Re: Jumpy Plugin (19 Nov 2012)
Infidel, I don't understand why but it has worked!!! (at least for a while)
Reading this post (viewtopic.php?f=9&t=386) I decided to unistall UMS 2.2.4 in order to install UMS 1.6.0 (hoping it would work... but it didn't)
After that and because it didn't work I reinstalled UMS 2.2.4 over 1.6.0
I have managed to test three Tv Shows succesfully but unfortunately it has only worked for 5 minutes...
Suddenly this message appeared again: ffmpeg.exe has a return code of 1!
ffmpeg is the problem...
in this case, it worked:
Not in this case:
DEBUG 2013-01-14 02:27:54.078 [Thread-96] Waiting for pipe connection \\.\pipe\pmsencoder_transcoder_out_1358126874046_306
DEBUG 2013-01-14 02:27:54.281 [win32\ffmpeg.exe] Starting D:\Universal Media Server\win32\ffmpeg.exe -v 0 -y -threads 1 -i "http://videosgeo.mitele.es/geo/programa/quienquierecasarseconmihijo/t2/c10_ok.mp4?vf=20130114012758&vu=20130114012804&h=0b64281f079d06cfa73c5&start=0" -threads 1 -target ntsc-dvd \\.\pipe\pmsencoder_transcoder_out_1358126874046_306
DEBUG 2013-01-14 02:27:54.281 [win32\ffmpeg.exe] Reading pipe: \\.\pipe\pmsencoder_transcoder_out_1358126874046_306
DEBUG 2013-01-14 02:27:54.671 [win32\ffmpeg.exe] Attaching thread: win32\ffmpeg.exe
DEBUG 2013-01-14 02:27:56.062 [Thread-96] Result of \\.\pipe\pmsencoder_transcoder_out_1358126874046_306 : true
DEBUG 2013-01-14 02:28:53.812 [win32\ffmpeg.exe] Starting D:\Universal Media Server\win32\ffmpeg.exe -v 0 -y -threads 1 -i "http://videos.mitele.es/nogeo/series/laqueseavecina/t5/series_laqueseavecina_t5_c67.mp4?vf=20130114012857&vu=20130114012903&h=058a46fa3be15b79d56ff&start=0" -threads 1 -target ntsc-dvd \\.\pipe\pmsencoder_transcoder_out_1358126933562_306
DEBUG 2013-01-14 02:28:53.828 [win32\ffmpeg.exe] Reading pipe: \\.\pipe\pmsencoder_transcoder_out_1358126933562_306
DEBUG 2013-01-14 02:28:54.296 [win32\ffmpeg.exe] Attaching thread: win32\ffmpeg.exe
INFO 2013-01-14 02:28:55.546 [win32\ffmpeg.exe] Process D:\Universal Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occured... check the log file
INFO 2013-01-14 02:29:00.265 [StartPlaying Event] Started playing 5x67 Un bodorrio, un león desterrado y la revolución de los centollos on your Sony Bravia EX
DEBUG 2013-01-14 02:29:00.265 [StartPlaying Event] The full filename of which is: http://videos.mitele.es/nogeo/series/laqueseavecina/t5/series_laqueseavecina_t5_c67.mp4?vf=20130114012857&vu=20130114012903&h=058a46fa3be15b79d56ff&start=0 and the address of the renderer is: 192.168.2.100
DEBUG 2013-01-14 02:29:02.843 [Buffered IO End Checker] Stopping process: win32\ffmpeg.exe
Good, you're getting somewhere . You've probably already thought of this but you could try a clean install of 2.2.4 and then dropping in ffmpeg from 1.6.0 (7zip would be able to extract it directly from the 16.0 installer if you want to save a few steps).frentemorao wrote:Infidel, I don't understand why but it has worked!!! (at least for a while)
Thank you for the new idea, infidel
I will try a clean install of 2.2.4 dropping ffmpeg from 1.6.0 tonight --> QUESTION: Apart from dropping ffmpeg.exe, do i have to drop any additional file (.dll or configuration file or even ffmpeg_MPGMUX.exe or pthreadGC2.dll) ??
Why do you think this new idea can work?
Regarding the attachment you provided a couple of days ago
For my curiosity, what did you change in these files to make the addon work??infidel wrote: [*]update the rest of your jumpy-xbmc files (sorry, I should have posted all of them ):
It may not be necessary to do a complete reinstall, just try the older ffmpeg. I'm only guessing that the newer ffmpeg binary could be causing the problem in your setup (maybe with regard to XP? I don't know). I have win7, and my UMS ffmpeg is an older one (maybe even from 1.6.0 ) since I don't usually upgrade the whole package, just ums.jar itself.frentemorao wrote:I will try a clean install of 2.2.4 dropping ffmpeg from 1.6.0 tonight
It's been a while since the last release of jumpy and there are many changes which are the result of you and others finding bugs. When I was testing tvalacarta I noticed that one of the other recent changes applied here too. If you do a brand new install just use this last zip, since it includes the changes from the first zip I posted for you, and also make sure rtmpdump is in the new win32 folder, same as before.frentemorao wrote: infidel wrote:[*]update the rest of your jumpy-xbmc files (sorry, I should have posted all of them ):
xbmc-dev-120104.zip
I have just made two quick tests:
- Older ffmpeg --> no positive results
- I have copied ums.jar 1.6.0 over 2.2.4 and I have managed to watch a couple of minutes of 2 different Tv Shows of mitele... however, as happened yesterday, ffmpeg has started to fail again... Maybe something related with ffmpeg and buffer??
Does mitele cut off in xbmc too? if so it could be cpu capacity.frentemorao wrote:Maybe something related with ffmpeg and buffer?
You can see I'm out of useful suggestions .
Although my cpu capacity is not as desirable or convenient as I would like, I am afraid mitele does not cut off in xbmc...infidel wrote:Does mitele cut off in xbmc too? if so it could be cpu capacity.
I will try to make a test in a computer running win7 (a labtop quite faster than my pc) in order to discard a winXP incompatibility.
Also I think I will ask tvalacarta addon developer about any posible important differences between mitele and the rest of the channels (if any)
It was just a wild guess . Please post back if you learn anything new since as you've no doubt noticed some others users consistently experience similar cutoff problems but the behaviour is hard to replicate.frentemorao wrote:mitele does not cut off in xbmc...
Re: Jumpy Plugin (17 Jan 2013)
Jumpy Plugin is not installing rtmpdump. The system cannot find the file specified.
Checking rtmpdump
Installing rtmpdump
Downloading "https://github.com/downloads/K-S-V/Scri ... mp-2.4.zip"
Download error
unzip: cannot find either rtmpdump-2.4.zip or rtmpdump-2.4.zip.zip.
Checking rtmpdump
Warning: problem installing rtmpdump \nsee C:\\PROGRA~1\\UNIVER~1\\plugins\\jumpy\\win32-setup\\setup.log
backing up and replacing UMS.conf
1 file(s) moved.
1 file(s) moved.
done
Error: some items were not installed.
