[Fixed] UMS Mac OS X 2.2.4 Couldn't Play Some MKV Files
sHawTY
Post by sHawTY »
I've just downloaded & installed UMS Mac OS X 2.2.4. Everything is working perfectly except a few latest One Piece episodes couldn't be played at all.
First, I've tested playing [HorribleSubs] Fairy Tail - 163 [480p].mkv, it plays perfectly until the end.
But when I tried playing [HorribleSubs] One Piece - 579 [360p].mkv, it says "This content cannot be played [800288E1]".
At first I thought the episode 579 has some problem, so I tested playing all episodes from 568 until 578, all couldn't be played at all. The same error occurs.
This is strange as back when I was using PS3 Media Server [pms-macosx-1.72.0], all episodes from 568 until 578 works perfectly.
Then I tried transferring all One Piece 568 until 579 to another disk in my Mac, the same error occurs.
I don't have any Windows PC in my house so I don't know if the error also affects UMS Windows version.
Hope someone could check on this. Thanks.
Owh and by the way, all One Piece 568 until 579 plays perfectly on my Mac (Using MPlayerX v1.0.1.7), no problem at all. The error only occurs when I wanted to play them through Universal Media Server.
My Mac is running Mountain Lion 10.8.2 & all network connection is through gigabit lan. Not WiFi.
Re: UMS Mac OS X 2.2.4 Couldn't Play Some MKV Files
Thanks for reporting this. Please attach your debug.log after attempting to play it, that will help me fix it
sHawTY
Post by sHawTY »
The problem has been fixed in UMS Mac OS X version 2.2.5.
Thank you for fixing it so fast. :)
Will report again if there's any other problem.
Great, thanks for confirming the fix :)
