PS4 now support DLNA!
Re: PS4 now support DLNA!
Thanks for all the testing, you guys are really helping :) Here's a new build for you guys, I'm curious to see how it goes. There are a lot of different things in this one than previous ones:
Edit: Link removed because of bug
AlGrenadine
Post by AlGrenadine »
Hi
Now i have "unreadable media" on the ps4 on basic xvid videos that were previously working...
(105.03 KiB) Downloaded 842 times
Thanks for the quick response, I made a mistake with that version. Here's a fixed one: http://www.spirton.com/uploads/UMS/UMS-b47a368.exe
AlGrenadine
Now it works :)
But Fast Forward or Rewind is disabled in PS4 MediaPlayer :(
(171.58 KiB) Downloaded 849 times
Phonism
Post by Phonism »
Thank you for the test version, SubJunk! I downloaded UMS-f7eb827.exe and I have the same results as usual - every transcoding fails with the message cannot play the media.
But no transcoding plays for about one and a half minute before stopping.
The crazy thing is, as previously mentioned, is to change the .mkv to .ts and then transcoding works, even with subtitles, and not stopping.
Attached is the trace log files. Hope it helps :)
(65.79 KiB) Downloaded 851 times
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
Phonism
Post by Phonism »
After posting, I saw the UMS-b47a368.exe was uploaded. I installed it and wow, the mkv files plays with encoding now! :D Great work!
Just for testing, I went into the transcoding folder and tried starting the no encoding, but now it gets the message about cannot play the media.
I attached a new debug file.
(65.5 KiB) Downloaded 858 times
PS3 Slim 120GB
PS4
mileleku
Post by mileleku »
SubJunk wrote:Thanks for the quick response, I made a mistake with that version. Here's a fixed one: http://www.spirton.com/uploads/UMS/UMS-b47a368.exe
I love you!
Thanks a lot. It is indeed transcoding everything I throw at it just fine now. :) The only issue left is that the length of the videos isn't being displayed while they play. Need more logs to fix that?
Other than that, goodbye old and noisy PS3..
Edit: Just discovered that FLAC files won't show up / play, as well. The Transcode Folder is empty for those FLAC files, too.
Well, the most important thing is working already, so really really thanks for your hard work. :)
AlGrenadine
I confirm length is not displayed and maybe that's why ff/rw does not work ?
Hi guys, thanks for all the reports, I'm glad we are onto something :)
Please use the attached config and let me know if it makes a difference to those issues:
Sony-PlayStation4.conf
(1.41 KiB) Downloaded 1035 times
AlGrenadine
Total length is still unknown on media player
