Installation, Avisynth 2.6 MT question
During the installion of UMS 1.1.0 it asks for Avisynth 2.6 MT, and you can let it install it for you.. If you run the installation again, it still asks you to install Avisynth 2.6 and goes ahead and install it again.. Please make a check in the installation to see if it's already installed, or remove the question from the installation completely and let it check it in UMS itself.
Re: Installation, Avisynth 2.6 MT question
Hi SuperDre, thanks for the suggestion
It's a bit hard to check if it's already installed because it is a custom version of AviSynth; we want this specific version of AviSynth to be installed and not any others that would be recognised as identical by the installer.
Anyway I don't think it's too hard to just click "no" when you install the program
I have SEt's 2.6 MT installed already with UMS 1.0.1. Going to install latest UMS shortly and just a quick question, okay two. Before installing 1.0.1 should I remove the SEt 2.6 MT "avisynth.dll"? Should I uninstall AviSynth 2.5.8 as well? I was already here and saw this thread so went ahead and asked.
Peace!
Doesn't matter either way
If you select "yes" it will replace your current AviSynth files with the latest ones, if you select "no" it will leave them alone.
Thanks for quick reply. I stuck with the versions of AviSynth I already had installed and told UMS 1.1.0 installer to skip AviSynth installation. I have a lot more troubleshooting to do but it seems like AviSynth is now giving me problems whether playing a file with "AviSynth/FFDshow" or "AviSynth/Mencoder." I will provide update unless, as often happens, I discover it was a short between the keyboard and chair.
Peace!
Peace!
Peace!
i have AviSynth 2.6 MT installed, yet UMS install still asks to install ...could it be that i installed it myself? ...going to uninstall AviSynth and let UMS install it with a clean install ...maybe this will fix my TEDTalks problem, as well ...on that note, The Onion feed works fine ...peace
Yeah it needs to be installed via UMS because that is how we know you are using the version we support
