Version 5.1.1 Bad News
Re: Version 5.1.1 Bad News
It is said: "when sick - stay away". Yup - my head cold went to my brain! During earlier testing I added the 'x' so as to avoid UMS looking at the file. I forgot AND failed to notice it when I posted (which explains why the Parse errors disappeared). Sorry.valib wrote:michael what does it mean .mkvx extension?
The characters '*' and '?' are the problem in v5.1.1. I retested all the Title printable characters with 5.0.0, 5.0.1, 5.1.0 and 5.1.1, all Java 8 - only 5.1.1 failed Parse and DataStream.The others parsed all Titles correctly and the videos played.valib wrote:michael I think that also sign "*" can cause the problem.
again - sorry for the bad post.
I have all the log files but will only post the latest two versions. If needed I can supply the others.
- ums_dbg-24_510J8_Good.zip
- (37.13 KiB) Downloaded 337 times
- ums_dbg-26_511J8_ParseErrs_NoInputStream.zip
- (74.77 KiB) Downloaded 339 times
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
michael in short time Subjunk is going to release new UMS version 5.1.2 with new MediaInfo version 0.7.73. It seems to me that this external library has the problem with the characters '*' and '?'. You can test the new version and we will see. The problem introduced in version 5.1.1 is caused by the implicitly enabled new parsing method MediaInfo = true in the config file. So if you are not willing to rename your media files and avoid using not supported characters you can use Samsung-CD.conf file from the previous version e.g. 5.1.0 which works for you.
Good news - I'll retest & post when I see it.valib wrote:michael in short time Subjunk is going to release new UMS version 5.1.2 with new MediaInfo version 0.7.73. It seems to me that this external library has the problem with the characters '*' and '?'. You can test the new version and we will see.
Not a matter of "not willing" to change - the Title names are read from an online database via the EAN/UPC. I have no control over it.valib wrote:So if you not willing to rename your media files and avoid using not supported characters ...
Note: this is not a "hard" problem, it is intermittent in V5.*. When I first ran 5.1.1 there were no character problems. I have a test library with all printable characters. Most errors cleared up in V5* when "Prettify filenames" and "Ignore the word 'the'" were unselected. However, all characters worked for a short while in 5.1.1, then the '*' & '?' errors. Why??? Don't know.valib wrote:you can use Samsung-CD.conf file from the previous version e.g. 5.1.0 which works for you.
Just saw the media info dll 0.7.73 post - I'll try it now.
Samsung UN55C8000
Samsung UN55C8000
Tried it - no change. Same Parse errors and it seems to trigger the "Not Supported File Format" error too.valib wrote:michael in short time Subjunk is going to release new UMS version 5.1.2 with new MediaInfo version 0.7.73. It seems to me that this external library has the problem with the characters '*' and '?'. You can test the new version and we will see.
Have dbg file (-27) if needed.
Samsung UN55C8000
Samsung UN55C8000
