Several configuration on same main device
Trebly
Post by Trebly » Mon Aug 03, 2020 4:12 am
I have not found the answer to this :
I have a Amazon fireTV 4K as device to render on a TV.
The Amazon fireTV can run various softwares to render media to the TV : example is VLC and KODI.
The configurations can then be dynamically change from VLC on FireTV to KODI on FireTV which has not the same properties for defining the configuration.
Which configuration file to create with which parameters ?
Currently it seems that the properties are associated to the main devices. But practically it is like the properties of this main device were changing dynamically.
Best regards.
Trebly
