Add a search option in editing UMS.conf conf menu
Sami32
Post by Sami32 » Sun Jul 17, 2016 7:38 am
Like in the "Logs" tab, a search filter will be appreciate in "General Configuration" --> "Edit UMS.conf configuration file manually".
I find that it will be more usable for fast manual editing, avoiding using an external editor.
squadjot
Re: Add a search option in editing UMS.conf conf menu
Post by squadjot » Tue Jul 19, 2016 11:10 pm
Why does it open in GUI in the first place? is it because when you press "save", it will trigger a internally "refresh" in UMS?
I'd prefer it to open in external editor tbh. (just like renderer configs)
Sami32
Post by Sami32 » Wed Jul 20, 2016 11:42 pm
Good remark...but i don't have the answer ;-)
I can only told you that Panasonic Viera user are not able, without patch, to access renderer conf from UMS.
For now, if you want open UMS.conf in your editor from UMS, you need to go to the Logs tab and select "Pack debug files" and open from there.
squadjot
Post by squadjot » Thu Jul 21, 2016 1:26 am
Sami32 wrote: For now, if you want open UMS.conf in your editor from UMS, you need to go to the Logs tab and select "Pack debug files" and open from there.
Hm, If i would open and edit the UMS.conf. I'd just open the actual UMS.conf "C:\ProgramData\UMS\UMS.conf"
Edit: I don't know what you mean about the Panasonic Viera users
