purple/green colors when playing dv file
hello
Could some one help me please ?
If i want to stream/play a dolby vision file or atmos file i get this purple/green screen the hole movie.
and this happend also on some blueray movies.
Re: purple/green colors when playing dv file
Can you post trace logs? there is not enough information to help. see the section in red above.
Hello.
I have the same problem as Threadripper in 2022 on my LG OLED65CX9LA.
I attach the trace logs and some sample pics.
THX
THX
- ums_dbg_2023-08-10-09-18.zip
- (311.99 KiB) Downloaded 62 times
- Samples.zip
- (927.3 KiB) Downloaded 75 times
Nobody with a similar problem or a solution here?
This is a known bug and I think it is not just limited to UMS as other media servers seem to have the same problem.
There has been some work done to try and fix this but not sure of the status. You can see more info about it here.
