Can't play MP3 files
Re: Can't play MP3 files
No. There is only one line that treats both files (mp3 and wav) as the same type L16.SubJunk wrote:Thanks for the post It looks to me like Samsung-CD.conf already has those two lines in it...?
I've just replace the line, with those two. Now UMS in my case "knows" how to treat both files.
True. The MP3 files are mpeg audio files so.... you have to "say" UMS that those MP3 files has to be decoded as mpeg files (obvious, right?)nightmare1942 wrote:Hello swiftprince,
thank you for your reply.
I change a config file and used this as default renderer.
Specifically I change
to the lines you wrote. And now it is working.Code: Select all
Supported = f:mp3|wav m:audio/L16
May it needs to be "mpeg" and not "L16"?
Regards
nightmare1942
