Log viewer
Log viewer
Just curious if anyone uses a log viewer program.
I was using Notepad++ for a while but thought there must be an easier way
I've found LogViewPlus and has made looking at the debug logs a lot easier. I have set up a few filters and highlights for common problems so I can easily jump to the relevant part.
Problem is it is not free and only has a 30 day trial. I found a way around it by deleting the settings data in appdata/roaming and reinstalling, Unfortunately that wipes all the filters set up but not too hard to set up again.
Anyone have any better recommendations for a free viewer with similar features?
Re: Log viewer
@Subjunk @Nadahar Have you tried using this?
These are the settings I use for UMS log files along with the filters and highlights that makes it much easier to find issues.
Any suggestions on other filters to add?
Settings:
>Fonts & colours>Application Skin>"Visual Studio Blue"
>Encoding & Culture>Default Encoding>"UTF-8"
Load Debug.log file, cancel prompt.
Right click log and go to Parser Wizard.
Click next x3
Parser Wizard conversion pattern, reload (F5) then replace with
%p %d{yyyy-MM-dd %H:mm:ss.fff} [%c] %m%n
Click next x2
Give name (UMS) then finish
Setup filters by copying the begin and end sections below then right click on the debug.log in Logview and paste.
Repeat with all filters
Add all Issues filter (Ctrl+E)
Click highlights icon at bottom left. add all the extra highlights below (some are created with the filters)
Resize columns and hide the "date" column if not needed
Once setup, go to add template in toolbar.
set Save highlights "save all highlights"
Template name "UMS"
Click OK.
Loading a new logfile (or zipped archive) just select the debug.log then select Templates from the toolbar and pick "UMS"
Free version works for 1 month but will work longer as long as it is not closed at end of the trial period.
To continue to use the program, delete "C:\Users\{user}\AppData\Roaming\LogViewPlus"
Unfortunately all settings will be deleted and have to be redone.
These are the filters I use
UMS version
<!-- Begin LogViewPlus Template -->
LVPTPd416eQAZTiulc+LYCAF2AXMBAAAACkNPUFlfUEFTVEVjAQAAAF5aAAAAAQQCAAAAA1EBOEFTSlRkR0Z5ZEdsdVp5QlZibWw
yWlhKellXd2dUV1ZrYVdFZ1UyVnlkbVZ5SUM0cUJRRUJBQT09AwQBAAAABAEBBgtVTVMgdmVyc2lvbgAAAAA=
<!-- End LogViewPlus Template -->
System Information
LVPTPd416eQAdIu9QTxvZCAFRAU4BAAAACkNPUFlfUEFTVEU+AQAAADk1AAAAAQQCAAAAAywBIEFSTlRlWE4wWlcwZ2FXNW1iM0p
0WVhScGIyNDZBQT09AwQBAAAABAEBAAAAAA==
