Can't find folder
Can't find folder
For some reason, I selected the start minimized option during installation and can't access the UI.
I am trying to change the settings but can't find the UMS folder in /Library/Application Support.
UMS is running but I can't find the folder anywhere.
I have yosemite 10.10.5, java 8 and UMS 5.2.2 for java 8.
Re: Can't find folder
@spark3575
UMS config files reside in your home/Library/Application Support/UMS folder:
or
where xxxxx is the name of your user account.
~/Library/Application Support/UMS
or
/Users/xxxxx/Library/Application Support/UMS
I can not find the folder in either location.
The app seems to run and the app is in the applications folder.
This UMS folder is hiding from me...
