Unsupported MKV package
http://www.nyaa.se/?page=download&tid=673862
http://www.nyaa.se/?page=download&tid=675788
Two unsupported media types in a MKV package. Just an FYI so you can improve the server, I have Plex as an alternative but that is not as stable as UMS so I tend to use it more.
- (55.63 KiB) Downloaded 406 times
Re: Unsupported MKV package
Does it play via TRANSCODE folder and
This will force engine chosen instead of playing file with FFmpeg but because file can be remuxed it fails to tsMuxeR which is used in combination with MEncoder.
New UMS versions uses FFmpeg when tsMuxeR is used instead of MEncoder which can have problems with this file.
If tsMuxeR and FFmpeg alone will work with file, it is high chance that new version will play file correctly (where MEncoder is replaces with FFmpeg when file is remuxed by txMuxeR to get higher compatibility)
EDIT:
OK, not really merged but you can test it by using UMS Builder
https://github.com/UniversalMediaServer ... -103388696
- MEncoder engine
- FFMPEG Engine
- tsMuxeR Engine
EDIT:
