Version 2.5.0 is released
Re: Version 2.5.0 is released
Cool, thanks for confirming that it works! :)
OS X version is still coming soon BTW, just waiting for it to be built
Impee
Post by Impee »
Hi Subjunk,
Thanks again for this great release and your unremitting work. I really aprreciate what you're doing!
I was glad to see you improved the aspect ratio handling on Panasonic and Sony TVs. In this context, i would like to bring this thread to your attention: viewtopic.php?f=5&t=615
In this thread, OlliL explains how he managed to tackle a lot of aspect ratio problems (such as black borders, stretching or cropping) on the Sony EX715 and EX716. His tips & tricks are also valid for the EX711 model.
Maybe you can use this information and apply it in a more general way? I will leave this up to you as i can't evaluate this myself.
Regards,
Impee.
Uzerrr
Post by Uzerrr »
WoW!
Changelog is impressive! Thanks a lot for your hard work guys.
ExSport
Post by ExSport »
@Impee
I don't think this settings should be used because it will not be universal for any AR so some aspect ratios will be incorrectly displayed on TV.
Furthermore this will downscale all 1080p files to weird 1283x720 resolution and upscale any other low res files. It uses bicubic algorithm for rescaling so not the best too.
mencoder_decode =  -vf softskip,expand=::::1:16/9:2,scale=1283:720 -lavcopts aspect=16/9
Btw. with this settings (using softskip at the beginning and :1:) you will get subtitles headache :mrgreen:
viewtopic.php?f=9&t=580
Right now, if I am not wrong, AR fix for Sony Bravia in new version is only with FFMPEG engine? 8-)
tmeader
Post by tmeader »
I was happy to see an entry about improved Sony Blu-ray support... but it appears to still fail quite decisively on most mkv (h264 encoded) files on the most recent x90 series of players (390,590,790) running the latest firmware. I'm not sure if this breaks compatibility with older DLNA Sony Blu-ray players, but for this series, the following conf video section works:
Supported = f:mpegps|mpegts v:mpeg1|mpeg2 a:ac3|dts|lpcm|mpa|mp3 m:video/mpeg
Supported = f:mpegts v:h264|vc1 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3 m:video/vnd.dlna.mpeg-tts
Supported = f:mp4|m4v v:mp4|h264 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3 m:video/mp4
Supported = f:avi|divx v:divx|mp4 a:ac3|lpcm|mpa|mp3 m:video/x-divx
Supported = f:mkv v:mp4|divx|h264 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3 m:video/mp4
Supported = f:wmv v:wmv|vc1 a:wma m:video/mp4
Maybe this can be integrated into the next release somehow?
Thanks.
sujayt
Post by sujayt »
Any ETA on the OSX build?
Nope :( Unfortunately I rely on someone else for that
Phonism
Post by Phonism »
2.5.0 is running like a champ on my new rig! :D Thank you, thank you, thank you :D
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
sHawTY
Post by sHawTY »
Any news on UMS v2.5.0 for Mac?
Optimus_prime
Post by Optimus_prime »
I'm currently trying to build it now for mac, took me a while to get the VM image setup
