
    Stream #0:0(eng): Video: mpeg2video (Main), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-7, 200 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default)
    Metadata:
      BPS-eng         : 14003698
    Side data:
      cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1, fltp (24 bit), 640 kb/s (default)
    Metadata:
      BPS-eng         : 3681399
Stream mapping:
Press [q] to stop, [?] for help
[vaapi @ 0x338f4e0] No VA display found for device (null).
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2397 size=2560
[vob @ 0x4f5cca0] packet too large, ignoring buffer limits to mux it
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2237 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2059 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2444 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2284 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2124 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2509 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2331 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2171 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2556 size=2560
    Last message repeated 4 times
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2396 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2236 size=2560
    Last message repeated 7 times
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2076 size=2560 bitrate=1373.3kbits/s speed=4.43x
    Last message repeated 6 times
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2461 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2301 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2141 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2526 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2366 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2206 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2431 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2271 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2111 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2496 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2336 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2176 size=2560 bitrate=2648.5kbits/s speed=3.41x
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2388 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2210 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2050 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2435 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2275 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2115 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2500 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2340 size=2560
[vob @ 0x4f5cca0] buffer underflow st=1 bufi=2180 size=2560
frame=  107 fps= 71 q=31.0 Lsize=    1998kB time=00:00:04.47 bitrate=3657.7kbits/s speed=2.96x
video:1620kB audio:350kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 1.403475%
Exiting normally, received signal 2.
So it does seem to make a difference. The question is how do I edit FFMpegVideo.java and run the file? I can'f find the file in the ums installation.
Thanks,
busyguy2
Post by busyguy2 » Thu Dec 27, 2018 12:42 am
				if (
					cmdList.add("33");
					cmdList.add("1");
That is correct. The 2nd post is with UMS 8.0.0-a1 whilst the 1st was with UMS 7.6.2..
