IDE
DevlshOne
IDE
Post by DevlshOne »
What should I be using? I tried IntelliJ but it kept crashing. NetBeans doesn't seem to handle Maven very well. Do I need to try Eclipse?
Server: WHS 2011 - AMD Athlon 2.8GHz {Black Edition} - 4GB PC2-6400 - 7TB
SELECT * FROM users WHERE clue IS NOT NULL; Results: 0 rows found
GO DAWGS! SEC East Champions, again!
Re: IDE
I use NetBeans and find it pretty good.
DevlshOne
Re: IDE
Post by DevlshOne »
You still have to check the external dependencies manually, though, right? Maybe there's a configuration option I'm missing to get Maven to behave.
Re: IDE
I don't know, I don't really use any Maven features with NetBeans, I just use it as a code editor
