UMS dont show up at screen on mac
Maxglauzon
Post by Maxglauzon »
Hi, I was able to install the last version of UMS and was able to load it up after some issues but now I dont see the app or anything else except the menu on top of the screen (see the attachement).
I dont see anything else and I'm not able to show other options. I dont know if a selected something wrong with the set up of the application or I got a issu with Java.
Any idea?
Capture d’écran 2016-04-01 à 11.40.31.png (66.25 KiB) Viewed 8252 times
takethepain
Re: UMS dont show up at screen on mac
Post by takethepain »
I had that problem because I hit 'minimize at startup' when I went through the start up wizard. The solution I found was to hold down option key while in the finder, click the 'Go' menu item and then select Library (once in library you can let go of the option key). Then open the folder Application Support and then UMS. Double Click on the UMS.conf file and change minimized = false to minimize = true. Then save and open up the UMS application and it should work for you. At least it did for me!
grish
Post by grish »
setting to false worked for me.
thk's
