UMS not finding PS4
Matimotof1
UMS not finding PS4
Post by Matimotof1 » Sat Jun 03, 2017 7:20 am
Dear friends, I have a mac book pro mid 2012 with osx Sierra 10.12.5 UMS and java version 8 update 131, I have a chromecast and a tv lg 55 which UMS finds them and I can transmit video and audio without any problem but can not find my Play Station 4. I have installed the Media Player App on PS4 but can not find it. I attached the log. I hope you can help me. Thank you all for your time.
(24.58 KiB) Downloaded 186 times
Sami32
Re: UMS not finding PS4
Post by Sami32 » Mon Jun 05, 2017 8:32 am
your other renderers only work because they are using Chromecast.
You've a network issue. Your PS4 is not on the same submask as UMS, so that's not going to work.
You are actually using the en4 network interface, you need to change it.
Go in "General Configuration" tab, and in "Force networking on interface:" select the right one (192.168.0.xx).
Hoping that helped.
Matimotof1
Post by Matimotof1 » Tue Jun 06, 2017 6:31 am
Thank you very much. I will do that and post the results.
Matimotof1
Post by Matimotof1 » Sun Sep 10, 2017 5:58 am
Dear Friends,
I have problems trying to use UMS and PS4
UMS in MacBookPro Retina mid 2012, MAC OS SIERRA VERSION 10.12.6 connecting to internet via WI-FI to the cable modem
PS4 connects to internet using LAN cable to the WIFI cable modem
ums finds the LG smart tv and the chromecast I use on small tv
I Hope there is a solution. I'm struggling to get this right. I must say that I have not Networking knowledge. :mrgreen:
Thank You Very Much
(21.83 KiB) Downloaded 110 times