VPN?
LVPTPd416eQDQu/D2Gb3YCAE5ATYBAAAACkNPUFlfUEFTVEUmAQAAACEdAAAAAQQCAAAAAxQBCEFRTldVRTRBAwQBAAAABAEBAAA
AAA==
IP Adresses
LVPTPd416eQANTiulc+LYCAF3AXQBAAAACkNPUFlfUEFTVEVkAQAAAF9bAAAAAQQCAAAAA1IBOEFTSmNaSHN4TEROOVhDNWNaSHN
4TEROOVhDNWNaSHN4TEROOVhDNWNaSHN4TEROOUJRRUJBQT09AwQBAAAABAEBBgxJUCBhZGRyZXNzZXMAAAAA
IPs + Ports
LVPTPd416eQAOTiulc+LYCAF4AXUBAAAACkNPUFlfUEFTVEVlAQAAAGBcAAAAAQQCAAAAA1MBQEFTcGNaSHN4TEROOVhDNWNaSHN
4TEROOVhDNWNaSHN4TEROOVhDNWNaSHN4TEROOU9seGtlekVzTlgwRkFRRUEDBAEAAAAEAQEGBVBvcnRzAAAAAA==
Used Network Interface
LVPTPd416eQAVTiulc+LYCAH9TwMB/UoDAQAAAApDT1BZX1BBU1RF/TgDAQAAAP0xAy0DAAABBAIAAAAD/SIDAf38AkFkSW5abTk
xYm1RZ2IyNGdibVYwZDI5eWF5QnBiblJsY21aaFkyVTZKeUJQVWlBbmJtVjBMbkJ0Y3k1dVpYUjNiM0pyTGs1bGRIZHZjbXREYjI
1bWFXZDFjbUYwYVc5dUlHWnBjbk4wSUc1bGRIZHZjbXNnYVc1MFpYSm1ZV05sT2ljZ1QxSWdKMVZ6YVc1bklHRmtaSEpsYzNNbkl
FOVNJQ2RWYzJsdVp5Qm1iM0pqWldRZ1lXUmtjbVZ6Y3ljZ1QxSWdKMU5sZEhScGJtY2dVMU5FVUNCdVpYUjNiM0pySUdsdWRHVnl
abUZqWlRvbklFOVNJQ2RTWldGa2FXNW5JRzVsZEhkdmNtdGZhVzUwWlhKbVlXTmxPaWNDL1dJQkJnQUFBRFFCS0VGU2RHMWlNMVo
xV2tOQ2RtSnBRblZhV0ZJellqTktja2xIYkhWa1IxWjVXbTFHYWxwVWIwRURCQUVBQUFBRUFRRUFaQUZZUVZReGRWcFlVWFZqUnp
GNlRHMDFiR1JJWkhaamJYTjFWRzFXTUdReU9YbGhNRTUyWW0xYWNGb3pWbmxaV0ZKd1lqSTBaMXB0Ykhsak0xRm5ZbTFXTUdReU9
YbGhlVUp3WW01U2JHTnRXbWhaTWxVMlFVRTlQUU1FQVFBQUFBUUJBUUFrQVJoQlVURldZekpzZFZwNVFtaGFSMUo1V2xoT2VrRkJ
QVDBEQkFFQUFBQUVBUUVBTEFFZ1FWSlNWbU15YkhWYWVVSnRZak5LYWxwWFVXZFpWMUpyWTIxV2VtTjNRVDBEQkFFQUFBQUVBUUV
BUEFFd1FWSTVWRnBZVWpCaFZ6VnVTVVpPVkZKR1FXZGliVll3WkRJNWVXRjVRbkJpYmxKc1kyMWFhRmt5VlRaQlFUMDlBd1FCQUF
BQUJBRUJBRFFCS0VGU2NGTmFWMFpyWVZjMWJrbEhOV3hrU0dSMlkyMTBabUZYTlRCYVdFcHRXVmRPYkU5blFUMERCQUVBQUFBRUF
RRUFBQT09AwQGAAAABAEBBhZVc2VkIE5ldHdvcmsgSW50ZXJmYWNlAAAAAA==
Used Interface/IP
LVPTPd416eQARTiulc+LYCAH9UgIB/U0CAQAAAApDT1BZX1BBU1RF/TsCAQAAAP00AjACAAABBAIAAAAD/SUCAf0EAkFZMG5abTk
FOVNJQ2RWYzJsdVp5Qm1iM0pqWldRZ1lXUmtjbVZ6Y3ljQzhBUUFBQUEwQVNoQlVuUnRZak5XZFZwRFFuWmlhVUoxV2xoU00ySXp
TbkpKUjJ4MVpFZFdlVnB0Um1wYVZHOUJBd1FCQUFBQUJBRUJBR1FCV0VGVU1YVmFXRkYxWTBjeGVreHROV3hrU0dSMlkyMXpkVlJ
0VmpCa01qbDVZVEJPZG1KdFduQmFNMVo1V1ZoU2NHSXlOR2RhYld4NVl6TlJaMkp0VmpCa01qbDVZWGxDY0dKdVVteGpiVnBvV1R
KVk5rRkJQVDBEQkFFQUFBQUVBUUVBSkFFWVFWRXhWbU15YkhWYWVVSm9Xa2RTZVZwWVRucEJRVDA5QXdRQkFBQUFCQUVCQUN3Qkl
FRlNVbFpqTW14MVdubENiV0l6U21wYVYxRm5XVmRTYTJOdFZucGpkMEU5QXdRQkFBQUFCQUVCQUFBPQMEBgAAAAQBAQYRVXNlZCB
JbnRlcmZhY2UvSVAAAAAA
Renderers
LVPTPd416eQASTiulc+LYCAH98gEB/e0BAQAAAApDT1BZX1BBU1RF/dsBAQAAAP3UAdABAAABBAIAAAAD/cUBAf2sAUFYQW5UbVY
