Problem with Web interface
Gaston62
Post by Gaston62 »
I have recently updated to UMS v. 13.1.0.
Since then, I have problems with the web interface, and can not connect to it. With previous version, I have chosen option to have a user and a password to log on. And it was working. But since last update, it is not working anymore. So... how can I revert to web interface without user and password ?
Re: Problem with Web interface
From here. You can reset the user and password by quitting UMS and deleting C:\ProgramData\UMS\database\USERS.mv.db (not sure where this is on other systems)
This will prompt you to create a new user and password when UMS next starts.
I have just tested this and it does work, no need to delete the database, just the USERS file.
Gaston62
Post by Gaston62 »
Thanks a lot, mik_s ! It worked ! This time, I choose the other option : no user, no password...
