3D support
valib
Re: 3D support
Post by valib » Sun Dec 11, 2016 3:13 am
The UMS simply stream the 3D video as it is or convert to other 3D formats like Bino does. Also can transcode video and add 3D subtitles.
Sami32
Re: 3D support
Post by Sami32 » Sat Jun 10, 2017 1:44 pm
@violetta Hello,
if your question was is UMS able to make it 2D, as Bino player, the answer is no.
So if you try to see it on non 3D renderer, you'll have a "splitted" screen display, and eventually 3D subtitles.
That's said, it can be done, but i don't really see the point, as i thought that the 3D BlueRay need to have the 2D version as well ?
valib
Re: 3D support
Post by valib » Sat Jun 24, 2017 12:50 am
It seems that all discussion is reacting on the original question which was deleted for some reason in the meantime.
