Version 3.6.3 is released
Paradox
Re: Version 3.6.3 is released
Post by Paradox »
valib wrote:Thanks for your input but there is not missing semicolon. In the line 1894 there is
vfValuePrepend += "expand=-" + expandBorderWidth + ":-" + expandBorderHeight;
and the previous code checks if resolution is divided by 4 and this line add the black bars where needed.
hmm yep looked again and you are 100% correct. Doh i should had looked harder.
I wonder why it does not work on a Sony EX TV unless you set manually in the renderer conf file? Just another stupid Sony quirk i suppose.
Thanks for the quick response.
If you make one debug log with it set manually and another with the default, and attempt to play the same file both times, we can see what's going on
Paradox
Post by Paradox »
SubJunk wrote:If you make one debug log with it set manually and another with the default, and attempt to play the same file both times, we can see what's going on
Done and posted here.....
viewtopic.php?f=9&t=1959
Hope it makes sense and is ok ive uploaded all 3 logs in a single post
darkerthanblack
Post by darkerthanblack »
On 3.6.3 version UMS, some errors were appeared in debug log.
These were not on 3.6.2.
06-18 16:19:04  Starting Universal Media Server 3.6.3
06-18 16:19:04  Based on PS3 Media Server by shagrath, copyright 2008-2014
06-18 16:19:04  http://www.universalmediaserver.com
06-18 16:19:04
06-18 16:19:04  Build: 33f483366 (2014-06-13)
06-18 16:19:04  Java: Java HotSpot(TM) 64-Bit Server VM 1.6.0_65 64-bit by Apple Inc.
06-18 16:19:04  OS: Mac OS X 64-bit 10.9.3
06-18 16:19:04  Encoding: UTF-8
06-18 16:19:04  Memory: 763 MB
06-18 16:19:04  Language: ko
06-18 16:19:04
06-18 16:19:04  Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java
06-18 16:19:04  Temp directory: /var/folders/4t/djcvvmys2gz9n_wyr1zvbrv00000gn/T/universalmediaserver
06-18 16:19:04  Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml
06-18 16:19:04  debug.log: /Users/Taki/Library/Application Support/UMS/debug.log
06-18 16:19:04
06-18 16:19:04  Profile directory: /Users/Taki/Library/Application Support/UMS
06-18 16:19:04  Profile directory permissions: rw
06-18 16:19:04  Profile path: /Users/Taki/Library/Application Support/UMS/UMS.conf
06-18 16:19:04  Profile permissions: rw
06-18 16:19:04  Profile name: Temuzine.local
06-18 16:19:04
06-18 16:19:04  Web conf path: /Users/Taki/Library/Application Support/UMS/WEB.conf
06-18 16:19:04  Web conf permissions: file not found
06-18 16:19:04
06-18 16:19:04  Loading renderer names from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
06-18 16:19:04  Loading MediaInfo library
06-18 16:19:04  Loaded MediaInfoLib - v0.7.58
06-18 16:19:04  Checking shared folder: /Volumes/Shredis
06-18 16:19:04  Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
06-18 16:19:04  Loaded configuration for renderer: AirPlayer
06-18 16:19:04  Loaded configuration for renderer: Android
06-18 16:19:04  Loaded configuration for renderer: Sony Bravia BX305
06-18 16:19:04  Loaded configuration for renderer: Sony Bravia W Series
06-18 16:19:04  Loaded configuration for renderer: LG LA6200
06-18 16:19:04  Loaded configuration for renderer: LG LA644V
06-18 16:19:04  Loaded configuration for renderer: LG LM620
06-18 16:19:04  Loaded configuration for renderer: PlayStation 3
06-18 16:19:05  Loaded configuration for renderer: iPad / iPhone
06-18 16:19:05  Checking the fontconfig cache, this can take two minutes or so.
06-18 16:19:05  Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins
06-18 16:19:05  No plugins found
06-18 16:19:05  Registering transcoding engine: FFmpeg Audio
06-18 16:19:05  Registering transcoding engine: MEncoder
06-18 16:19:05  Registering transcoding engine: VLC
06-18 16:19:05  Registering transcoding engine: FFmpeg Web Video
06-18 16:19:05  Registering transcoding engine: MEncoder Web
06-18 16:19:05  Registering transcoding engine: VLC Web Video
06-18 16:19:05  Registering transcoding engine: tsMuxeR
06-18 16:19:05  Registering transcoding engine: Audio High Fidelity
06-18 16:19:05  Registering transcoding engine: VLC Web Audio (Legacy)
06-18 16:19:05  Registering transcoding engine: VLC Web Video (Legacy)
06-18 16:19:05  Registering transcoding engine: dcraw Thumbnailer
06-18 16:19:05  Using address /192.168.11.5 found on network interface: name:en1 (en1)
06-18 16:19:05  Created socket: /192.168.11.5:5001
06-18 16:19:05  Using the following UUID configured in UMS.conf: c6312f9f-4c03-4a50-b13a-b2d5a481d12e
06-18 16:19:06  The server is now available for renderers to find
06-18 16:19:41  Sending BYEBYE...
