UMS reports GUI environment not available
Blue-Dog-Archolite
Post by Blue-Dog-Archolite »
I am attempting to set up UMS but am unable to load GUI.
During load, it reports `GUI environment not available`
UMS: 5.3.1 Downloaded 2015-12-01
Fedora 23
Linux 4.2.6-301.fc23.x86_64 #1 SMP Fri Nov 20 22:22:41 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Java Version:
openjdk version "1.8.0_65"
OpenJDK Runtime Environment (build 1.8.0_65-b17)
OpenJDK 64-Bit Server VM (build 25.65-b01, mixed mode)
Attached is the console log after starting UMS.
I would love a GUI to load, however if that is not possible in Fedora, I would be happy with some direction as to how to configure, and where to configure what directories to load for streaming.
Thanks for the help.
ums_result.txt
(10.6 KiB) Downloaded 437 times
Tonne M
Re: UMS reports GUI environment not available
Post by Tonne M »
What you might try is looking at http://10.163.1.10:9001 This is where the webinterface should be in your case.
Hope you have some luck with this,
Tonne
