[Solved] Lg cx sometimes I have problems with external subs on 4k movies
jaapie18
Post by jaapie18 »
ums_dbg_2021-08-13-11-40.zip
(491.6 KiB) Downloaded 803 times
I have an LG OLED65CX6LA. I have problems with 4k movies which an internal sub and when i put an external sub it won't read it. The weird part is if it has no internal sub it just read the external sub fine. I tried serviio and via usb and it doesn't have those problems. What settings do i have to change.I like ums more.
jaapie18
Re: Lg cx sometimes I have problems with external subs on 4k movies
Post by jaapie18 »
Seems i forgot the logs. Dunno if it will help my problem.
I don't see any renderers or attempt to play anything so cannot see what UMS is doing with the subs file.
Could you do new logs making sure to try and play a file you have problems with.
jaapie18
Post by jaapie18 »
ums_dbg_2021-08-14-16-49.zip
(541.47 KiB) Downloaded 823 times
If I just look at the logs i don't see any problems.
Nothing is being played so I can't see anything. Could you try again and make sure you play something you have an issue with first.
Having a look at the config for UMS, you have disabled the external subtitles
# Load subtitles
# Choose whether UMS should check for external subtitles files with the same
# name as the media (*.srt, *.sub, *.ass, etc.).
# Default: true
autoload_external_subtitles =false
Check the option in the Transcoding settings tab > Subtitles settings > enable "Force external subtitles"
jaapie18
Post by jaapie18 »
mik_s wrote: Sun Aug 15, 2021 4:29 pm Nothing is being played so I can't see anything. Could you try again and make sure you play something you have an issue with first.
# Load subtitles
# Default: true
ums_dbg_2021-08-15-11-02.zip
(1.19 MiB) Downloaded 856 times
In the transcoding settings tab I had "Force external subtitles" already enabled. Weird that in the config file it is on false. So i set it on enable. But have still the problem.
I'm not sure but I think there is a problem with the conf or the way UMS is handling the supported subtitles option.
If si: is defined it might be ignoring the SupportedExternalSubtitlesFormats.
I have made 2 confs for you to test to see if that is the case. First copy this to C:\Program Files (x86)\Universal Media Server\renderers and see if that is working.
(you may have to restart UMS)
LG-OLED subs test.conf
Removed si:ASS|SUBRIP from mkv
(3.07 KiB) Downloaded 880 times
If that does work, delete that conf and try this one next
LG-OLED subs test 2.conf
added se:ASS|SUBRIP to mkv
(3.07 KiB) Downloaded 877 times
I also noticed some interesting things in the logs:
TRACE 2021-08-15 11:02:03.301 [HTTPv2 Request Worker 30] net.pms.configuration.FormatConfiguration The video bit depth "10" is not supported for this filetype, or all filetypes
I can't find any mention in the TV manual of whether higher bit depths like 10 and 12 are supported, but I guess it does based on your logs. So we can also add that to the config. Can you do that mik_s?
But yeah it is weird about the subtitles, it seems like a bug so I will be interested in the results of the testing too
No probs, I added them to the existing LG-OLED.conf
LG-OLED.conf
added SupportedVideoBitDepths = 8,10,12
(3.09 KiB) Downloaded 839 times
@jappie18 if you want to try this version you will have to delete the test confs after you have made the logs, as I have given them a higher priority.
jaapie18
Post by jaapie18 »
Sorry for the late reply.
I gonna try it tomorrow i let you know.