06-18 16:19:41  Stopping server on host 192.168.11.5 and port 5001...
06-18 16:19:42  No IP filter specified, access granted to /192.168.11.5
06-18 16:19:42  Exception in thread "UPNPHelper" java.lang.NullPointerException
06-18 16:19:42  	at net.pms.network.UPNPHelper.sendDiscover(UPNPHelper.java:88)
06-18 16:19:42  	at net.pms.network.UPNPHelper.access$400(UPNPHelper.java:39)
06-18 16:19:42  	at net.pms.network.UPNPHelper$2.run(UPNPHelper.java:399)
06-18 16:19:42  	at java.lang.Thread.run(Thread.java:695)
06-18 16:19:42  Using address /192.168.11.7 found on network interface: name:en0 (en0)
06-18 16:19:42  Created socket: /192.168.11.7:5001
06-18 16:19:42  No IP filter specified, access granted to /192.168.11.7
06-18 16:19:43  No IP filter specified, access granted to /192.168.11.2
06-18 16:19:43  Checking IP: 192.168.11.2 for PlayStation 3
06-18 16:19:44  Renderer PlayStation 3 found on this address: 192.168.11.2
06-18 16:19:47  Sending BYEBYE...
06-18 16:19:47  Stopping server on host 192.168.11.7 and port 5001...
06-18 16:19:48  Using address /192.168.11.7 found on network interface: name:en0 (en0)
06-18 16:19:48  Created socket: /192.168.11.7:5001
06-18 16:20:02  Checking shared folder: /Volumes/Shredis
06-18 16:20:02  Error adding child: "A/V 동기화 방법 강제 할당"
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:655) [ums-3.6.3.jar:na]
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:479) [ums-3.6.3.jar:na]
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1182) [ums-3.6.3.jar:na]
	at net.pms.dlna.RootFolder.addAdminFolder(RootFolder.java:1032) [ums-3.6.3.jar:na]
	at net.pms.dlna.RootFolder.discoverChildren(RootFolder.java:184) [ums-3.6.3.jar:na]
	at net.pms.dlna.DLNAResource.discoverChildren(DLNAResource.java:1060) [ums-3.6.3.jar:na]
	at net.pms.dlna.DLNAResource.discoverWithRenderer(DLNAResource.java:973) [ums-3.6.3.jar:na]
	at net.pms.dlna.DLNAResource.getDLNAResources(DLNAResource.java:895) [ums-3.6.3.jar:na]
	at net.pms.network.RequestV2.answer(RequestV2.java:658) [ums-3.6.3.jar:na]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:288) [ums-3.6.3.jar:na]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:246) [ums-3.6.3.jar:na]
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:485) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [netty-3.9.1.Final.jar:na]
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [netty-3.9.1.Final.jar:na]
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895) [na:1.6.0_65]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918) [na:1.6.0_65]
	at java.lang.Thread.run(Thread.java:695) [na:1.6.0_65]
06-18 16:20:02  Error adding child: "Default H.264 Remux with MEncoder"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1190) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "  !!-- Fix 23.976/25fps A/V Mismatch --!!"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1199) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "Deinterlace Filter"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1208) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "모든 자막 무시"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1217) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "비디오와 이름이 같을 경우 자동으로 자막 로드하기 *.srt/*.sub"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1227) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "ASS 기본 스타일 사용하기"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1237) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "Skip loop filter deblocking for H.264. Can degrade quality."
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1247) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "Keep DTS tracks"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1255) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "설정 저장"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1263) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "재시작"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1275) [ums-3.6.3.jar:na]
06-18 16:20:02  Error adding child: "Hide the "Live Subtitles" folder"
	at net.pms.dlna.RootFolder.getVideoSettingsFolder(RootFolder.java:1282) [ums-3.6.3.jar:na]
Paradox
Post by Paradox »
^^^^ Did you really need to post that long quote? Would it not had been more sensible to point out there is an issue and upload the full log in a forum section that allows attachments?
Regardless to me it looks like you have a java issue, if i had to guess i bet this is MAC/OSX related, if it is try a newer or older java version. I think there was some MAC related java issue around version UMS 3.6x and onward.
darkerthanblack
Hi!
Finally I have succeeded transcoding by ffmpeg with subtitle.
But fontsize of the subtitle is very small.
In case of mencoder, the fontsize is normal.
How to fix this problem?
