RESOLVED: DirecTV HRxx and Hxx Thread
Re: RESOLVED: DirecTV HRxx and Hxx Thread
"Process E:\Program Files (x86)\Universal Media Server\win32\mencoder.exe has a return code of 1! Maybe an error occurred... check the log file"
Same as the others. Are you wanting debug.log or logback.xml?
Yeah I've noticed an Issue with MKV's as well...
Universal Media Server Wiki!
I just tried an .avi file, same issue.
Do you have MEncoder at the top of your Video Files Engine? If so, what do you have clicked/unclicked? My i5 2500k doesn't support multithreading, so I turned that off. Same result turning it on anyways.
the CONF file is specifically using MEncoder to do the transcoding.
I'm still getting Video only with this conf file.
# Profile for DirecTV
# Boxes Tested: H23-600, H25-500, HR34-700 (Genie), HR24-500 (DVR)
# This profile is still in an experimental stage.
# You are encouraged to experiment and report back the results on the forums
# at http://www.universalmediaserver.com/forum/
# Know Issues: if three or more boxes are trying to watch the same movie at the same time,
# the third box will jump into someones stream; not intrupting the origional streamer.
#---------------------General informations / detection-----------------------
RendererName=DirecTV HR
# UserAgentSearch: regular expression to detect the connected renderer.
# DirecTV has been observed using the following user agents:
# User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
# User-Agent: Linux/2.6.18.5, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
# User-Agent: Linux/2.6.31-2.6, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
# Combined regular expression of working user agents
UserAgentSearch=DIRECTV
# UserAgentAdditionalHeaders: additional HTTP header for better detection
UserAgentAdditionalHeader=DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
UserAgentAdditionalHeaderSearch=
#Basic capabilities
Video=true
Audio=true
Image=true
#--------------------DLNA settings-------------------------------------------
# Use the DLNA feature seek by time and not by range
SeekByTime=true
# Serve different flavors of localization in the DLNA parameters (PAL/NTSC, NA/EU/JP)
# to allow every worldwide renderer to see the files.
DLNALocalizationRequired=true
#--------------------Transcoding/Muxing capabilities-------------------------
# Transcode profiles for video and audio engines
# currently supported: MPEGPSAC3, MPEGTSAC3 or WMV for video, LPCM, WAV or MP3 for audio
TranscodeVideo=MPEGPSAC3
TranscodeAudio=MP3
# Use default DVD buffer size: false = greater bitrate and faster encoding,
# but can generate incompatible videos, depends of your media renderer
DefaultVBVBufSize=true
# Does the media renderer supports DTS wrapped into LPCM in a mpeg file ?
WrapDTSIntoPCM=false
# Does the Device need Muxing? (false by default)
MuxH264ToMpegTS=true
MuxDTSToMpeg=true
MuxLPCMToMpeg=true
# MIME Changes? (oldmime=newmime|olemime2=newmime2|...)
#MimeTypesChanges=
# Maximum bit rate supported by the media renderer (0=unlimited)
MaxVideoBitrateMbps=8
# Max Width and Height supported by the media renderer (0=unlimited)
MaxVideoWidth=0
MaxVideoHeight=0
# Does the media renderer supports only H264 L4.1 at most?
H264Level41Limited=false
# Does music files need to be resampled at 44.1kHz?
TranscodeAudioTo441kHz=true
# Does the client need to receive transcoded video with minimal delay ?
# (Useful when the client has a small timeout delay)
TranscodeFastStart=true
# Size of the transcoded file (unknown length) sent to the renderer (could
# determine browsing failure/success) Possible values:
# -1: Specific value working with the PS3, means perfect transcoding
# and copying support (it is against the DLNA spec though)
# 0: size attribute is NOT sent to the renderer (default value if
# this parameter isn't used)
# 100000000000: 100Gb, if you want to be sure that the media file is not cut
# before the end
TranscodedVideoFileSize=-1
#--------------------Misc Settings--------------------------------------------
# Rotate JPEG files based on EXIF information
AutoExifRotate=false
# Disable these once MediaInfo=True works.
# What extensions are forcefully transcoded
# Don't use this if MediaInfo=true, prefer codec configurations
TranscodeExtensions=mpeg2,lpcm,mp3,wav,jpg,mpegps,mpegts,wmv,avi,mp4,mov,flv,rm,mkv,wavpac,aac,ac3,mpa,ogg,wma,dts,dtshd,truehd,eac3,atrac,flac,ape,ra,mpc,aiff,alac,dv,mpeg1,divx,h264,mjpeg,vc1,png,gif,tiff,bmp,und
# What extensions are forcefully streamed as is (and not transcoded)
#StreamExtensions=
#--------------------Meat and Potatos----------------------------------------
# CustomMencoderOptions: Overrides the MEncoder custom options in UMS for
# this renderer. The below has been Tweeked for DirecTV MediaShare!
CustomMencoderOptions = -channels 2 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=mp2:abitrate=192:threads=8:keyint=0:vqscale=1:vqmin=1:vrc_maxrate=8192:vrc_buf_size=8192 -aid 0 -nosub -noautosub -ofps 24000/1001 -vf scale=1280:720 -lavdopts fast -mc 0.1 -af lavcresample=44100 -srate 44100 -o
#hold
# -vf expand=-0:-2,softskip
MediaInfo=false
# All supported media formats of this renderer (the rest will be transcoded)
# First steps towards a faster/proper file/codec/mimetype management system (false by default)
# 1- Parse files with mediainfo on Windows/OSX (Linux too if libmediainfo and libzen installed)
# 2- Deprecate following parameters: MuxH264ToMpegTS,MuxDTSToMpeg,MuxLPCMToMpeg,MimeTypesChanges
# 3- The server will skip badly parsed, corrupted files or wrong coding, preventing potential playback errors
# 4- Faster browsing, due to the launch of ffmpeg/mplayer first thumbnailer process with each http client request, rather than in the browse DLNA request
