Caught exception Java error on 360
tMH
Post by tMH »
INFO  2012-06-07 23:05:58.589 [New I/O server worker #1-8] Starting transcode/remux of [A-Destiny]_Toriko_-_59_(848x480_h264_AAC)_[C7360574].mkv
DEBUG 2012-06-07 23:05:58.714 [New I/O server worker #1-8] Caught exception
java.lang.ArithmeticException: / by zero
	at net.pms.encoders.MEncoderVideo.launchTranscode(MEncoderVideo.java:1876) ~[ums.jar:na]
	at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:1537) ~[ums.jar:na]
	at net.pms.network.RequestV2.answer(RequestV2.java:313) ~[ums.jar:na]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:306) ~[ums.jar:na]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:269) ~[ums.jar:na]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[ums.jar:na]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_03]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_03]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_03]
I get that on any mkv I try to play on my 360. I just installed UMS a few minutes ago, any suggestions?
Re: Caught exception Java error on 360
Hi tMH, welcome to the forums and program! Thanks for letting us know about this bug. It was caused by the overscan compensation setting.
The fix will be in the next release and here's a build I made for you with the fix so you don't have to wait :)
tMH
Post by tMH »
Thank you!