zSUhKbGJtUmxjbVZ5SUdadmRXNWtPaWNnVDFJZ0owMWhkR05vWldRZ2JtVjNJRzFsWkdsaElISmxibVJsY21WeUp5QlBVaUFuVFd
GMFkyaGxaQ0J0WldScFlTQnlaVzVrWlhKbGNpY2dUMUlnSjFKbFkyOW5ibWw2WldRZ2JXVmthV0VnY21WdVpHVnlaWEluQXN3RUF
BQUFMQUVnUVZKT1QxcFlZMmRqYlZaMVdrZFdlVnBZU1dkYWJUa3hZbTFSTmtGQlBUMERCQUVBQUFBRUFRRUFOQUVvUVZKd1RsbFl
VbXBoUjFaclNVYzFiR1I1UW5SYVYxSndXVk5DZVZwWE5XdGFXRXBzWTJkQlBRTUVBUUFBQUFRQkFRQXdBU1JCVWxwT1dWaFNhbUZ
IVm10SlJ6RnNXa2RzYUVsSVNteGliVkpzWTIxV2VVRkJQVDBEQkFFQUFBQUVBUUVBTkFFb1FWSnNVMXBYVG5aYU1qVndaVzFXYTB
sSE1XeGFSMnhvU1VoS2JHSnRVbXhqYlZaNVFVRTlQUU1FQVFBQUFBUUJBUUFBAwQGAAAABAEBBglSZW5kZXJlcnMAAAAA
Network Speed
LVPTPd416eQAHqedfrfDYCAFqAWcBAAAACkNPUFlfUEFTVEVXAQAAAFJOAAAAAQQCAAAAA0UBKEFScGxjM1JwYldGMFpXUWdibVY
wZDI5eWF5QnpjR1ZsWkNCdlpnQT0DBAEAAAAEAQEGDydOZXR3b3JrIHNwZWVkJwAAAAA=
GetProtocalInfo
LVPTPd416eQDSu/D2Gb3YCAFJAUYBAAAACkNPUFlfUEFTVEU2AQAAADEtAAAAAQQCAAAAAyQBGEFROUhaWFJRY205MGIyTnZiRWx
1Wm04QQMEAQAAAAQBAQAAAAA=
Media Info Results
LVPTPd416eQATTiulc+LYCAH9IwEB/R4BAQAAAApDT1BZX1BBU1RF/QwBAQAAAP0FAQEBAAABBAIAAAAD+AHgQVRrblVHRnljMmx
1WnlCeVpYTjFiSFJ6SUdadmNpQm1hV3hsSnlCUFVpQW5UV1ZrYVdGSmJtWnZJSEJoY25OcGJtY2djbVZ6ZFd4MGN5Y0NhZ0lBQUF
Bd0FTUkJVbWhSV1ZoS2VtRlhOVzVKU0Vwc1l6TldjMlJJVFdkYWJUbDVTVWRhY0dKSFZVRURCQUVBQUFBRUFRRUFOQUVvUVZKc1R
scFhVbkJaVld4MVdtMDRaMk5IUm5sak1teDFXbmxDZVZwWVRqRmlTRko2UVVFOVBRTUVBUUFBQUFRQkFRQUEDBAYAAAAEAQEGCk1
lZGlhIEluZm8AAAAA
Final Verdict
LVPTPd416eQDOu/D2Gb3YCAFJAUYBAAAACkNPUFlfUEFTVEU2AQAAADEtAAAAAQQCAAAAAyQBGEFRNUdhVzVoYkNCMlpYSmthV04
wT2dBPQMEAQAAAAQBAQAAAAA=
Start/Stop playing Events
LVPTPd416eQDNu/D2Gb3YCAHlAeIBAAAACkNPUFlfUEFTVEXSAQAAAM3JAAAAAQQCAAAAA8ABtEFTc25VM1J2Y0ZCc1lYbHBibWN
nUlhabGJuUW5JRTlTSUNkVGRHRnlkRkJzWVhscGJtY2dSWFpsYm5RbkFsWUNBQUFBS0FFY1FWSkdWR1JIT1hkVlIzaG9aVmRzZFZ
wNVFrWmtiVloxWkVGQlBRTUVBUUFBQUFRQkFRQW9BUnhCVWtwVVpFZEdlV1JHUW5OWldHeHdZbTFqWjFKWVdteGlibEZCQXdRQkF
BQUFCQUVCQUFBPQMEBgAAAAQBAQAAAAA=
Transcode Command
LVPTPd416eQDqp5wlkCnZCAFkAWEBAAAACkNPUFlfUEFTVEVRAQAAAExIAAAAAQQCAAAAAz8BIEFSQlRkR0Z5ZEdsdVp5QWlLQzR
xUHlraUJRRUJBQT09AwQBAAAABAEBBhFUcmFuc2NvZGUgQ29tbWFuZAAAAAA=
These are the additional Highlights that are useful
New renderer found:
Matched media renderer
Recognized media renderer
Received a browse request from
End of analysis
MediaInfo parsing results
Metadata already exists for
Matched format
Matched support line
will be streamed
failed to match supported line
failed to match support line
will be transcoded with player
StartPlaying Event
StopPlaying Event
Starting transcode