# Use MediaInfo for faster and proper file, codec and mime type management
# system (false by default).
# The media parser and this configuration file will recognize the following
# formats and codecs (lower case only, regular expressions are supported).
# Chosen from the most common used and supported formats and codecs.
# mpegps (mpeg presentation stream, used in DVD Videos, VCDs, etc.)
# mpegts (mpeg transport stream, used in sat tv, blu rays, etc.)
# wmv (Windows Media Video, tag also used for asf files)
# avi (AVI container)
# mp4 (ISOM/MPEG4 container, or MPEG4 codec)
# mov (Quicktime container, Apple)
# flv (Flash Video)
# rm (Real Media, RMVB)
# mkv (Matroska)
# wav (WAVE file)
# wavpac (WavPack)
# lpcm (Linear PCM)
# aac (Advanced Audio Codec)
# ac3 (Audio Coding 3)
# mp3 (Mpeg Audio Layer 3)
# mpa (Mpeg Audio)
# ogg (Ogg Vorbis)
# wma (Windows Media Audio)
# dts (Digital Theater Systems)
# dtshd (Digital Theater Systems)
# truehd (TrueHD)
# eac3 (Extended AC3)
# atrac (Atrac)
# flac (Free Lossless Audio Codec)
# ape (Monkey's Audio)
# ra (Real Audio)
# mpc (MusePack)
# aiff (AIFF)
# alac (Apple Lossless)
# dv (Digital Video)
# mpeg1 (Codec used in VCD)
# mpeg2 (Codec used in DVD Videos and HDTV)
# divx (DivX Video)
# h264 (H264)
# mjpeg (M-JPEG)
# vc1 (VC-1)
# jpg (Jpeg)
# png (PNG)
# gif (GIF)
# tiff (TIFF)
# bmp (Bitmap)
# und (Undetermined, if the parser did not recognize one of above)
# Usage [IN ORDER TOO]:
# f: format, MANDATORY (the only conf for a 'eat everything' renderer would be f:.+)
# v: video codec
# a: audio codec
# n: max nb of audio channels (2 or 6)
# s: max audio sample frequency in Hz
# b: max audio bitrate in bps
# w: max width in pixels
# h: max height in pixels
# m: mimetype, STRONGLY RECOMMENDED (if not declared, an estimated value is assigned)
# other flags: right now, only qpel and gmc (see avi)
# In case of multiple matches, the first mime type of the list is the used one.
# Be careful with regexps such as .+ : You should not use these except when you
# are sure your renderer is quite versatile.
# [Supported video formats]:
#Supported = f:mpegts v:mpeg2 a:mp2 n:2 s:44100 b:192000 m:video/mpeg
# [Supported audio formats]:
#Supported = f:mp3 n:2 s:44100 m:audio/mpeg
# [Supported image formats]:
#Supported = f:jpg m:image/jpeg
# Use faster method to create DLNA tree with MediaInfo. Not supported by some renderers,
# false by default (upnp specification violation).
CreateDLNATreeFaster = true
I've tried everything I can think of and that config file just don't work for me. Do you need the .xml or .log with Trace on to pinpoint it?
Griffin, your using an old conf file.
Ill update the main page once I get home.
I'm using this one.
#Basic capabilities
Video=true
Audio=true
Image=true
SeekByTime=true
TranscodeAudio=MP3
MuxDTSToMpeg=true
MuxLPCMToMpeg=true
#MimeTypesChanges=
MaxVideoWidth=0
MaxVideoHeight=0
# before the end
#TranscodeExtensions=mpeg2,lpcm,mp3,wav,jpg,mpegps,mpegts,wmv,avi,mp4,mov,flv,rm,mkv,wavpac,aac,ac3,mpa,ogg,wma,dts,dtshd,truehd,eac3,atrac,flac,ape,ra,mpc,a
#StreamExtensions=
autoaspect=1:vcodec=mpeg2video:acodec=mp2:abitrate=192:threads=8:keyint=25:vqmax=8:vqmin=3:vrc_maxrate=3000:vrc_buf_size=1835 -aid 0 -nosub -noautosub -ofps
#hold
MediaInfo=false
# flv (Flash Video)
# mkv (Matroska)
# wav (WAVE file)
# wavpac (WavPack)
# lpcm (Linear PCM)
# mpa (Mpeg Audio)
# ogg (Ogg Vorbis)
# truehd (TrueHD)
# atrac (Atrac)
# ra (Real Audio)
# mpc (MusePack)
# aiff (AIFF)
# divx (DivX Video)
# h264 (H264)
# mjpeg (M-JPEG)
# vc1 (VC-1)
# jpg (Jpeg)
# png (PNG)
# gif (GIF)
# tiff (TIFF)
# bmp (Bitmap)
# v: video codec
# a: audio codec
I'll try the one on the front page again today, it looks like you updated it. When you cut/paste these into the conf file do you reformat them to get the extra space and line breaks out the the /code puts in on the forums?
No leave the line breaks in... makes for cleaner formatting
