After updating Win10, UMS stops working
Re: After updating Win10, UMS stops working
It's very likely that it's the firewall rules enforced by the update. You must make sure that UMS can communicate with the renderer(s).
I had the same problem after installing a recent update for win 10. I had to manually go into my firewall settings to re enable access for java as windows decided to mess with the rules.
Yes if the program is still visible on the computer but just not showing up on the TV, and a OS restore fixes it, it is likely a firewall configuration issue.
You could try removing the firewall entries for javaw.exe and then it should re-prompt you. Make sure you give it full permissions like public and private, not just public
